#11
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message ... Frankly, on a C-172 I can't think of any reason either. http://www.caa.is/datadir/bsdata/img...s/72-07-02.pdf Karl |
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message ... On the C-402 for example, you had to burn a good 30 minutes on the outboards (which were its mains) before you could switch to the inboards. When you switched to the inboards, the fuel actually went from the inboards to the outboards to the engine. If you didn't make room first by burning the outboards first, the fuel pumped from the inboards would just be pushed through the overflow valves on the outboard tanks and then you get to sprinkle the landscape with expensive avgas. You got that partially right. The aux tanks each have their own electric fuel pump that pushes the fuel throught the selector valve and on to the engine driven fuel pump. Excess fuel from the engine driven fuel pump is routed back to the main (tip) tanks. The reason for running on the tip tanks first for 60 (or 90 for the large aux tanks) minutes is to make room for this bypass fuel. -- *H. Allen Smith* WACO - We are all here, because we are not all there. |
On Oct 6, 12:47 am, es330td wrote:
Sorry if this is dumb (I am only at 8.3 hours toward my PPL)... In the email I got from AOPA ePilot training tips today there is a discussion of fuel starvation that makes regular mention of the fuel selector switch. All my flying is done in a CE172 and the first and last time I worry about the switch is during pre-flight when I confirm that it is on both. I fly on both and never fly any other way and to be honest, outside of gravity flow issues when parked on an incline I cannot think of why one would want to select one tank at a time vs both. If you ever get to a situation where you are worried about fuel, you switch to one tank and start your watch, when that tank runs dry (engine splutters) you will have a very good idea of how much flying time you have left. This knowlege will enable you to decide if your chosen alternate airfield is in reach or if you neeed to start your precautionary landing procedures (looking for a paddock etc.) Cheers |
On Oct 6, 4:25 am, "karl gruber" wrote:
On many Cessna 172s you are REQUIRED to run on either left or right (not both) above 5000' Karlhttp://www.caa.is/datadir/bsdata/img/adnotes/72-07-02.pdf Many cessna 172's? How many were not modified -I've not seen the required placard... Cheers |
Some times after some maneuvers.. or continuous pattern work with not that
great coordination.. you may find one tank (wing) heavier than the other because the fuel is unbalanced. select the heavier (fuller) tank for a few minutes and monitor to rebalance, then back to "both". Of course.. training to select one tank or the other for single tank operations, prepares one for flying other aircraft. BT "es330td" wrote in message ups.com... On Oct 5, 9:03 am, wrote: On Oct 5, 2:47 pm, es330td wrote: Sorry if this is dumb (I am only at 8.3 hours toward my PPL)... In the email I got from AOPA ePilot training tips today there is a discussion of fuel starvation that makes regular mention of the fuel selector switch. All my flying is done in a CE172 and the first and last time I worry about the switch is during pre-flight when I confirm that it is on both. I fly on both and never fly any other way and to be honest, outside of gravity flow issues when parked on an incline I cannot think of why one would want to select one tank at a time vs both. The POH will answer that. -Kees I bought one two days ago. I should finish reading it this weekend. Thanks. |
On Oct 5, 7:47 am, es330td wrote:
Sorry if this is dumb (I am only at 8.3 hours toward my PPL)... In the email I got from AOPA ePilot training tips today there is a discussion of fuel starvation that makes regular mention of the fuel selector switch. All my flying is done in a CE172 and the first and last time I worry about the switch is during pre-flight when I confirm that it is on both. I fly on both and never fly any other way and to be honest, outside of gravity flow issues when parked on an incline I cannot think of why one would want to select one tank at a time vs both. If you are running on "BOTH" and there is an obstruction in a fuel line, fuel could feed only from the other tank and you might find yourself with fuel starvation long before you expect it. Changing between left and right on a regular basis may let you discover such a problem before it's an emergency. A close watch on fuel gauges and being sensitive to heavy wing helps too. -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because we fly, we envy no one. |
"Allen" wrote in message . .. "Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message ... On the C-402 for example, you had to burn a good 30 minutes on the outboards (which were its mains) before you could switch to the inboards. When you switched to the inboards, the fuel actually went from the inboards to the outboards to the engine. If you didn't make room first by burning the outboards first, the fuel pumped from the inboards would just be pushed through the overflow valves on the outboard tanks and then you get to sprinkle the landscape with expensive avgas. You got that partially right. The aux tanks each have their own electric fuel pump that pushes the fuel throught the selector valve and on to the engine driven fuel pump. Excess fuel from the engine driven fuel pump is routed back to the main (tip) tanks. The reason for running on the tip tanks first for 60 (or 90 for the large aux tanks) minutes is to make room for this bypass fuel. -- *H. Allen Smith* WACO - We are all here, because we are not all there. Correct for the AUX tanks. However, the optional locker tanks function just like Mortimer said. Al G |
On Oct 5, 12:09 pm, Gene Seibel wrote:
On Oct 5, 7:47 am, es330td wrote: If you are running on "BOTH" and there is an obstruction in a fuel line, fuel could feed only from the other tank and you might find yourself with fuel starvation long before you expect it. Changing between left and right on a regular basis may let you discover such a problem before it's an emergency. A close watch on fuel gauges and being sensitive to heavy wing helps too. My Mooney doesn't have a both. However, its nice to know that if I ever did run out of gas, I could always switch to the other tank and having something left. If you run out in a C-172 on "both" you're done. -Robert |
Allen wrote:
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message ... On the C-402 for example, you had to burn a good 30 minutes on the outboards (which were its mains) before you could switch to the inboards. When you switched to the inboards, the fuel actually went from the inboards to the outboards to the engine. If you didn't make room first by burning the outboards first, the fuel pumped from the inboards would just be pushed through the overflow valves on the outboard tanks and then you get to sprinkle the landscape with expensive avgas. You got that partially right. The aux tanks each have their own electric fuel pump that pushes the fuel throught the selector valve and on to the engine driven fuel pump. Excess fuel from the engine driven fuel pump is routed back to the main (tip) tanks. The reason for running on the tip tanks first for 60 (or 90 for the large aux tanks) minutes is to make room for this bypass fuel. Oops... it's been a while. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
| Thread Tools | |
| Display Modes | |
| Fuel line question | Lou | Home Built | 12 | October 9th 06 03:46 PM |
| Fuel selector or two check valves? | Rob Turk | Home Built | 13 | July 1st 05 01:21 AM |
| Fuel Question | Peterpan | Piloting | 5 | March 24th 05 04:49 AM |
| Fuel Selector Valve | Tom Cummings | Owning | 1 | March 7th 04 03:44 PM |
| Fuel Selector Valve | Jay | Home Built | 5 | November 16th 03 12:16 AM |
