On Oct 6, 9:21 am, Arno wrote:
Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno You'll get used to it... there is a transition time to go from round dial to tapes, but once you get used to tapes you will find that they do have certain advantages. I worked on the 777 EFIS, which used the tape format, and after several hours in the 777 simulator, the tapes became as easy to read at a glance as the round dials. It just takes conditioning your mind to be able to rapidly scan them, and being able to pick up trend information from the tape motion instead of needle motion. At least that was my experience. A lot of human factors work went into the tape formats, and it was with the understanding that training would be required for pilots to adapt to them. Dean |
On Oct 6, 12:56 pm, john smith wrote:
In article . com, wrote: A lot of human factors work went into the tape formats, and it was with the understanding that training would be required for pilots to adapt to them. So do the numbers get bigger or smaller as the tape move down? It does not get bigger when it moves down slowly. It only does that when it moves down quickly, sucking the pilot to get closer to the fast moving tape. It may be even bloodier, unless one is trained to slow down the fast moving tape before it displays a single digit 0. |
![]() wrote in message ups.com... On Oct 6, 9:21 am, Arno wrote: Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno You'll get used to it... there is a transition time to go from round dial to tapes, but once you get used to tapes you will find that they do have certain advantages. I worked on the 777 EFIS, which used the tape format, and after several hours in the 777 simulator, the tapes became as easy to read at a glance as the round dials. It just takes conditioning your mind to be able to rapidly scan them, and being able to pick up trend information from the tape motion instead of needle motion. At least that was my experience. A lot of human factors work went into the tape formats, and it was with the understanding that training would be required for pilots to adapt to them. Dean I have never seen the system for the 777, but I did get a look at the low end equipment at the LSA Expo in Sebring Florida, and felt that what I saw was pure crap! It is certainly possible to make a tape motion system that works well, and I have seen some "physical" versions that I liked when I was an avionics tech twenty years ago. However, those have a moving needle which moved in opposition to the moving tape and at a slower rate than the tape. The result was that the needle gave the coarse indication, at a glance, and the tape gave the precise measurement when required--and, in the case of a higher flying aircraft which would require a three needle altimeter, may have been more intuitive to read. However, on the implementations that I have seen, the representations of needles were fixed and the numbers moved on a virtual card or tape. In my opinion, they were egregeous! Peter |
with the understanding that training would be required for pilots to adapt to them. That's interesting. Do you have any reference of research comparing various display methods? Tapes for speed and altitude in today's cockpits are ubiquitous of course. So far I thought it was a case of someone starting it and others just copying it. Arno |
Dean,
I just noticed something interesting, looking at pictures of recent Boeing and Airbus PFDs. For altitude, they are both pretty much the same, but for the speed tape, Airbus does not have a big number at the center of the tape but instead the number on top of the tape and just a thin line at the center. After my experience today I like the Airbus better because it is less conducive to reading the numbers rather than "get the picture": Airbus A340: http://simflight.nl/users/reviews/CL...nshots/PFD.jpg Boeing 777: http://www.meriweather.com/777/fwd/pfd.html Arno |
On Oct 6, 2:35 pm, Arno wrote:
Dean, I just noticed something interesting, looking at pictures of recent Boeing and Airbus PFDs. For altitude, they are both pretty much the same, but for the speed tape, Airbus does not have a big number at the center of the tape but instead the number on top of the tape and just a thin line at the center. After my experience today I like the Airbus better because it is less conducive to reading the numbers rather than "get the picture": Airbus A340: http://simflight.nl/users/reviews/CL...nshots/PFD.jpg Boeing 777: http://www.meriweather.com/777/fwd/pfd.html Arno Take a look at the speed tape on the 777. The tape itself gives you the course rate of change, while the window gives you the fine resolution changes with the 1's place on the airspace as a sliding digit. The Airbus doesn't give you that. |
On Oct 6, 6:10 pm, wrote:
On Oct 6, 2:35 pm, Arno wrote: Dean, I just noticed something interesting, looking at pictures of recent Boeing and Airbus PFDs. For altitude, they are both pretty much the same, but for the speed tape, Airbus does not have a big number at the center of the tape but instead the number on top of the tape and just a thin line at the center. After my experience today I like the Airbus better because it is less conducive to reading the numbers rather than "get the picture": Airbus A340: http://simflight.nl/users/reviews/CL...nshots/PFD.jpg Boeing 777: http://www.meriweather.com/777/fwd/pfd.html Arno Take a look at the speed tape on the 777. The tape itself gives you the course rate of change, while the window gives you the fine resolution changes with the 1's place on the airspace as a sliding digit. The Airbus doesn't give you that.- Hide quoted text - - Show quoted text - Oops, typo, make that "coarse rate of change" |
ups.com... .... You'll get used to it... there is a transition time to go from round dial to tapes, but once you get used to tapes you will find that they do have certain advantages. I worked on the 777 EFIS, which used the tape format, and after several hours in the 777 simulator, the tapes became as easy to read at a glance as the round dials. It just takes conditioning your mind to be able to rapidly scan them, and being able to pick up trend information from the tape motion instead of needle motion. At least that was my experience. A lot of human factors work went into the tape formats, and it was with the understanding that training would be required for pilots to adapt to them. Dean Hey Dean, the tape systems I've seen have the scale fixed on the display and the tape that moves up and down the scale appropriately. That is not how the Garmin system works from what I've seen. The G1000 in the local 182 actually moves the scale in relation to a fixed pointer that is mid-scale on the display, so you have to read numbers relative to a pointer instead of judging a tape marker relative to a fixed scale. This is much more difficult than the old fixed scale displays, but I don't see how they could cram as much on the screen as they do if they still used fixed scale depictions. Those old instruments used the barberpole concept very well and went right along with the round gages for system monitoring where we would rotate the gauges in the panel such that "normal" had all needles pointing the same direction; no interpretation needed unless one of the needles wasn't pointing like the rest. In some ways technology has made the panel much less intuitive and more time consuming. Think about traffic signals - Red means stop, but we could have just as easily put up a digital display that said "Cross traffic beginning". Which would be easier for the driver to interpret most quickly? -- Jim Carter Rogers, Arkansas |
OSH Homerun? Glass Cockpit for the Budget-Challenged | Marco Leon | Piloting | 4 | July 27th 07 11:27 PM |
winter is hard. | Bruce Greef | Soaring | 2 | July 3rd 06 06:31 AM |
Why Not Use PC To Make Glass Cockpit? | Le Chaud Lapin | Instrument Flight Rules | 52 | July 19th 05 03:45 AM |
It ain't that hard | Gregg Ballou | Soaring | 8 | March 23rd 05 01:18 AM |
Glass Cockpit in Older Planes | Charles Talleyrand | Owning | 2 | May 20th 04 01:20 AM |
