Seaplane Resurgence?
Old September 30th 07, 01:40 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Mark Test
Default Seaplane Resurgence?
"Rob Arndt" wrote in message
On Sep 29, 5:02?pm, wrote:
In addition to the C-130 Seaplane project:
http://www.aviationweek.com/aw/blogs...plckController...
It looks like other seaplane ideas are being studied as well:
http://cisd.dt.navy.mil/div/cisd/fil...anes%20wo%20an...
Japan and the (Former) USSR never really gave up on seaplanes, but
will they now make a comeback in the US?
No- we have plenty of a/c carriers which Japan and the FSU/Russia
lack...
Seaplanes perform strike missions? (That's what CVN's do)
Posted via a free Usenet account from http://www.teranews.com
Old September 30th 07, 01:51 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Rob Arndt[_2_]
lack...
Posted via a free Usenet account fromhttp://www.teranews.com- Hide quoted text -
- Show quoted text -
Yes, AFAIK, that IS what the plan has been for years with new seaplane
projects apart from pure transports- arm them with Harpoons and
torpedos and other ordnance.
Also, military seaplanes can perform recon, sea rescue (on a carrier
performed by a helo), ASW, etc... all of which carrier-based aviation
does better.
The Soviet-era Ekranoplans were comparable to seaplanes as well and
carried a range of missiles.
Rob
Old September 30th 07, 02:04 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eeyore[_2_]
Not at all similar.
The Ekranoplans flew only in ground effect.
Graham
Old September 30th 07, 02:42 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Rob Arndt[_2_]
On Sep 29, 6:04?pm, Eeyore
Not at all similar.
Graham
A technicality at best.
Ekranoplans are planes and are sea-based, so they are only a DIFFERENT
type of seaplane.
You can't call them flying ships- they are WIG aviation.
Rob
Old September 30th 07, 02:52 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Dan[_2_]
Not at all similar.
Graham
type of seaplane.
Rob
Oh, please, seaplanes can fly overland, fly at altitude, don't have
to go around islands, can fly over rough seas and a few other things
WIGs can't do. Even you should be able to see that, xenia.
Dan, U.S. Air Force, retired
Old September 30th 07, 03:31 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Rob Arndt[_2_]
On Sep 29, 6:52 pm, Dan wrote:
Not at all similar.
Graham
type of seaplane.
Rob
Dan, U.S. Air Force, retired- Hide quoted text -
So how would you define an Ekronoplan? Seacraft? It is piloted and
flies. I believe ti has a/c controls as well...
Here is a dated article from New Scientist and their description, used
as an example:
Spacecraft may one day take off from the backs of seaplanes travelling
at half the speed of sound. That's the future of space travel if
Russian and Japanese scientists get their way, according to the
journal New Scientist.
Here's their plan. A spaceplane is placed on the back of a 1500-tonne,
rocket-propelled seaplane, or what Russians call an "ekranoplan". The
seaplane skims the water on a high-pressure cushion of air. When the
ekranoplan reaches speeds of more than 600 km/h, the spaceplane's
rockets fire and the two crafts separate. The spaceplane continues to
fly until it reaches its escape velocity of around 966 km/h.
Researchers believe this technology could be at par with the
traditional vertical take-off system such as the space shuttle.
Alexander Nebylov, director of the International Institute for
Advanced Aerospace Technology in St. Petersburg, says the high initial
launch speed gives this system an advantage over a conventional take-
off.
To land, Nebylov says the spaceplane will dock with a moving
ekranoplan when it returns to Earth.
Nebylov points out that the craft can be launched from any point in
the ocean - and that's important in achieving orbit. Scientists prefer
to launch as near as they can to the equator since the Earth's extra
rotational velocity in that area helps a spacecraft get into orbit.
Nebylov and Nobuyuki Tomita of the Musashi Institute of Technology in
Tokyo plan to conduct initial sea trials next year with a scaled-down
ekranoplan weighing 400-tonnes.
Rob
Old September 30th 07, 03:36 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Dan[_2_]
Not at all similar.
Graham
type of seaplane.
Rob
How about a separate category of WIG, xenia? Using your "logic" a
hovercraft is a helicopter.
Old September 30th 07, 05:35 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Richard Casady
On Sat, 29 Sep 2007 19:31:04 -0700, Rob Arndt
..Flying machines don't have an escape velocity. Planets or
stars have one, but not aircraft. We are talking about escaping
_something_, but what? what does the number relate to? For the earth
escape velocity is 7 miles per second, or a bit more than 40 000
km/h.
Casady
Old September 30th 07, 02:51 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eeyore[_2_]
as an example:
Just goes to show how little real science makes it's way into New Scientist
these days.
How many 'free energy' articles did they have in that issue ?
Graham
Old September 30th 07, 03:03 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
On Sep 29, 9:52 pm, Dan wrote:
Not at all similar.
Graham
type of seaplane.
Rob
Here's a display of what it says is the latest on the Ekranoplans.
Since I was the guy who named them I consider the idea to be mine. I
would guess somewhere in the Russian realm or working a deli in
Brooklyn is someone who could explain why the Sovs chose the Caspian
for basing this bugger. No way out, no use except thrill rides,
pictures and exciting Western intelligence people.
Seaplane Base 1 - Leaving the Seaplane Base-2.jpg (1/1) john smith[_2_] Aviation Photos 2 August 2nd 07 08:37 AM
seaplane takeoff Lets Fly Owning 1 December 5th 05 10:18 PM
seaplane motoglider? John Ammeter Home Built 23 September 19th 05 04:11 AM
ultralight seaplane Friedrich Ostertag Piloting 13 September 16th 05 03:37 AM
Seaplane Rating Add-On and Seaplane Rental Peter Bauer Piloting 10 May 29th 05 11:53 AM
