Travis Marlatte wrote:
"Jay Honeck" wrote in message ups.com... ... As RPMs dropped below 1000, the "shock-cooling alarm" suddenly went off, flashing its dire warnings that EGTs had dropped beyond (and faster) than recommended limits. (I can't remember what the threshold is for that alarm -- it's preset.) ... Jay Honeck What happens when you do a normal pattern? Given your explaination, I would assume that you get a shock cooling alarm everytime you do power reductions as part of a normal landing. If not, use the same technique at altitude to get into a power idle glide. I don't have any engine analyzer. But, on a normal approach, I will reduce throttle in two or three steps to get to 15" or 16". That supports my minimum, flaps up, holding altitude speed. Then, with gear out and flaps down, I'm descending on extended downwind, base and final, with the power gradually coming off to flare. (I'm not describing this as the ideal technique. I'm stating it so that others can say - "Are you crazy! That technique is an engine killer.") Have you killed any engines yet doing this? Matt |
Topi - Mig29 engine failure during practice - "topi.wmv" (14/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (13/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
