			#41
Stefan wrote:
	Matt Barrow schrieb: Thomas offers data and evidence, Lycoming offers anecdote and legend. Lycoming offers running engines. Thomas offers words. Lycoming and Continental offer no science whatsoever to back up their recommendations. There are several companies that can show you hard scientific data to disprove what the engine manufacturers claim.  |
			#42
			 "Matt Whiting" wrote The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Most engines see far higher temperature differentials during start-up than they do during cooldown. Jay, have you timed your engine heat up rate? It would be interesting to watch how fast your engine heats up from say a 50 degree cold start and then compare that to the cool-down rate when you pull the throttle for engine out practice. I'm assuming this would be fairly trivial with your engine analyzer. I'm pretty sure that the rate of heating of the metal of the head is not the big issue, according to the shock cooling proponents. Instead, it is the heads (and cylinders) cooling more rapidly than the pistons, and the hot pistons (not able to be cooled as rapidly) against the cooler cylinders (the cylinders do not have heat instrumentation, so the closest thing they can do is to measure is the head temperatures) causing a reduction in the tolerances between the piston and the cylinder walls, thus causing possible scuffing and abnormal wear. At least that is my take on what they say. -- Jim in NC  |
			#43
			 "Morgans" wrote At least that is my take on what they say. I should have added that the cylinders heating up faster, on start up, than the pistons would increase the tolerances, and thus cause no scuffing. -- Jim in NC  |
			#44
	Matt Whiting wrote: Hmmm, thinking about it a bit, any shock cooling should be worse on the front two cylinders rain or shine. An analyse of failure rate by cylinder position would be interesting. Yes, my thought exactly. I wonder if anyone keeps such data? I know when I owned my Skylane, we never had any unusual issues with the front two cylinders. This data, if available, would certainly provide some indication if shock cooling is real or imagined. My O-320 had 2 cracked cylinders (both on the left side) at the same time. This was the year after the exhaust stud hold cracked on the right front cylinder. Shock cooling? More likely due to the fact that these were cermichromed cylinders with an unknown number of hours on them before they cracked at 600hours SMOH. -- Bob Noel (goodness, please trim replies!!!)  |
			#45
			 "Matt Whiting" wrote in message news ![]() Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) Matt By implication, a fast cooling rate would cause *more* differential cooling, since the cylinders cool from the fins inward. The faster the cooling, the higher the delta-T between the internal and external surfaces of the cylinders. The higher the delta, the more internal stresses on the cylinders due to the different growth between the hot and cold surfaces. But you already knew that and were just being difficult, eh? KB  |
			#46
Kyle Boatright wrote:
	"Matt Whiting" wrote in message news ![]() Jay Honeck wrote: The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Actually, I think it is the rate of cooling *and* the differential cooling -- if it exists at all. Like you, I am skeptical -- but am I willing to bet $25K on it? Nope. How does the rate affect things? I have a masters in structural engineering and work for a materials company so don't be afraid to get technical. :-) Matt By implication, a fast cooling rate would cause *more* differential cooling, since the cylinders cool from the fins inward. The faster the cooling, the higher the delta-T between the internal and external surfaces of the cylinders. The higher the delta, the more internal stresses on the cylinders due to the different growth between the hot and cold surfaces. But you already knew that and were just being difficult, eh? It is a subtle point maybe, but an important one. It isn't the rate of cooling that matters. It is a difference in rate between two locations. Faster cooling doesn't necessarily a greater differential, it all depends on how the cooling is done. In some materials and at some temperatures, the rate of cooling can change the fundamental material properties. That is a different issue than what is involved with engines. Matt  |
			#47
Morgans wrote:
	"Matt Whiting" wrote The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Most engines see far higher temperature differentials during start-up than they do during cooldown. Jay, have you timed your engine heat up rate? It would be interesting to watch how fast your engine heats up from say a 50 degree cold start and then compare that to the cool-down rate when you pull the throttle for engine out practice. I'm assuming this would be fairly trivial with your engine analyzer. I'm pretty sure that the rate of heating of the metal of the head is not the big issue, according to the shock cooling proponents. Instead, it is the heads (and cylinders) cooling more rapidly than the pistons, and the hot pistons (not able to be cooled as rapidly) against the cooler cylinders (the cylinders do not have heat instrumentation, so the closest thing they can do is to measure is the head temperatures) causing a reduction in the tolerances between the piston and the cylinder walls, thus causing possible scuffing and abnormal wear. At least that is my take on what they say. It seems to me that upon engine start the pistons would heat up much faster than the cylinders causing the same net affect as cooling down the cylinders faster once hot. Either way the pistons are hotter than the cylinders. Matt  |
			#48
Morgans wrote:
	"Morgans" wrote At least that is my take on what they say. I should have added that the cylinders heating up faster, on start up, than the pistons would increase the tolerances, and thus cause no scuffing. Why would the cylinders heat up faster? Only the very top of the cylinder is in constant contact with the combustion heat whereas the top of the piston is entirely in contact. As you go down the cylinder away from the head, the cylinder spends less and less time in contact with the combustion heat and thus will be cooler. Matt  |
			#49
			 Jay Honeck wrote: For you aircraft owners who do this regularly, how slowly do you retard the throttle to prevent shock cooling? (I know -- does shock cooling really exist? For purposes of this discussion, I'll pretend that it does.) I don't believe it exists so I'll go from a low cruise power setting of say 20-21" and 2300 rpm to throttle fully retarded in 3-5 seconds. Given that the power reduction must be incredibly gradual, do you feel that this exercise is realistic? Doing it your way? No. There really is no chance to simulate how you must "suddenly" find best glide speed (after your engine has presumably just crapped out), since you're gradually reducing your speed along with your power. Or do you put the plane into a shallow dive as you reduce power, so as not to lose airspeed? Your just going to have to be content that you are unwilling to realisticly practice this. Find yourself a friends private dirt strip field and start 5-7 miles away at 3000 AGL and land on it without touching the power after you have gone to idle. Another thing I do all the time is pull the power to idle on the downwind and land without touching the power.  |
			#50
			 "Matt Whiting" wrote Why would the cylinders heat up faster? Only the very top of the cylinder is in constant contact with the combustion heat whereas the top of the piston is entirely in contact. As you go down the cylinder away from the head, the cylinder spends less and less time in contact with the combustion heat and thus will be cooler. Perhaps they would not. I was going simply on the converse. My thought is that the cold oil shooting on the piston, and a relatively weak combustion would keep the piston cooler. -- Jim in NC  |
| Thread Tools | |
| Display Modes | |
| Topi - Mig29 engine failure during practice - "topi.wmv" (14/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 10:15 PM |
| Topi - Mig29 engine failure during practice - "topi.wmv" (13/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 10:15 PM |
| Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 10:15 PM |
| Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 11:13 PM |
| A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 05:06 PM |
