![]() "Allen" wrote in message . .. "Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message ... On the C-402 for example, you had to burn a good 30 minutes on the outboards (which were its mains) before you could switch to the inboards. When you switched to the inboards, the fuel actually went from the inboards to the outboards to the engine. If you didn't make room first by burning the outboards first, the fuel pumped from the inboards would just be pushed through the overflow valves on the outboard tanks and then you get to sprinkle the landscape with expensive avgas. You got that partially right. The aux tanks each have their own electric fuel pump that pushes the fuel throught the selector valve and on to the engine driven fuel pump. Excess fuel from the engine driven fuel pump is routed back to the main (tip) tanks. The reason for running on the tip tanks first for 60 (or 90 for the large aux tanks) minutes is to make room for this bypass fuel. -- *H. Allen Smith* WACO - We are all here, because we are not all there. Correct for the AUX tanks. However, the optional locker tanks function just like Mortimer said. Al G |
Fuel line question | Lou | Home Built | 12 | October 9th 06 02:46 PM |
Fuel selector or two check valves? | Rob Turk | Home Built | 13 | July 1st 05 12:21 AM |
Fuel Question | Peterpan | Piloting | 5 | March 24th 05 03:49 AM |
Fuel Selector Valve | Tom Cummings | Owning | 1 | March 7th 04 02:44 PM |
Fuel Selector Valve | Jay | Home Built | 5 | November 15th 03 11:16 PM |
