On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert |
On Mon, 15 Oct 2007 17:04:26 -0000, "Robert M. Gary" wrote:
On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? Correct, but only when performing those tasks that require use of a Recreational or higher license. A Sport Pilot can climb into the airplane and fly day VFR, but if he's going to go on the gauges he needs the appropriate license and rating (and medical to go with the license). The FAA made a big terminology mistake with the new rules; they use the same term for a *definition* as for an aircraft certification category. Any aircraft meeting the 14 CFR Part 1 definition for "Light Sport Aircraft" can be flown by a pilot exercising Sport Pilot privileges, whether it's a Private pilot with an expired medical, or a person with the new Sport Pilot rating. This definition is summarized at: http://www.bowersflybaby.com/tech/sportpilot.jpg However, the FAA also added "Light Sport Aircraft" as a certification category, both as "Special" and "Experimental." These are aircraft that comply with the ASTM standards. There's nothing that I know of that precludes aircraft in these two categories from flying IFR if properly equipped AND with a pilot with appropriate ratings at the controls. The ASTM standard has a required minimum for instruments and equipment (which, in fact, requires less instruments than Part 91 for day VFR) but does not define a maximum. Ron Wanttaja |
On Oct 15, 10:27 am, Ron Wanttaja wrote:
So then I assume the pilot would need a current class 3 medical, correct? Correct, but only when performing those tasks that require use of a Recreational or higher license. A Sport Pilot can climb into the airplane and fly day VFR, but if he's going to go on the gauges he needs the appropriate license and rating (and medical to go with the license). In this case the task of flying IFR requires at least a private rating so a class 3 medical seems to be required. The FAA made a big terminology mistake with the new rules; they use the same term for a *definition* as for an aircraft certification category. Any aircraft meeting the 14 CFR Part 1 definition for "Light Sport Aircraft" can be flown by a pilot exercising Sport Pilot privileges, whether it's a Private pilot with an expired medical, or a person with the new Sport Pilot rating. This definition is summarized at: I understand that. In fact that was my point. A LSA can be IFR certified but in order to fly it a pilot now must have a medical. So the idea of letting your medical lapse when you get old and buying an LSA only works for VFR. For IFR you have to exercise the priv of an instrument rated private pilot and not the priv of a sport pilot. -Robert |
On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. |
Gig 601XL Builder wrote:
Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt |
Matt Whiting wrote:
Gig 601XL Builder wrote: Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt Then follow that link up there the 601XLi might be just the plane for you. |
Matt Whiting wrote: Gig 601XL Builder wrote: Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt Then follow that link up there the 601XLi might be just the plane for you. Except that the wing is in the wrong place! Matt |
Matt Whiting wrote:
Then follow that link up there the 601XLi might be just the plane for you. Except that the wing is in the wrong place! Matt Keep on the look out for the Zenith Patriot. It is going to be an LSA only (no kit) high wing. |
Matt Whiting wrote: Then follow that link up there the 601XLi might be just the plane for you. Except that the wing is in the wrong place! Matt Keep on the look out for the Zenith Patriot. It is going to be an LSA only (no kit) high wing. This one here? http://www.sport.aero/index2.html Looks interesting. Matt |
If you are a Cessna pilot, you'll LOVE the Tecnam line of IFR available
LSAs. We have an Echo on the line. It is super stable, super roomy, and has a super useful load. We have a 6'9" 310lb student taking lessons in it with a 200lb instructor! It has the stability you need for IFR, and useful load you need for long range tanks if you are going to fly hard IFR. Best of all, you won't sacrifice roominess. It's every bit as comfy as a 172. The IFR certified Rotax 912S burns about 4 gph, mo gas preferred. Available glass or traditional. The new 2008 panel is superb, available glass or traditional, and complete with cup holder. http://www.tecnamaircraft.com/Tecnam_Aircraft.htm http://www.chesapeakesportpilot.com/sales.htm Helen Matt Whiting wrote: Gig 601XL Builder wrote: Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt |
Cessna's new LSA: "Skycatcher" | Jim Logajan | Piloting | 107 | September 23rd 07 01:18 AM |
Cessna's new LSA: "Skycatcher" | Jim Logajan | Owning | 110 | September 23rd 07 01:18 AM |
Cessna's new LSA: "Skycatcher" | miffich | Piloting | 1 | July 24th 07 12:04 AM |
