![]() "gman" wrote in message ups.com... I'm with Mitty on this one. AIM Section 5-4-5.d.4(b) Says: "Pilots entering the TAA and cleared by air traffic control, are expected to proceed directly to the IAF associated with that area of the TAA at the altitude depicted, unless otherwise cleared by air traffic control." If the clearance was indeed "...maintain 4000 until established" that would fit the "..unless otherwise cleared by air traffic control" clause. You didn't go far enough: "Cleared direct to an Initial Approach Fix (IAF) without a clearance for the procedure does not authorize a pilot to descend to a lower TAA altitude. If a pilot desires a lower altitude without an approach clearance, request the lower TAA altitude." To put this to a test, ask yourself when would you report established on the approach if asked by ATC to ".. report established on the approach"? My answer would be when I'm on one of the depicted portions of the approach and not the TAA. My answer would be when I'm within the TAA, because a TAA is by definition a published portion of the approach. TERMINAL ARRIVAL AREA (TAA)? The TAA is controlled airspace established in conjunction with the Standard or Modified T and I RNAV approach configurations. In the standard TAA, there are three areas: straight-in, left base, and right base. The arc boundaries of the three areas of the TAA are published portions of the approach and allow aircraft to transition from the en route structure direct to the nearest IAF. TAAs will also eliminate or reduce feeder routes, departure extensions, and procedure turns or course reversal. I guess one could argue that the TAA is a depicted portion of the approach but I can't find any official publication pointing to that fact. It's in the Pilot/Controller Glossary. |
