How do you plan the descent in emergency landing practice?
Old October 15th 07, 08:31 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Default How do you plan the descent in emergency landing practice?
Knowing your power-off descent rate will help. In my plane, I know that
my power off descent rate at best glide speed is about 50% higher than the
500 ft./min rate that I generally use in a normal pattern. If I arrive at 1,
000 ft. AGL abeam of my landing spot. I know that I'll have to make an
abbreviated pattern to make the runway. I also aim for a spot a several
hundred feet down the landing area to prevent landing short. The sight
picture through the windshield on final will tell you where you're going to
go. If you're overshooting, your landing spot will move down. If you're
coming up short, the landing spot will move up in the windshield. I try to
overshoot slightly as I turn final, then adjust the descent rate with a hard
slip to put it down at the near edge of the landing area.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200710/1
Old October 17th 07, 09:52 PM posted to rec.aviation.piloting
Cubdriver
On Mon, 15 Oct 2007 19:31:04 GMT, "JGalban via AviationKB.com"
This whole discussion sounds like an argument against power-on
approaches.
I was taught power-on by a former military pilot. Then he went off to
the airlines and my new, older, civilian-trained pilot instructed me
to go throttle all the way back at the numbers, then fly the rest of
the pattern without any more power than it took to "clear" the engine
from time to time.
Blue skies! -- Dan Ford
Claire Chennault and His American Volunteers, 1941-1942
new from HarperCollins www.FlyingTigersBook.com
Emergency landing at airfield Danny Deger Piloting 10 January 8th 07 06:31 PM
Emergency landing theoretical gatt Piloting 21 May 15th 06 03:07 PM
Live emergency landing on tv right now C. Massey Piloting 7 May 4th 06 02:49 AM
C-141 emergency landing Christchurch Miche Military Aviation 11 February 6th 04 04:04 AM
N30793, Emergency Landing Tom Hughes Piloting 5 August 21st 03 03:56 AM
