![]() How old are your sparkplugs? We've had a lot of trouble over the years with Champions, and used to buy the Auburns before Champion bought them up and shut them down. They were an excellent plug and almost always eroded to limits before the internal resistor failed. With Champs, we've had the internal resistor misfiring at 50 hours. One didn't work right out of the box. The Unison plugs are no better. A poorly-firing plug will cause a slight RPM drop. They need to be tested under pressure to see that they continue to fire up to at least 120 psi. Dan |
Dave wrote:
: Exhaust restriction? Bad mufflers can rob lots of power and be : intermittent. : I'm not saying valve clearance isn't the problem, but your clearances : don't seem extreme. : Also, plugs can test well but the internal resistance can bugger things : up. I've read that 5k ohms or over may be excessive. The spark will find : easier places to go than across the electrodes. : good luck As I said in my initial message, muffler baffles checked and fine. I have overhauled the mufflers this year due to cracks in the end plates, but the baffles were fine when they were removed. As far as the plugs, we replaced them about a year ago. Had the intermittent failures with the old plugs, new plugs, and mag drops were fine in all cases. Doesn't seem to be ignition-related. -Cory ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
On Sep 25, 8:46 pm, wrote:
Dave wrote: : Exhaust restriction? Bad mufflers can rob lots of power and be : intermittent. : I'm not saying valve clearance isn't the problem, but your clearances : don't seem extreme. : Also, plugs can test well but the internal resistance can bugger things : up. I've read that 5k ohms or over may be excessive. The spark will find : easier places to go than across the electrodes. : good luck As I said in my initial message, muffler baffles checked and fine. I have overhauled the mufflers this year due to cracks in the end plates, but the baffles were fine when they were removed. As far as the plugs, we replaced them about a year ago. Had the intermittent failures with the old plugs, new plugs, and mag drops were fine in all cases. Doesn't seem to be ignition-related. One more thing: Lycomings, especially those built or rebuilt before 1998, have a habit of wearing their exhaust valve guides enough that the valve can start seating off center and leaking. Normally this will show up as an exhaust leak on a differential compression test, but sometimes not until the wear is pretty bad. As the valve strikes the seat off-center, it hangs there briefly before closing and some of the compression is lost. See http://www.lycoming.com/support/publ...dfs/SB388C.pdf Dan |
On Sep 25, 6:34 pm, wrote:
wrote: : How old are your sparkplugs? We've had a lot of trouble over the : years with Champions, and used to buy the Auburns before Champion : bought them up and shut them down. They were an excellent plug and : almost always eroded to limits before the internal resistor failed. : With Champs, we've had the internal resistor misfiring at 50 hours. : One didn't work right out of the box. The Unison plugs are no better. : A poorly-firing plug will cause a slight RPM drop. They need : to be tested under pressure to see that they continue to fire up to at : least 120 psi. It's done the intermittent thing with new plugs, as well as freshly gapped and cleaned. Besides, if a plug wasn't firing, the mag drop would show it (it doesn't... runs smoothly on each mag by itself). Nice thought though. We've already done all the easy and normal stuff.... ![]() -Cory The plugs will fire during the runup, one mag at a time, but during flight when both mags are firing, there may be one or two that don't. Engines that have both mags timed at the same point BTDC need to be set as accurately as possible so that both plugs fire at the same time or very close. If one fires well before the other, the cylinder pressures may rise to a point that the other plug, being a little weak, can't fire and now we get a bit of roughness and loss of power. There are a few engines that specify a significant difference in their mag timing. I don't know how they handle spark blowout with that setup. Some of them were pretty old models that used resistorless plugs; perhaps they didn't suffer the same way that plugs with resistors do. Dan |
I changed out one cylinder where the dry lash was out of spec even
with oversized pushrods. I had to find a newer rocker arm that had more metal on the valve end. |
: Nice thought though. We've already done all the easy and normal stuff....
![]() : : -Cory : : The plugs will fire during the runup, one mag at a time, but : during flight when both mags are firing, there may be one or two that : don't. Engines that have both mags timed at the same point BTDC need : to be set as accurately as possible so that both plugs fire at the : same time or very close. If one fires well before the other, the : cylinder pressures may rise to a point that the other plug, being a : little weak, can't fire and now we get a bit of roughness and loss of : power. : There are a few engines that specify a significant difference : in their mag timing. I don't know how they handle spark blowout with : that setup. Some of them were pretty old models that used resistorless : plugs; perhaps they didn't suffer the same way that plugs with : resistors do. Interesting thought. I'm still skeptical that could be it, though. I've timed the mags a few different times over the course of the year or so it's occasionally happened. I'm pretty anal about getting them dead-nuts on each other and exactly at 25 degrees. I don't want them advanced at all since I run autogas, but don't want to detune them either. Also, I've done the mag drop in flight when I suspected that it was happening. Everything was fine... power smoothly decreased as expected. The "blow-out" thing could still be doing it, but I wouldn't think it would only do it for the first 60 seconds of flight occasionally. It should be more consistent or reproducable with higher MP (lower altitude takeoffs), etc. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
On Oct 9, 9:50 am, wrote:
Interesting thought. I'm still skeptical that could be it, though. I've timed the mags a few different times over the course of the year or so it's occasionally happened. I'm pretty anal about getting them dead-nuts on each other and exactly at 25 degrees. I don't want them advanced at all since I run autogas, but don't want to detune them either. Also, I've done the mag drop in flight when I suspected that it was happening. Everything was fine... power smoothly decreased as expected. The "blow-out" thing could still be doing it, but I wouldn't think it would only do it for the first 60 seconds of flight occasionally. It should be more consistent or reproducable with higher MP (lower altitude takeoffs), etc. Another idea. We had a Cessna 150 that used to lose some power on takeoff, sometimes shuddered while doing it, and after a lot of messing around we found that the valve stem/guide clearance was too small. This was a problem is the smaller Continentals and when the rebuilders did those engines they had to be careful not to get the guides too tight. Lycomings tend to wear their guides bigger, so the clearances get worse, but a few have had sticking valves caused by carbon buildup on the exhaust valve stems. The sticking would usually cause a power loss with vibration, and if they stuck bad enough the pushrod would bend, and bend the rod tube like so: http://www.prime-mover.org/Engines/L...r/bentpush.jpg You said you'd done the wobble test and the guides were worn but within limits. None were tight, huh? The 150's sticking valves were the intakes, not the exhausts, and the Lycoming wobble check applies only to the exhaust valves. Dan |
Ball Valve,Needle Valve,Snubber,Gauge Cock Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:32 AM |
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:25 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
sticky valve or | Dick | Home Built | 18 | May 25th 05 07:50 PM |
sticky valve or | Dick | Owning | 18 | May 25th 05 07:50 PM |
