On Wed, 08 Oct 2003 22:38:27 +0100, Greg Hennessy
wrote: On Wed, 08 Oct 2003 18:31:41 GMT, Ed Rasimus wrote: The real strength of the A-7D was the endurance. While it couldn't go quite as fast as AF types would have preferred, it carried a significant load for a long time. The true significance was demonstrated during Linebacker when they A-7Ds of the 354th TFW out of Korat would takeoff and fly unrefueled to Route Pack V or VI and return. Interesting, obviously something with equivalent legs which can fly 100+kts quicker to/over/from the target is going to be more than just a minor improvement. One is talking about serious potential in two seat variants for wild weasel etc. While the endurance and range were impressive, the energy available was not. As I indicated below, the survivability in an intense SAM environment was questionable. In fact, in short order during Linebacker II, the A-7s were withheld from "downtown" targets out in the flats of RP VI and used as bomb droppers on "diversionary" targets in RP V and on the western edge of VI. They did get downtown initially, but after the first couple of SAM experiences, they didn't get back to the area. They wouldn't have made a good Weasel. The endurance and range, along with the ordinance carrying capability did, however make them an excellent SAR airplane. They assumed the Sandy mission for North Vietnam strikes very soon after arrival in theater. That didn't take a two seat airplane when the A-1 did it and didn't require two seats with an A-7 either. At issue (from an AF point of view, but not apparently from the USN operator's perspective) was the ability to recover energy quickly when placed on the defensive. A SAM break that took you down to very low altitude, usually with high-G, would squander both kinetic and potential energy. With AB you could regain both fairly rapidly. Without AB you were in a precarious situation. The extra thrust of a more efficient engine might have improved that aspect of A-7 ops. Its an interesting consideration of the road not travelled. Another would be thinking about if the AF had procured single seat F16-Es 1 for 1 instead of 'C's during the 80s. They would have made an interesting compliment to the attack options available during Desert storm and elsewhere. You're unclear here. I assume you mean TWO seat F-16Es instead of Cs? If, I again assume, that would mean a parallel development to the F-15E? Clearly without knowing something about what sort of weapons delivery improvement an F-16E would have over a C, it's difficult to say much. The CCIP delivery of dumb bombs by the F-16 A or C was always exceptional--that's what was used on Isirik I believe. The LANTIRN package for C models makes the airplane pretty good all-wx. And the SEAD capability is acceptable for the C. Are you maybe referring to the crank-wing F-16XL? There you would have gotten more fuel in the big wing for more endurance and more lift capacity. Still, there's little to have recommended going that way rather than the considerably better performance and growth capacity of the F-15E. It seems as though they ran out of targets during Desert Storm long before they ran out of attack options. greg |
before they ran out of attack options. F-4Gs ended up doing some strike missions, since they were running out of SEAD targets to go after. NMANG A-7s came close to being sent over there to the gulf in late 90 Ron Pilot/Wildland Firefighter |
On Wed, 08 Oct 2003 23:45:32 GMT, Ed Rasimus wrote:
They did get downtown initially, but after the first couple of SAM experiences, they didn't get back to the area. They wouldn't have made a good Weasel. Even with a F100/F110 ? I assume given it size it would also be down to a lack of internal space to put all the electronic gear etc ? The endurance and range, along with the ordinance carrying capability did, however make them an excellent SAR airplane. They assumed the Sandy mission for North Vietnam strikes very soon after arrival in theater. That didn't take a two seat airplane when the A-1 did it and didn't require two seats with an A-7 either. True. You're unclear here. I assume you mean TWO seat F-16Es instead of Cs? If, I again assume, that would mean a parallel development to the F-15E? I meant the XL as you refer to below. Clearly without knowing something about what sort of weapons delivery improvement an F-16E would have over a C, it's difficult to say much. The CCIP delivery of dumb bombs by the F-16 A or C was always exceptional--that's what was used on Isirik I believe. I remember you mentioning this before. Are you maybe referring to the crank-wing F-16XL? There you would have gotten more fuel in the big wing for more endurance and more lift capacity. It was that side of the equation I was thinking about, I believe the advertising went something along the lines of, carry the same load twice the distance when compared to the standard model. greg -- $ReplyAddress =~ s#\@.*$##; # Delete everything after the '@' The Following is a true story..... Only the names have been changed to protect the guilty. |
GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 04:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
