The Osprey Goes to War
Old October 5th 07, 08:39 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Vince
Default The Osprey Goes to War
Andrew Swallow wrote:
Vince wrote:
[snip]
The net result is that all of the "advantages" of the osprey only
occur at relatively long range. At short range it is inferior to a
modern helicopter in every possible way.
But the Cobra is not a long range aircraft It has a maximum payload
of about 3500 pounds of crew fuel and weapons. The more fuel loaded ,
the less armament
So how do you mix the two?
Vince
Some ideas.
1.Launch from different ships/airfields in different locations. Say
one north of the target and the other south of the target.
which one is the close one ?
2. Launch at different times. The Cobras in the first wave and the
Ospreys in the second wave. This also permits the ship to have a
smaller flight deck.
no surprise and you have to be short range
3. Replace the Cobras with a long range aircraft for the close in
escort role.
Which one? the F007 Magic Fairy Dust ?
4. Modify some of the Ospreys to carry guns rather than people. The
Ospreys can then escort the Ospreys. Appropriate guns and missiles
will have to be determined.
120 million plus a pop
Vince
Osprey 2 modifications Terry Mortimore Home Built 5 October 23rd 04 11:46 PM
Osprey icing tests Ed Majden Military Aviation 0 February 1st 04 08:43 PM
Amphib: Coot vs Osprey II Greg Milligan Home Built 9 December 29th 03 01:48 AM
Osprey tested in air, at sea Otis Willie Military Aviation 0 December 10th 03 12:30 AM
Osprey vs. Harrier Stephen D. Poe Military Aviation 58 August 18th 03 03:17 PM
