what the heck is lift?
Old September 9th 05, 04:56 AM
buttman
Default what the heck is lift?
I have always been under the impression that lift is the product of
airspeed and angle of attack, and that lift is the measure of upward
force acting on the plane at a given time. For instance, if you are
doing slow flight, your wings are producing the same amount of life
that you would be if you were cruising, GIVEN that you did not lose or
gain any altitude during the maneuver.
My instructor, which is a very knowledgable guy tried telling me that
lift has nothing to do with airspeed. He said that lift is directly and
soley related to AOA and AOA only. So if you are doing slow flight, you
are producing more life than you are when you're cruising. I overheard
a ATP guy who flies King Air's say that this huge 20 ton military plane
he used to fly would fly approaches at 110 knots, and I heard him say
"It is able to do this because it producing so much lift", which I took
as him defining lift as my instructor does.
So whats the deal here? Are we just thinking of two diffrent concepts?
Old September 9th 05, 05:32 AM
Peter Duniho
"buttman" wrote in message
Your instructor is wrong, and should not be instructing.
In straight and level flight, lift equals weight. Unless your weight
changes, lift does not change, regardless of airspeed. What *can* change is
the lift coefficient, which is determined by the angle of attack. But lift
itself remains static.
Pete
Old September 9th 05, 12:12 PM
Roger Long
Lift in a fully developed spin or steady sinking mush is also exactly
the same as in level flight.
Roger Long
Old September 9th 05, 02:37 PM
Jimbob
On Fri, 09 Sep 2005 11:12:36 GMT, "Roger Long"
Hmm. If lift was equal to weight in level flight the forces are
equal, thus no change in height.
How do you reconcile this with a mush or spin? Height is changing,
thus left is less than weight.
http://www.unconventional-wisdom.org
Old September 9th 05, 04:41 PM
Hilton
Not even close!
Hilton
Old September 9th 05, 06:51 PM
Peter Duniho
"Hilton" wrote in message
. net...
Not even close!
He's quite close. See Todd' post.
I wrote "straight and level flight" simply because that was the scenario
being discussed in the original post. But any unaccelerated flight means
lift equals weight, and that includes the "fully developed spin" and "steady
sinking mush" Roger described.
Pete
Old September 9th 05, 07:30 PM
Larry Dighera
On Fri, 9 Sep 2005 10:51:23 -0700, "Peter Duniho"
wrote in
sinking mush"
Isn't there acceleration in a sinking mush? If the aircraft is
descending, does lift equal weight?
Old September 9th 05, 07:36 PM
Hilton
Peter wrote:
Not even close!
"steady
Todd's reply to this clearly shows why Roger's statement is wrong. A large
percentage of the upward force in a spin is drag. The extreme case is a
parachutist coming straight down in one of those old round parachutes. In
this case, the 'aircraft' has zero lift and DRAG == WEIGHT.
Lift, drag, and thrust can be pointed in any direction; the only constant is
weight which always points towards the center of the earth.
Hilton
Old September 9th 05, 08:16 PM
Stefan
It depends on how you define "lift". If every upward pointing force is
lift, you're correct. If however you make a difference between, hmmm,
let's call it "true" lift created by the airfoil and drag that's just
incidentally pointing upwards, then you're not.
Stefan
Old September 9th 05, 07:04 PM
George Patterson
Not according to the Jepp Private Pilot's Manual.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 10:50 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
