On Oct 14, 9:44 pm, Kirk Ellis
wrote: After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? Kirk PPL-ASEL No it is not a sixth sense. It is the right combination of numbers and sight picture. Sight picture only helps when you are fairly low (ie 500' AGL) and on final approach. During downwind or base you don't have a good sight picture to tell whether you are going to be too high or too low. You have to rely on your altimeter and use several 'target' altitudes until you turn final. I use 1000' for the abeam- point, 800' for turning base and 600' for turning final. How you get down to 1000' is completely up to you, but you have to be facing the right direction at the right altitude. If you are doing 360's to lose altitude you should know how much altitude is lost in one turn. You have several tools at your disposal to control altitude such as flaps, airspeed and slip. On a normal approach (with power on) I aim for 400-500' for turning final. The trick is not to nail everything precisely, but to learn to identify deviations and make early corrections so that you don't get too far off track. After turning final, you do everything based on sight picture. Aim for 1/3 down the runway, but when you get close and the landing is assured, slip or flap aggressively to put it down on the numbers. |
Andrew Sarangan schrieb:
No it is not a sixth sense. It is the right combination of numbers and sight picture. Sight picture only helps when you are fairly low (ie 500' AGL) and on final approach. During downwind or base you don't have a good sight picture to tell whether you are going to be too high or too low. You have to rely on your altimeter and use several 'target' altitudes until you turn final. I disagree. Of course the alitmeter can be very helpful, but only if you know the ground elevation and if you are sure your current altimeter setting is correct. As this is often not the case, think in angles. Angles stay the same regardless of height and distance. |
'target' altitudes until you turn final. I disagree. Of course the alitmeter can be very helpful, but only if you know the ground elevation and if you are sure your current altimeter setting is correct. Correct. Additionally, altimeter will tend to stick with engine off. Glider pilots are taught to ignore altimeter during circuit and landing. Bartek |
brtlmj schrieb:
Glider pilots are taught to ignore altimeter during circuit and landing. Guess why I suggested the "looks about right" method... ;-) |
brtlmj wrote:
Correct. Additionally, altimeter will tend to stick with engine off. WHAT? |
WHAT? Engine off - no vibration - altimeter sticks. B. |
brtlmj wrote:
Correct. Additionally, altimeter will tend to stick with engine off. WHAT? Engine off - no vibration - altimeter sticks. Yet another failure mode for liquid crystal displays I hadn't known about. ;-) |
brtlmj wrote:
Correct. Additionally, altimeter will tend to stick with engine off. WHAT? Engine off - no vibration - altimeter sticks. B. In my one fixed wing engine out that didn't happen. But I could see where it could. |
![]() Engine off - no vibration - altimeter sticks. In my one fixed wing engine out that didn't happen. But I could see where it could. A parked altimeter consistently unmoved by overnight weather changes could be a tip-off. - FChE |
On Oct 15, 12:57 pm, brtlmj wrote:
Correct. Additionally, altimeter will tend to stick with engine off. WHAT? Engine off - no vibration - altimeter sticks. So what do they do during the IFR cert? Shake the plane around? -Robert |
Emergency landing at airfield | Danny Deger | Piloting | 10 | January 8th 07 06:31 PM |
Emergency landing theoretical | gatt | Piloting | 21 | May 15th 06 03:07 PM |
Live emergency landing on tv right now | C. Massey | Piloting | 7 | May 4th 06 02:49 AM |
C-141 emergency landing Christchurch | Miche | Military Aviation | 11 | February 6th 04 04:04 AM |
N30793, Emergency Landing | Tom Hughes | Piloting | 5 | August 21st 03 03:56 AM |
