Glass cockpit hard to read
Old October 6th 07, 10:11 PM posted to rec.aviation.piloting
Viperdoc[_4_]
Default Glass cockpit hard to read
To all:
Please be aware the Anthony Atkielski (mxsmanic) is not a pilot, and has
never held an aviation medical. In fact he has never even taken a lesson,
let alone fly in a small plane.
He certainly has never flown with or operated a G-1000 or anything remotely
similar.
Viperdoc[_4_]
To all:
similar.
Old October 6th 07, 10:59 PM posted to rec.aviation.piloting
Dan Luke[_2_]
"Bertie the Bunyip" wrote:
An analogue display cuts the left hand side out of the loop and enables
the calcualtion rate to increase the right sides "frame rate" so that
corrections can be made more frequently thus enabling the pilot to fly
the airplane more smooothly and with more authority.
Caorse rule of thumb math can be laid over this for descent angles,
interceptin angles and wo on, but generally, the fewer numbers involved,
the better.
People who prefer the numbers usualy don't fly very well at all.
Bless you, my boy.
I thought the reason I hated the tapes was that I'm just an old fogie. Now I
know it's because I'm a natural!
Most gratifying news.
Dan
T-182T at BFM
Old October 6th 07, 11:06 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"Dan Luke" wrote in
enables the calcualtion rate to increase the right sides "frame rate"
so that corrections can be made more frequently thus enabling the
pilot to fly the airplane more smooothly and with more authority.
involved, the better.
Bless you, my boy.
Now I know it's because I'm a natural!
'xactly.
've had a speed tape in front of me for years now and I still look right
past it to the ASI. It does have a useful function in that it flashes if I
get more than a few knots away from bug speed whilst hand flying, but
intuitive use of the ASI needle is al I have found I'd ever need.
That's why the name Berite the Bunyip is a byword for service.
Bertie
Old October 7th 07, 01:10 AM posted to rec.aviation.piloting
On Oct 6, 2:35 pm, Arno wrote:
Dean,
I just noticed something interesting, looking at pictures of recent
Boeing and Airbus PFDs. For altitude, they are both pretty much the
same, but for the speed tape, Airbus does not have a big number at the
center of the tape but instead the number on top of the tape and just
a thin line at the center. After my experience today I like the Airbus
better because it is less conducive to reading the numbers rather than
"get the picture":
Airbus A340:
http://simflight.nl/users/reviews/CL...nshots/PFD.jpg
Boeing 777:
http://www.meriweather.com/777/fwd/pfd.html
Arno
Take a look at the speed tape on the 777. The tape itself gives you
the course rate of change, while the window gives you the fine
resolution changes with the 1's place on the airspace as a sliding
digit. The Airbus doesn't give you that.
Old October 7th 07, 01:30 AM posted to rec.aviation.piloting
Mxsmanic
Bertie the Bunyip writes:
Flying is a right hand brain activity. At least the handling portion is.
The right hand side of the brain dosn't do abstractions like numbers, at
least not until the left hand side (which can't fly worth a ****) sends
it over to the right side in a readily digestable form which enables the
right brain to chew it into a picture.
Most of this is pure speculation, although it is interesting.
Unless, of course, they are flying an airliner in which systems are more
important than hand-flying. In that case, they may be a lot better at it.
You don't do trig while you're shooting pool and expect to win the game.
Some people do (cf. card counters).
  #28
Old October 7th 07, 01:33 AM posted to rec.aviation.piloting
Jim Logajan
Bertie the Bunyip wrote:
john smith wrote in
game.
You're right, I do geometry. :-))
Nobody can do geometry properly with the required alchohol load to play
pool properly
I consider it well played if I manage to hit the cue ball with the cue
stick. And that's sometimes with no alcohol load. I then pray (a dubious
thing for an atheist to do) for fortuitous stochastic scattering to align
with my prediction.
  #29
Old October 7th 07, 01:36 AM posted to rec.aviation.piloting
Dean,
"get the picture":
Airbus A340:
Boeing 777:
Arno
digit. The Airbus doesn't give you that.- Hide quoted text -
- Show quoted text -
Oops, typo, make that "coarse rate of change"
  #30
Old October 7th 07, 01:55 AM posted to rec.aviation.piloting
Mxsmanic wrote in
is. The right hand side of the brain dosn't do abstractions like
numbers, at least not until the left hand side (which can't fly worth
a ****) sends it over to the right side in a readily digestable form
which enables the right brain to chew it into a picture.
No it isn't. I do it, you don;t
more important than hand-flying. In that case, they may be a lot
better at it.
It was an airliner I was talking about Fjukktard.
I
game.
Card counters use trig to play pool , do they?
You are the dumbest fjukkwit I've ever seen.
Bertie
OSH Homerun? Glass Cockpit for the Budget-Challenged Marco Leon Piloting 4 July 27th 07 11:27 PM
winter is hard. Bruce Greef Soaring 2 July 3rd 06 06:31 AM
Why Not Use PC To Make Glass Cockpit? Le Chaud Lapin Instrument Flight Rules 52 July 19th 05 03:45 AM
It ain't that hard Gregg Ballou Soaring 8 March 23rd 05 01:18 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
