Cessna Anticipates AvGas Demise
Old October 7th 07, 01:09 AM posted to rec.aviation.piloting
Larry Dighera
Default Cessna Anticipates AvGas Demise
On Sat, 06 Oct 2007 23:29:31 GMT, Matt Whiting
wrote in :
It's fully FADEC controlled, so always best prop pitch to the chosen
power setting.
Yes, that is a nice advantage.
What powers the FADEC in the event of an electrical system failure?
Old October 7th 07, 01:18 AM posted to rec.aviation.piloting
Stefan
power setting.
No idea about the Thielert, but the FADEC controlled engine I often fly
just falls back to some default settings. I mean, it had been if it ever
had failed.
Old October 7th 07, 01:29 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Stefan wrote in news:9b58a$470825c7$d9a271ba
power setting.
had failed.
This is what happens
http://www.megginson.com/blogs/lahso...ngine-failure/
Bertie
Old October 7th 07, 08:41 AM posted to rec.aviation.piloting
Thomas Borchert
Larry,
A battery. Yes, in the case of the DA-42, this was implemented lousily,
as someone found out the hard way when he didn't follow the POH. The
system is being changed to prevent fools from...
Other installations are different.
In case you worry about this "single point of failure", your Lyc or
Continental has tons of them, too.
Thomas Borchert (EDDH)
Old October 7th 07, 11:18 AM posted to rec.aviation.piloting
Thomas Borchert wrote in
Larry,
But not invovling electricity.
Any airplane I've flown that has Fadec has some sort of manual reversion.
Bertie
Old October 7th 07, 04:48 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 07 Oct 2007 09:41:05 +0200, Thomas Borchert
wrote in
Larry,
A battery.
Are you saying the battery isn't part of the electrical system? Or
are you saying Thielert equipped aircraft carry an additional battery
dedicated to the FADEC system that is incapable of failure?
Old October 7th 07, 02:15 AM posted to rec.aviation.piloting
Roy Smith
Matt Whiting wrote:
It's fully FADEC controlled, so no overheating possible.
Automobile engines have been digitally controlled for two decades and
they still can overheat.
Yes, but they don't overheat because somebody set the wrong combination of
three different knobs.
Old October 7th 07, 02:19 PM posted to rec.aviation.piloting
Matt Whiting
What part of "so no overheating possible" didn't you understand? That
statement is simply factually incorrect.
Matt
Old October 7th 07, 06:12 PM posted to rec.aviation.piloting
Stefan
combination of three different knobs.
What part of "not possible" didn't *you* understand? Frankly I don't
know abot the Thielert, but with the FADEC controlled engine *I* fly
regularly (a non-certified engine which isn't sold in the USA), I've not
been able to overheat it, and I *did* try. (Actually I've just tried to
reach the allowed limits, of course.) So yes, it's a reachable goal.
Old October 7th 07, 10:21 PM posted to rec.aviation.piloting
Roy Smith
Matt
Taken literally, the statement, "no overheating possible" is indeed
incorrect. But, FADEC still gives you a protection against most of the bad
things people do to engines through poor technique.
100/130 avgas Roy Smith General Aviation 1 December 24th 06 09:17 AM
Old AvGas gwengler Piloting 2 December 16th 06 01:07 PM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
The demise of the Sea Harrier Henry J Cobb Naval Aviation 39 April 25th 04 07:27 PM
Here's to Arafat's Speedy Demise robert arndt Military Aviation 0 September 12th 03 07:45 AM
