A Sad Accident
Old October 9th 07, 09:32 PM posted to rec.aviation.piloting
Bob Gardner
Default A Sad Accident
All we have is press reports at present, and you know how reliable they are.
Comments from the skydivers club indicate that on a cross-country like this
they would take off their chutes and use them as pillows. Last two radar
hits indicated a vertical speed of 7000 fpm, which is not conducive to
leaving the airplane, to say the least.
The tail was found some distance from the main wreckage; the Caravan has
icing issues. Related? I can't say.
Bob Gardner
On Oct 9, 10:52 am, RL Anderson wrote:
Greetings All,
Thought I'd pass on that there has been a horrific crash this past
Sunday (7 Oct). There was a Caravan used for skydiving, with 10 people
aboard, traveling between Star Idaho and Shelton Washington. The
airplane went down in the general vicinity of White Pass, a 4500 foot
mountain pass on US 12, located on the boundary of Yakima and Lewis
Counties, in the South Central Washington Cascade Mountains. According
to local news, no survivors have been found. I am acquainted with
several skydivers and some of the other folks at the aircraft owner,
Skydive Kapowsin. I hope that none of the folks I know are involved.
Here are some links to the story.
http://www.herald-republic.com/page/dis/290013970261411
http://www.herald-republic.com/page/dis/290013901892319
Pass on as you see fit.
Rick
Do you have any idea what the weather was like at the time of the
crash? Why was he so low? Was he scud running?
I was thinking that if it had been an engine failure at altitude, the
passenges would have bailed out with their chutes, given that they
were experienced skydivers.
Old October 10th 07, 12:24 AM posted to rec.aviation.piloting
Dale[_3_]
A jumper in freefall is descending at around 12000 fpm so the speed
alone wouldn't be a big deal...and out of control airplane could make it
hard to get out.
Old October 10th 07, 02:26 AM posted to rec.aviation.piloting
Bob Gardner
Freefall is a lot different than being pinned in a pile of bodies in the aft
end of the cabin by acceleration forces. I doubt that they were even able to
move, once the dive began.
Bob Gardner
"Dale" wrote in message
are.
this
hard to get out.
Old October 10th 07, 06:40 AM posted to rec.aviation.piloting
Dale[_3_]
I understand that, IF they were out of control. I descended at
3000-4000fpm in a 206 and kept the engine warm. It wouldn't be
unreasonable to think they could reach 7000fpm without being out of
control...although it does sound like a spiral descent with inflight
breakup. I'm reading they found the tail section some distance away.
Not the way I want to die.
Old October 11th 07, 02:55 AM posted to rec.aviation.piloting
Bob Gardner
I was just going to post a correction, because the last news I saw said that
the tail had not been found. The sheriff described the accident scene as
pretty much a lawn dart, although he didn't use those words....60 by 100
feet.
Bob Gardner
aft
to
Old October 11th 07, 04:11 AM posted to rec.aviation.piloting
feet.
Bob Gardner
aft
to
The Caravan does not carry ice well. There's an airworthiness
directive against it for that reason. See
http://rgl.faa.gov/Regulatory_and_Gu...7?OpenDocument
Dan
Old October 11th 07, 03:30 PM posted to rec.aviation.piloting
Dale[_3_]
feet.
I saw that same Sheriff quoted as saying the aircraft impacted at "70
mph". G
Old October 10th 07, 07:15 AM posted to rec.aviation.piloting
M[_1_]
That's true. However I live in Seattle metro area and the weather
that day was very bad. It was one of those northwest winter stormy
days where you can pretty much expect bad icing over the Cascades, and
very non-VFR conditions over the mountains. Just about the only way
to safely fly over the Cascades on those days would be IFR in known-
ice certified airplanes with a lot of power.
Wind + lots of moisture in the airmass + mountain range = uplift and
very bad icing.
DA 42 accident Karl-Heinz Kuenzel Piloting 86 April 29th 07 09:05 AM
Accident? on 8-27-92 Chris Wells General Aviation 8 January 10th 06 02:15 AM
F6F accident Larry Cauble Naval Aviation 4 October 14th 05 06:19 PM
Accident db? [email protected] Owning 3 July 25th 05 06:22 PM
MU2 accident Big John Piloting 16 April 13th 04 03:58 AM
