Cessna Anticipates AvGas Demise
Old October 7th 07, 02:19 PM posted to rec.aviation.piloting
Matt Whiting
Default Cessna Anticipates AvGas Demise
Roy Smith wrote:
Matt Whiting wrote:
It's fully FADEC controlled, so no overheating possible.
Automobile engines have been digitally controlled for two decades and
they still can overheat.
Yes, but they don't overheat because somebody set the wrong combination of
three different knobs.
What part of "so no overheating possible" didn't you understand? That
statement is simply factually incorrect.
Matt
Old October 7th 07, 06:12 PM posted to rec.aviation.piloting
Stefan
combination of three different knobs.
What part of "not possible" didn't *you* understand? Frankly I don't
know abot the Thielert, but with the FADEC controlled engine *I* fly
regularly (a non-certified engine which isn't sold in the USA), I've not
been able to overheat it, and I *did* try. (Actually I've just tried to
reach the allowed limits, of course.) So yes, it's a reachable goal.
Old October 7th 07, 06:15 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Stefan wrote in news:b7358$47091384$d9a2714f$8838
@news.hispeed.ch:
You try letting the coolant out?
Bertie
Old October 7th 07, 07:54 PM posted to rec.aviation.piloting
Morgans[_2_]
That would definitely make it easier!
Only you would think of doing that. ;-))
Jim in NC
Old October 7th 07, 11:39 PM posted to rec.aviation.piloting
"Morgans" wrote in news:lX9Oi.32$Mx6.29
@newsfe05.lga:
Well, the manufacture hopefully would, but being German they would probably
say "this cannot happen"
Bertie
Old October 7th 07, 08:25 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 07 Oct 2007 19:12:36 +0200, Stefan
wrote in :
Frankly I don't
So, are you saying that the FADEC will command a reduction in engine
power to reduce heating as the high-temp limit is approached?
Old October 7th 07, 09:32 PM posted to rec.aviation.piloting
Stefan
I'm not absolutely sure on this, but I don't think so. I think it just
has an extremely efficient cooling system (overkill, so to speak) which
is regulated by FADEC, i.e. reduced to keep the engine temperature high
enough.
Of course I believe that if one really tries, one *will* find a way to
kill the engine. E.g. the POH forbids a sustained power setting of more
than 75%. Or, as others have pointed out, remove the coolant before
flight. Or if nothing else helps, take a sledge hammer.
Old October 7th 07, 09:01 PM posted to rec.aviation.piloting
Matt Whiting
and they still can overheat.
Drain the coolant and go flying. Tell me how long the FADEC prevents
the engine from overheating.
Matt
Old October 7th 07, 09:04 PM posted to rec.aviation.piloting
Stefan
Yawn. Dry the oil and go flying.
Old October 7th 07, 11:12 PM posted to rec.aviation.piloting
Matt Whiting
So, you finally admit that the FADEC can't prevent overheating.
Matt
100/130 avgas Roy Smith General Aviation 1 December 24th 06 09:17 AM
Old AvGas gwengler Piloting 2 December 16th 06 01:07 PM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
The demise of the Sea Harrier Henry J Cobb Naval Aviation 39 April 25th 04 07:27 PM
Here's to Arafat's Speedy Demise robert arndt Military Aviation 0 September 12th 03 07:45 AM
