Backwash Causes Lift?
Old October 6th 07, 01:10 PM posted to rec.aviation.piloting
Mxsmanic
Default Backwash Causes Lift?
Matt Whiting writes:
Really? Many books still can't agree on the definition of current.
Some say it is the movement of electrons and some say it is the movement
of positive charge and some say it us both. Which is the absolute
truth, Mr. Wizard?
The absolute truth is unknown, and the real proof of wizardry is the ability
to say "I don't know."
Old October 6th 07, 07:18 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
movement of positive charge and some say it us both. Which is the
absolute truth, Mr. Wizard?
ability to say "I don't know."
And the proof of your idiocy is that you can actualy say that with a
presumably straight face.
Old October 6th 07, 02:53 PM posted to rec.aviation.piloting
Tina
Matt, come on, you're better than that. You have to know what you're
talking about re current flow is simply accepting one convention or
another. In either case (using a plus or a minus sign consistantly
when writing loop equations for example) the calculations and
observations match fairly well.
The hand waving about lift is equally funny: people are attaching
names to various theories, but the reality is the physics used in the
analysis of lift work well enough to predict performance. The 'wise
fools' will wave their hands and argue, those knowing what they are
doing will design airplanes.
Old October 6th 07, 03:36 PM posted to rec.aviation.piloting
muff528
"Tina" wrote in message
ps.com...
BADA BING!
(I'm a southerner so spelling or usage may or may not be correct)
Old October 6th 07, 06:06 PM posted to rec.aviation.piloting
Le Chaud Lapin
This I definitely agree with. Even if aerodynamicists (is that even a
word) were so inept at physics that could not even calculate F=ma,
after so many iterations, they would still be able to make highly
refined airfoils simply because nature provides feedback to help one
distinguish between good designs and bad designs.
However, I must point out something I noted yesterday, that if you
have theory as well as the practice, the correct theory, there might
be opportunity to experience and entiely new realm of order and
efficiency.
I re-read the chapter on fluid mechanics in my physics book last night
and it says exactly what that NASA article refutes. Naturally, I was
bit perturbed - this physics book is same one used by some very good
universities. It also read in it a near verbatim explanation of
downwash as an example of Newton's law at work, that I found in the
Jeppesen book, the same explanation with is rigorously refuted by
NASA. I remember reading this chapter over and over a long time ago,
and "not getting it", and now I realize that it's because it is most
likely wrong.
In any case, there is something to be said for re-examining the
theory. There might be a bit of opportunity here.
I *think* I understand the physics behind reduced pressure above a
moving, appropriately shaped airfoil. *If* my suspicions are correct,
then it should be possible to make an entirely new type of aircraft,
where the mechanims to keep the aircraft flying are entirely different
from what they are today. I won't say too much now. I know no one
will consider it anyway. I'll just start fiddling, albeit slowly,
with my copy of SolidWorks that is coming in the mail soon.
I plan eventually to make a small-scale model. Hopefully, someday, I
might find someone involved in aerodynamics/flight to help make a
prototype.
-Le Chaud Lapin-
Old October 6th 07, 07:10 PM posted to rec.aviation.piloting
Le Chaud Lapin wrote in
oups.com:
efficiency.
likely wrong.
prototype.
-Le Chaud Lapin-
You're an idiot
Bertie
Old October 6th 07, 07:20 PM posted to rec.aviation.piloting
oups.com:
No you don't
prototype.
You couldn't make a succesful papaer dart.
Bertie
Old October 7th 07, 02:14 PM posted to rec.aviation.piloting
Allen[_1_]
"Le Chaud Lapin" wrote in message
efficiency.
likely wrong.
prototype.
-Le Chaud Lapin-
Dear Le DooD,
You have got some severe imagination going on here! You need to quit
playing with lift; that has already been invented. Anti-matter and
anti-gravity is where it is at. Use your force to leap into the next era of
travel. The wheel and wing are already here.
Beam me up Scotty,
*H. Allen Smith*
WACO - We are all here, because we are not all there.
Old October 6th 07, 06:30 PM posted to rec.aviation.piloting
Matt Whiting
I was simply making a point that there are different ways of looking at
the same thing. Much the same with lift and Bernoulli and Newton. Does
the difference in pressure between the top and bottom of the airfoil
cause the downward airflow behind the airfoil, or does the mechanical
deflection of the airflow cause the different in pressure between the
top and bottom of the wing? Inquiring minds want to know? :-)
Matt
Old October 6th 07, 07:19 PM posted to rec.aviation.piloting
Tina wrote in news:1191678837.514394.4670
@r29g2000hsg.googlegroups.com:
Yep
Bertie
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
