The issue with shock cooling isn't the rate of cooling per se, but
rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. Therefore, I fly as if it exists. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) Matt |
Matt Whiting wrote:
Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) It doesn't (in metals) unless the temperature change is very high and very localized as in welding. -- Jim Pennino Remove .spam.sux to reply. |
rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) How 'bout this: It's the disparate rates of cooling in some parts of the engine (versus others) that causes the differential cooling that induces stress? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) How 'bout this: It's the disparate rates of cooling in some parts of the engine (versus others) that causes the differential cooling that induces stress? Yes, that is what I said originally. It is differential cooling that causes the problem, not the rate of cooling itself. If you could cool the entire engine uniformly, I don't think it would matter much how fast you cooled it. It isn't the rate itself that causes a problem, it is the difference in rates from one location to another. However, I still think that the greatest thermally induced stress occurs during the initial heat-up from a cold start, but I don't have any data to confirm that and I don't have an instrument airplane with which to collect the data. Matt |
Matt Whiting wrote:
Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) How 'bout this: It's the disparate rates of cooling in some parts of the engine (versus others) that causes the differential cooling that induces stress? Yes, that is what I said originally. It is differential cooling that causes the problem, not the rate of cooling itself. If you could cool the entire engine uniformly, I don't think it would matter much how fast you cooled it. It isn't the rate itself that causes a problem, it is the difference in rates from one location to another. However, I still think that the greatest thermally induced stress occurs during the initial heat-up from a cold start, but I don't have any data to confirm that and I don't have an instrument airplane with which to collect the data. Matt I would think the greatest thermally induced stress occurs when you fly into rain. -- Jim Pennino Remove .spam.sux to reply. |
![]() "Matt Whiting" wrote in message news ![]() Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) Matt By implication, a fast cooling rate would cause *more* differential cooling, since the cylinders cool from the fins inward. The faster the cooling, the higher the delta-T between the internal and external surfaces of the cylinders. The higher the delta, the more internal stresses on the cylinders due to the different growth between the hot and cold surfaces. But you already knew that and were just being difficult, eh? KB |
Topi - Mig29 engine failure during practice - "topi.wmv" (14/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (13/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
