Backwash Causes Lift?
Old October 3rd 07, 04:38 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Backwash Causes Lift?
Tina wrote in news:1191417912.483823.271490
@g4g2000hsf.googlegroups.com:
Then there's the Mx medical advice column, physics advice -- I'm
waiting for a unified field theory, or maybe a proposed standard of
care for depression.
I had a thought for what would be the longest thread ever in this
newsgroup -- "The collected corrections of Mx statements". Bertie
could be its editor, he has a deft and gentle way of pointing out
errors.
He's an idiot, what else does one need to know?
Bertie
Old October 3rd 07, 04:37 PM posted to rec.aviation.piloting
Dudley Henriques wrote in
Bertie the Bunyip wrote:
Dudley Henriques wrote in newsaednT-q-
Le Chaud Lapin wrote:
Hi,
Student pilot here, self-teaching using the Jeppensen Private Pilot
Kit after taking ground school.
I read in the book that combustion "creates" energy, which is
technically not true, but I decided to ignore it since the pictures
are sooo pretty.
Now, in Chapter 3, section about airfoils, it actually says:
"In addition to the lowered pressure, a downward-backward flow of
air
also is generated from the top surface of the wing. The reaction to
this downwash results in an upward force on the wing which
demnstrates
Newtons' third law of motion. This action/reaction principle also
is
apparent as the airstream strikes the lwoer surface of the wing
when
inclinded at a small angle (the angle of attack) to its direction
of
motion. The air is forced downward and therefore causes an upward
reaction resulting in positive lift."
IMHO, the latter part of this paragraph is correct, but the former
part is wrong.
Obviously, any air above the wing can only result in a force
downward
on top of the wing. The only force causing the plane to want to
move
upward comes from beneath the wing. The effect of any air above
wing is to cause rarefication above the wing, resulting in lower
pressure, thereby giving the 14.7lbs/in^2 (plus) to do its work.
That
"reaction" coming from downward movement of air seems just plain
silly
to me.
I am also inclined to take issue with the explanations of
Bernouilli's
Principle which I see often in the literature, but that's a
different
subject. [Note, I don't doubt Bernouilli's Principle, I just think
there is more to it than the way it is being described in context
of
flying.]
-Le Chaud Lapin-
Please don't take this the wrong way but I'm sure you would have
passed
me up as a potential flight instructor.
I nominate Anthony!
Bertie
Nah.....Anthony has offered many times to teach me about aerodynamics
and flying but so far at least I've cleverly managed to avoid that
enlightening experience.
Be a bit like letting a jackhammer operator do your teeth, that.
Bertie
Old October 3rd 07, 04:33 AM posted to rec.aviation.piloting
george
On Oct 3, 1:57 pm, Le Chaud Lapin wrote:
"In addition to the lowered pressure, a downward-backward flow of air
this downwash results in an upward force on the wing which demnstrates
Newtons' third law of motion. This action/reaction principle also is
apparent as the airstream strikes the lwoer surface of the wing when
inclinded at a small angle (the angle of attack) to its direction of
I blame the lift pixies myself
Old October 3rd 07, 05:23 AM posted to rec.aviation.piloting
Le Chaud Lapin
LOL.
This flying business is a bit too fascinating. I'm having trouble
concentrating on my day job. In no other hobby has the opportunity
arisen to apply essentially everything technical I have ever learned.
Physics, chemistry, mathematics, electronics, computation...it's all
there.
-Le Chaud Lapin-
Old October 3rd 07, 09:43 PM posted to rec.aviation.piloting
Just go look it up!
I thought it was how the airflow goes through the splaps?
Old October 3rd 07, 05:54 AM posted to rec.aviation.piloting
Mxsmanic
Le Chaud Lapin writes:
Obviously, any air above the wing can only result in a force downward
on top of the wing. The only force causing the plane to want to move
upward comes from beneath the wing. The effect of any air above the
pressure, thereby giving the 14.7lbs/in^2 (plus) to do its work. That
"reaction" coming from downward movement of air seems just plain silly
to me.
Lift is a reaction to the force required to push air downward behind the wing
(downwash). How the air gets pushed downward is not very important. The wing
twists air into a downwash as it passes through it, leaving a swath of air
moving gently downward behind it. The force required to do this engenders an
equal and opposite force that is lift. Lift accelerates the wing upward,
counteracting gravity. The wing accelerates a large mass of air downward.
I am also inclined to take issue with the explanations of Bernouilli's
Principle which I see often in the literature, but that's a different
there is more to it than the way it is being described in context of
flying.]
There are a lot of different ways to examine and describe the aerodynamics of
lift. It boils down to accelerating one mass (a mass of air) downward, which
engenders another acceleration of another mass (the wing, and anything to
which it is attached) upward. Any flat surface moving relative to the air
with a positive angle of attack below the stall angle will generate lift.
Old October 3rd 07, 07:38 AM posted to rec.aviation.piloting
Mxsmanic wrote in
silly to me.
the wing (downwash). How the air gets pushed downward is not very
important. The wing twists air into a downwash as it passes through
it, leaving a swath of air moving gently downward behind it. The
force required to do this engenders an equal and opposite force that
is lift. Lift accelerates the wing upward, counteracting gravity.
Bernouilli's Principle which I see often in the literature, but
that's a different subject. [Note, I don't doubt Bernouilli's
Principle, I just think there is more to it than the way it is being
described in context of flying.]
aerodynamics of lift. It boils down to accelerating one mass (a mass
of air) downward, which engenders another acceleration of another mass
(the wing, and anything to which it is attached) upward. Any flat
surface moving relative to the air with a positive angle of attack
Nope.
Bertie
Old October 3rd 07, 09:50 AM posted to rec.aviation.piloting
Tina
It is clearly time to revisit airplanes taking off on tredmills.
Old October 3rd 07, 09:59 AM posted to rec.aviation.piloting
Tina wrote in news:1191401433.827965.190080
@o80g2000hse.googlegroups.com:
Do tell. Must have been before my time here.
Bertie
Old October 3rd 07, 10:31 PM posted to rec.aviation.piloting
Morgans[_2_]
I have to agree. ANYTHING would be better than hearing the resident idiot
troll's blithering.
It goes something like this.
An airplane is about to takeoff on a runway, that is really a treadmill; a
very expensive treadmill.
The treadmill senses the airplane's speed, and matches the aircraft's speed,
with speed increases of its own.
Can the airplane takeoff? Why or why not?
Jim in NC
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
