#61
Roy Smith wrote:
Matt Whiting wrote: It's fully FADEC controlled, so no overheating possible. Automobile engines have been digitally controlled for two decades and they still can overheat. Yes, but they don't overheat because somebody set the wrong combination of three different knobs. What part of "so no overheating possible" didn't you understand? That statement is simply factually incorrect. Matt |
#62
Thomas Borchert wrote:
Matt, It's liquid cooled, so no discussion about shock cooling anymore. So we prevent a problem that isn't really a problem. No. Read carefully. We prevent DISCUSSION about a problem that isn't a problem ;-) Ah, but it is then replaced by discussions about loss of coolant and the dangers therein... :-) It's geared, so a prop strike doesn't affect the engine. The engine still stops suddenly unless the gearbox fails or is designed to fail before any significant acceleration is transferred to the engine. There is no direct mechanical connection between the engine and the prop, as I understand it. Same goes for the Rotax 912/914 series. Thielert's website is in English... ;-) The prop is driven by an electric motor? Cool! If it is driven by gears, belts, shafts or other things mechanical, then there is a direct connection otherwise the prop won't turn! :-) The connection may not be capable of transferring high accelerations, but it is still a direct connection. Matt |
#63
There's no TBO. They call it a TBR, where the whole engine is replaced with a new one. I can't put my finger on the time but I think it's around 2400 hours. Ain't that great? Power by the hour. You know in advance what it will cost you to run that engine 2400 hours. No surprise midtime overhauls. If it doesn't make TBR, Thielert will prorate it on the new engine. That is great as long as the cost per hour is competitive. Matt |
#64
On Sun, 07 Oct 2007 09:41:05 +0200, Thomas Borchert
wrote in : Larry, What powers the FADEC in the event of an electrical system failure? A battery. Are you saying the battery isn't part of the electrical system? Or are you saying Thielert equipped aircraft carry an additional battery dedicated to the FADEC system that is incapable of failure? |
#65
Larry,
Or are you saying Thielert equipped aircraft carry an additional battery dedicated to the FADEC system that is incapable of failure? They carry an extra. "INcapable of failure"? Show me one thing on an airplane (or anything) that is. So, in the literal sense you seem to have wanted your statement to be read: Yes, without electricity, the engine doesn't run. So? -- Thomas Borchert (EDDH) |
#66
Matt,
The connection may not be capable of transferring high accelerations, but it is still a direct connection. Well, let's get specific rather than semantic: The coupling is hydraulic, as I understand it. -- Thomas Borchert (EDDH) |
#67
("Larry Dighera" wrote)
What powers the FADEC in the event of an electrical system failure? A battery. Are you saying the battery isn't part of the electrical system? Or are you saying Thielert equipped aircraft carry an additional battery dedicated to the FADEC system that is incapable of failure? http://www.youtube.com/watch?v=bEaQO_2Httg Cessna's New Turbo Diesel 172 Skyhawk (4:25 mark) "We also have add a FADEC stand-by battery, which allows the airplane to run for 2 hours. In the event of a total electric failure there's a battery dedicated just to the engine." Montblack |
#68
Roy Smith wrote:
Yes, but they don't overheat because somebody set the wrong combination of three different knobs. Four knobs. You forgot the stick. |
#69
Matt Whiting wrote:
It's fully FADEC controlled, so no overheating possible. Automobile engines have been digitally controlled for two decades and they still can overheat. Yes, but they don't overheat because somebody set the wrong combination of three different knobs. What part of "so no overheating possible" didn't you understand? That statement is simply factually incorrect. What part of "not possible" didn't *you* understand? Frankly I don't know abot the Thielert, but with the FADEC controlled engine *I* fly regularly (a non-certified engine which isn't sold in the USA), I've not been able to overheat it, and I *did* try. (Actually I've just tried to reach the allowed limits, of course.) So yes, it's a reachable goal. |
#70
Stefan wrote in news:b7358$47091384$d9a2714f$8838
@news.hispeed.ch: Matt Whiting wrote: It's fully FADEC controlled, so no overheating possible. Automobile engines have been digitally controlled for two decades and they still can overheat. Yes, but they don't overheat because somebody set the wrong combination of three different knobs. What part of "so no overheating possible" didn't you understand? That statement is simply factually incorrect. What part of "not possible" didn't *you* understand? Frankly I don't know abot the Thielert, but with the FADEC controlled engine *I* fly regularly (a non-certified engine which isn't sold in the USA), I've not been able to overheat it, and I *did* try. (Actually I've just tried to reach the allowed limits, of course.) So yes, it's a reachable goal. You try letting the coolant out? Bertie |
100/130 avgas | Roy Smith | General Aviation | 1 | December 24th 06 09:17 AM |
Old AvGas | gwengler | Piloting | 2 | December 16th 06 01:07 PM |
Survival and Demise Kit; Contest Points | Jim Culp | Soaring | 1 | June 21st 04 04:35 AM |
The demise of the Sea Harrier | Henry J Cobb | Naval Aviation | 39 | April 25th 04 07:27 PM |
Here's to Arafat's Speedy Demise | robert arndt | Military Aviation | 0 | September 12th 03 07:45 AM |
