Stefan wrote:
Matt Whiting wrote: I don't plan to buy one so I have no need to do the math. If you want to prove a point, you do the math. *I* don't want to prove anything. It was you who claimed that the life span of the Thielert was too short to be competitive. No, I never claimed that. Matt |
Matt Whiting wrote:
*I* don't want to prove anything. It was you who claimed that the life span of the Thielert was too short to be competitive. No, I never claimed that. Matt You wrote: Yes, this may be the case, however the TBR has to get closer to 4,000 hours than to 2,400. Most auto and truck diesels will last at least twice as long as similar size gas engines, so with Lycs and Contis lasting 2,000 hours fairly routinely, the Thielert needs to at least double that ... unless the replacement cost is equivalent to an overhaul of a Lyc or Conti. Matt Of curse I did completely misunderstand you. No, please don't explain. It gets boring. |
Stefan wrote:
Matt Whiting wrote: *I* don't want to prove anything. It was you who claimed that the life span of the Thielert was too short to be competitive. No, I never claimed that. Matt You wrote: Yes, this may be the case, however the TBR has to get closer to 4,000 hours than to 2,400. Most auto and truck diesels will last at least twice as long as similar size gas engines, so with Lycs and Contis lasting 2,000 hours fairly routinely, the Thielert needs to at least double that ... unless the replacement cost is equivalent to an overhaul of a Lyc or Conti. Matt Of curse I did completely misunderstand you. No, please don't explain. It gets boring. Yes, what part of "unless the replacement cost is equivalent to an overhaul of a Lyc or Conti" wasn't clear? Matt |
Matt Whiting wrote:
Yes, this may be the case, however the TBR has to get closer to 4,000 hours than to 2,400. Most auto and truck diesels will last at least twice as long as similar size gas engines, so with Lycs and Contis lasting 2,000 hours fairly routinely, the Thielert needs to at least double that ... unless the replacement cost is equivalent to an overhaul of a Lyc or Conti. Matt Of curse I did completely misunderstand you. No, please don't explain. It gets boring. Yes, what part of "unless the replacement cost is equivalent to an overhaul of a Lyc or Conti" wasn't clear? Ah, I finally understand. I've always thought you were insuinating something by insisting that the Theilert ist only a good deal provided it is a good deal and repeating that statement over and over. But I finally understand that you didn't insuinate anything. You just meant what you wrote: It's only a good deal if it's a good deal. I don't know how you call such a statement in English, but in German I call it a "Null-Aussage", a zero-statement. It's only a good deal if it's a good deal... geezz. Sorry for searching for a message in your statement. |
Stefan wrote in
: Matt Whiting wrote: Yes, this may be the case, however the TBR has to get closer to 4,000 hours than to 2,400. Most auto and truck diesels will last at least twice as long as similar size gas engines, so with Lycs and Contis lasting 2,000 hours fairly routinely, the Thielert needs to at least double that ... unless the replacement cost is equivalent to an overhaul of a Lyc or Conti. Matt Of curse I did completely misunderstand you. No, please don't explain. It gets boring. Yes, what part of "unless the replacement cost is equivalent to an overhaul of a Lyc or Conti" wasn't clear? Ah, I finally understand. I've always thought you were insuinating something by insisting that the Theilert ist only a good deal provided it is a good deal and repeating that statement over and over. But I finally understand that you didn't insuinate anything. You just meant what you wrote: It's only a good deal if it's a good deal. It's only a good deal if it doesn't land you in the jungle if your diehard becomes disconnected. Bertie |
100/130 avgas | Roy Smith | General Aviation | 1 | December 24th 06 09:17 AM |
Old AvGas | gwengler | Piloting | 2 | December 16th 06 01:07 PM |
Survival and Demise Kit; Contest Points | Jim Culp | Soaring | 1 | June 21st 04 04:35 AM |
The demise of the Sea Harrier | Henry J Cobb | Naval Aviation | 39 | April 25th 04 07:27 PM |
Here's to Arafat's Speedy Demise | robert arndt | Military Aviation | 0 | September 12th 03 07:45 AM |
