Why Airplanes Fly - Voids Above A Planar Sheet
Old October 4th 07, 11:20 PM posted to rec.aviation.piloting
Gatt
Default Why Airplanes Fly - Voids Above A Planar Sheet
"Le Chaud Lapin" wrote in message
On Oct 4, 4:46 pm, "Gatt" wrote:
expects everybody to do
experiments just to indulge your accusation that basically everything
they
know about aerodynamics is wrong.
Not true. I do not recall any "accusation that basically everything
they know about aerodynamics is wrong." I wrote that there are some
things in the Jeppensen book that are just plain wrong, as is the
explanation of action/reaction with regard to downwash.
Oh, nevermind, everybody. It's the same guy with a new handle. It's
Jeppesen, and, do you have any idea how many people are successfully flying
with what they learned from the Jeppesen books? Are you one of them?
What has IT got to do with a war? My writings were very specific,
involving aerodynamics.
What I'm saying is, until you prove your aerodynamics with something more
than two sheets of paper, nobody gives a damn. Here's a hint: We don't fly
sheets of paper or plywood. If you think it can be done, all you have to do
is build an airplane and demonstrate it.
I did. The answer was "yes, the book is right, and you are wrong."
Accept it and move on. Don't just change your handle and try again.
-c
Old October 5th 07, 12:02 AM posted to rec.aviation.piloting
Le Chaud Lapin
On Oct 4, 5:20 pm, "Gatt" wrote:
"Le Chaud Lapin" wrote in ooglegroups.com...
My handle has been the same for over a decade.
Not yet. I will continue to study my Jeppesen book. That does not
mean that I will blindly accept everything I read.
And I will do as I please, thanks.
-Le Chaud Lapin-
Old October 5th 07, 06:16 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Le Chaud Lapin wrote in
ups.com:
ooglegroups.com...
It's
flying with what they learned from the Jeppesen books? Are you one
of them?
Wel, if you do ever leave your bedroom and take a flying lesson that will
turn out to be some CO2 pumped into the atmosphere for nothing.
At least your instructor will make enough to supersize off you.
Bertie
FAA advisory voids IFR certification for GPS's!!! Prime Owning 12 May 29th 07 01:43 AM
Brass or copper sheet? Scott Home Built 11 October 15th 06 02:20 AM
4130 sheet log Home Built 4 September 1st 04 01:42 AM
Day 2 New Castle Score Sheet Guy Byars Soaring 3 September 25th 03 02:39 AM
S-H Spars: Anyone check for voids laterally? Mark Grubb Soaring 1 September 20th 03 04:27 AM
