BlackBeard wrote:
On Oct 5, 12:50 pm, Typhoon502 wrote: SNIP How on earth is it a violation of laws of physics to launch Cobras at 0330 and Ospreys at 0430? And I still want to know what genius of planning would schedule the transports to arrive in the hot zone at the same time that the first armed aircraft are arriving. IIRC wasn't it SOP during WWII that fighter escorts would rendevous with long range bombers at some point during the mission. They left from different airfields, at different times, yet still often made the rendevous and stayed with the bombers as long as they could (prior to the long range escorts) and eventually throughout the flight while in hostile skies. With modern advancements in technology you would think if they could do it back then, they can do it better now. Coordinating your escort gunships to arrive at the LZ 10 minutes before the transports, from different (closer) airbases, or leaving from the same base earlier, isn't rocket science. Sure fighters rendezvoused with bombers.. (But exactly how accurate was the timing? Within minutes of schedule, at the appointed place on a map?) When the escorts joined with the bomber stream they throttled back to the speed of the transports so the missions could stay "together".. Of course the escorts, being faster could also fly loops etc giving better cover.. Now reverse the equation.. The escorts (helicopter gunships) rendezvous with the V-22s.. The V-22s slow down to the cruise sped of the helicopters... also altitude.. Which kind of defeats the justification for the V-22. The alternative is time on target.. gunships and transports arrive at the LZ at the same time.. which means the V-22s have to transit without any escort (Unless they get aircraft escorts?).. The Helicopters should arrive ahead of the V-22s to suppress the ground before the V-22s come in (The V-22 arriving first is contraindicated).. The big problem is.. Once the mission is launched.. If for any reason the LZ is moved... You have to contact all units to get them to (1) turn back for re planning, or (2) schedule arrival at the new LZ... Trying to schedule a new rendezvous once an operation has been launched ... Well.. I'm sure it would be an interesting exercise.. Lot's of ways things could go wrong... (If the two units -- transports and escort-- were flying together.. No such problem..) Do the V-22s circle at altitude until the LZ is considered safe? |
On Oct 5, 6:10 pm, Kerryn Offord wrote:
The alternative is time on target.. gunships and transports arrive at the LZ at the same time.. which means the V-22s have to transit without any escort (Unless they get aircraft escorts?).. I want to know just how busy these escorts are expected to be. The Helicopters should arrive ahead of the V-22s to suppress the ground before the V-22s come in (The V-22 arriving first is contraindicated).. Helos, Harriers, and Hornets, at the least. ANY troop carrier being fired upon during a landing sequence means quite a few somebodys have ****ed up severely. The big problem is.. Once the mission is launched.. If for any reason the LZ is moved... You have to contact all units to get them to (1) turn back for re planning, or (2) schedule arrival at the new LZ... Trying to schedule a new rendezvous once an operation has been launched .. Well.. I'm sure it would be an interesting exercise.. Lot's of ways things could go wrong... (If the two units -- transports and escort-- were flying together.. No such problem..) Do the V-22s circle at altitude until the LZ is considered safe? They can stay further from the LZ or hot zone because they can go further, faster when it's clear, which I'd think is an asset. |
Osprey 2 modifications | Terry Mortimore | Home Built | 5 | October 23rd 04 11:46 PM |
Osprey icing tests | Ed Majden | Military Aviation | 0 | February 1st 04 08:43 PM |
Amphib: Coot vs Osprey II | Greg Milligan | Home Built | 9 | December 29th 03 01:48 AM |
Osprey tested in air, at sea | Otis Willie | Military Aviation | 0 | December 10th 03 12:30 AM |
Osprey vs. Harrier | Stephen D. Poe | Military Aviation | 58 | August 18th 03 03:17 PM |
