Backwash Causes Lift?
Old October 4th 07, 05:01 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default Backwash Causes Lift?
On Oct 4, 6:27 am, Mxsmanic wrote:
TheSmokingGnu writes:
Then why do wings generate lift at negative AOA?
They don't. That's a very common misconception, even among pilots.
The effective AOA is always positive when the wing is generating lift.
Once again, thou knowest not of what thou speakest. I
just told you, in apost not long ago, that some airfoils will generate
lift at up to -4° AOA. Here's a graph that shows lift being generated
on some anonymous airfoil at -5°:
http://en.wikipedia.org/wiki/Lift_coefficient
Bernoulli at work. Newton, too, because there's downwash being
generated.
Dan
Don't bother. Believe me it's not worth it. You can talk this guy to
death and all he will do is count you as another response.
Angle of attack as we all know (with one exception it seems :-) can be
both positive or negative.
In fact, in high performance jets with a fuselage loaded IYMP, entering
a coupled spin after a departure, it's extremely disorienting if the
aircraft goes through PSG and stabilizes in an inverted spin mode where
yaw is opposite to roll. g is a bad indicator as with a fuselage loaded
IYMP you can get negative g either erect or inverted.
The way we deal with this is through instrument interpretation rather
than trying to eyeball what's happening, which can be next to impossible.
The AOA indicator in the aircraft has a positive and negative side. If
the AOA is stabilized at some value on the negative side, and the
airspeed is stabilized at some mean low value, the spin is inverted. The
turn needle will show spin direction either way.
Again, don't waste your time.
Dudley Henriques
Old October 4th 07, 05:10 PM posted to rec.aviation.piloting
Tina
Mr Dudley, once again you are confused. Most define angle of attack as
the chord line of a wing, and of course with that definition it can be
negative and still generate lift. Mr Mx chooses a different way of
defining it. It is some angle such that when it goes negative the
airfoil can generate no lift. Do you remember the disbarred former
president Clinton saying something about "It depends on what 'is'
means"?
In Mx's case, words change meaning so that he is NEVER wrong. It must
be an interesting version of English he teaches.
But he does offer amusement for some of us on otherwise humorless
days, doesn't he?
Old October 4th 07, 05:23 PM posted to rec.aviation.piloting
means"?
days, doesn't he?
AOA actually can be defined relative to any given reference datum, but
normally it's considered in the industry as being the angle formed
between the chord line of the wing and the relative wind as you have
correctly stated.
Quite frankly, I read what Mxemanic writes on occasion and can't figure
out how he can be so close to getting it right and still manage to get
it wrong. He's amazing, and an interesting study if nothing else.
It's too bad he's taken this path on these groups. I've always felt he
has a genuine interest in things aviation and would like to contribute,
but he seems to be such a jerk that he gets in his own way.
Dudley Henriques
Old October 4th 07, 01:26 PM posted to rec.aviation.piloting
Mxsmanic
Le Chaud Lapin writes:
Yes, I am. It's a combination of many things taking place at once.
Vacuum generation by the forward motion of the wing is one of them.
Gravity does that, not the forward motion of the wing. Without gravity, the
wing would simply move upwards until the effective angle of attack were no
longer positive.
Old October 5th 07, 12:53 AM posted to rec.aviation.piloting
Bertie the Bunyip
longer positive.
Good grief.
Bertie
Old October 5th 07, 12:54 AM posted to rec.aviation.piloting
Bertie the Bunyip
Le Chaud Lapin wrote:
On Oct 3, 9:26 pm, TheSmokingGnu
You can have lift of an object with no Bernoulli. It's simple vector
addition.
1. You are talking about nature's abhorrence of a vacuum.
2. Vacuum abhorrence is not lift.
3. Airplanes do not generate lift as a result of vacuum abhorrence.
Conclusion: you are not talking about how aircraft generate lift.
Enjoying yourself there Anthony_
i know I am!
Bwaahwahwhahwhahwhahwhahwhahwhahwhha!
Bertie
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
