In a previous article, "Crash Lander" said:
common sense or instinct to me. Maybe when you're faced with an engine failure, common sense can sometimes go out the window in the panic. That's why as a student pilot you're drilled on the emergency checklist until you know it without thinking. I don't know about the plane you fly, but on mine it's 1. FLY THE PLANE 2. Pick a landing spot 3. FLY THE PLANE 4. Everything forward (throttle, prop, mixture) 5. FLY THE PLANE 6. Everything up (flaps, gear) 7. FLY THE PLANE 8. Fuel pump on. Switch tanks. 9. FLY THE PLANE 10. Carb heat or alternate air 11. FLY THE PLANE 12. Make emergency radio calls 13. FLY THE PLANE 14. Prepare to land. -- Paul Tomblin http://blog.xcski.com/ God is real, unless declared as an integer. |
On Tue, 2 Oct 2007 01:03:37 +0000 (UTC), Paul Tomblin wrote:
9. FLY THE PLANE 10. Carb heat or alternate air I see some logic to moving carb heat to number one on engine outs with the thought that if it was carb ice, you don't want to give the exhaust manifolds a chance to cool down and you want to give carb heat all the time you can to melt any accumulations. Make any sense? -- Dallas |
In a previous article, said:
On Tue, 2 Oct 2007 01:03:37 +0000 (UTC), Paul Tomblin wrote: 9. FLY THE PLANE 10. Carb heat or alternate air I see some logic to moving carb heat to number one on engine outs with the thought that if it was carb ice, you don't want to give the exhaust manifolds a chance to cool down and you want to give carb heat all the time you can to melt any accumulations. Make any sense? Yes, I think you're right. The checklist was taught to me as a left to right flow across the panel, but the one time I lost power on take-off in the winter, I actually did the carb heat immediately and it worked. -- Paul Tomblin http://blog.xcski.com/ Three of your friends throw up after eating chicken salad. Do you think "I should find more robust friends" or "we should check that refrigerator"? -- Donald Becker, on vortex-bug, suspecting a network-wide problem |
Scared of mid-airs | Frode Berg | Piloting | 355 | August 20th 06 05:27 PM |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
