A-4 / A-7 Question
Old October 12th 03, 09:57 PM
Daryl Hunt
" wrote in message
ink.net...
Replacement_Tommel wrote:
Daryl Hunt
says...
"Replacement_Tommel"
'SINVA LIDBABY
wrote in
message ...
Tell the USAF that... for awhile they wanted to get rid
rid of the
A-10 and were pushing the "A-16" - picture a F-16 in
green
camoflage with a 30mm
gatling gun pod on its center hardpoint.
CAS simply isn't something taken seriously by the USAF.
You tell the AF that.
Oh, they already know it.
"Not a pound for air to ground" as the Fighter Mafia used
to like to
say... (funny how you don't hear about a "CAS Mafia,"
huh?)
They aren't buying anymore A-10s for a good reason.
They aren't sexy enough, so the USAF just ignored it and
hoped it
would die.
Even the USAF A-10 pilots say that the USAF is ignoring the
A-10 and hoping it'll go away.
Of course. It's the end of a way of life. The A-10 owes much of it's life
to the Skyraider. Ever been "Had by a Spad?"
snip
It's mission died with the fall of the iron curtain.
As did the F-22's and the (especially) the B-2's yet the
USAF doesn't
want to drop them does it?
No, the A-10s mission really began in Desert Storm when we
found out that it could do so much more than bust tanks.
The A-10 and AH-64 make a credible team for dealing with
hardened targets like bunkers and other defense works. It
is also an outstanding weapon in Close (and I mean close)
air support of ground operations providing covering fire as
effective (maybe more effective) as artillery and is more
versatile in "Danger Close" support missions because of its
ability to fly slow enough for the pilot to properly
identify ground targets. The A-10 can fly at altitudes
where the AH-64 is not effective such as the Hindu Kush
where they could be called against caves, stone works and
other defensive positions.
And so can the F-16 in ground loadout.
The major power with the Main Battle Tanks the A-10 was
designed to
combat
can't even get the fuel to drive them anymore.
So why does the USAF want the F-22 and B-2 then? The
Russian Air
Force is a joke, and it's not bloody likely that we need
to nuke them
anytime soon...
The A-10 has a current mission and is more capable of
performing it than any other aircraft whether fixed or
rotary winged.
What mission? It's main role for Tank busting was done by Bombers.
Everything else, the F-16 and the F-18 can do with a normal load for ground
support.
And the F-16 can completely fill the role
The USAF dropped the "A-16" idea because they knew nobody
was daft
enough to buy it...
It can't fly slow enough and it can't direct gunfire
accurately enough. The numbers of "blue on blue" incidents
with F-16s should be enough to tell anyone that.
You seem to forget the number of A-10s as well. The 16 and the 18 can slow
down to 200 kts like the A-10 can and still deliver the load.
the A-10 was supposed to do (and never did).
Desert Storm and Operation Iraqi Liberation?
Add Operation Enduring Freedom and Operation Just Cause.
All of which have proven (at least to the US Army, US Navy
(hence A-12) and USMC that the A-10 is an excellent aircraft
with a continuing mission in Close Air Support.
You are using ground pounder PR. It's not going to save the A-10. The only
reason they use it is that it's paid for. It saves a tremendous amount of
money than buying the support equipment for the F-16. When each 10 comes
offline, a 16 more than steps up to the plate.
Life expectancy of an A-10 against almost any Mig or SU
is about 30
seconds.
The A-10 isn't a fighter, right?
Do we expect that we will be unable to provide CAP and air
superiority anytime soon?
And if we go against a Military with a decent AF, what then? Do we just
leave you ground pounders to fend for yourselves until AS can be
established? Do we leave the A-10 home until then? What happens if there
is no forward Air Fields? The Forward AFs become the Carriers (F-18) and
the AF F-16s with external tanks. The A-10 sits out of range. North Korea
is a prime example.
And why does the USAF want to keep the AC-130? It's
s-l-o-w, b-i-g,
can't fight Migs... damn that thing is WORSE than an
A-10!!!
This is typical fighter mafia mentality - look downwards,
because man
lives on the ground and not up in the clouds. It's the
ground battle
that's paramount.
Life expectancy of a F-16 all depends on the Pilots.
Life expectancy of an A-10 depends on the skill of the
Pilots as well. Or didn't you read about how they were
employed as "deep strike" aircraft in Desert Storm?
Yes, that skill was used by the Skyraiders as well. Evade or Die.
Old October 13th 03, 01:39 AM
Replacement_Tommel
In article , Daryl Hunt says...
(snippum)
" wrote in message
link.net...
(snip)
Tell the USAF that. I've been reading a few new articles and the USAF claims
that the A-10 will be in their inventory until 2028. They are even (finally)
updating it.
When we got involved in Vietnam, the USAF (once again) found itself without a
suitable attack aircraft - one that could carry gobs of ordinance, was slow and
had a long loiter time... and once again the USAF had to take a USN aircraft,
the A-1 Skyraider, to fufill a role that they neglected...
(snip)
If the USAF lets them. The USAF has a tendency to keep their sexy jets away from
CAS because it doesn't want to get their pretty jets hurt.
From what I saw, the A-10, although slower than a F-16, can do two attack runs
in the same time a F-16 can do one. The A-10 can loiter better than the F-16.
(snip)
Nonsense. 80% of the MBTs taken out in Desert Storm were done by A-10s - even
the USAF has damitted that (USAF General Horner remarked that he took back
everything bad he said about the A-10 because it "saved his ass.")
support.
F-16s pilots do not practice CAS enough.
was daft
enough to buy it...
The A-10 can go down to about 110 knots. It's got some big ass boards on its
wings so that it can slow down effectively - the F-16 doesn't have that. The
A-10 is also more maneveurable than a F-16 at these speeds.
And unlike the F-16, the A-10 is a relatively "quiet" aircraft and is more adept
at sneaking up to mobile ground targets than a F-16 is (I know this cause one
snuck up on me at one time...).
2028?
(snip)
is about 30
seconds.
What are those F-22s and F-15s for?
Do we just leave you ground pounders to fend for yourselves until AS can be
established?
F-22s and F-15s can't fly escort for A-10s?
Odd thing about the A-10... it can fly off relatively unimproved airfields... if
we did go up against some country with a **** Hot Air Force, it'll be the F-22s,
F-16s, and F-15s that'll be grounded because their air bases and runways have
been shot up.
The A-10, OTOH, will be flying from makeshift runways...
is a prime example.
See above.
There were USAF A-10s at Bagram Air Field in the Sandbox, but there sure as hell
weren't any USAF F-16s there...
-Tom
"For the cause that lacks assistance/The wrong that needs ressistance/For the
Future in the distance/And the Good that I can do" - George Linnaeus Banks,
"What I Live for"
UMA Lemming 404 Local member, 404th MTN(LI)
Old October 13th 03, 03:18 AM
Daryl Hunt
'SINVA LIDBABY wrote in message
says...
(snippum)
" wrote in message
link.net...
(snip)
claims
(finally)
updating it.
without a
slow and
aircraft,
You really need to get a new schtic. This one is stail and quite uniformed.
The AF didn't get it from the Navy, they got it from the boneyard where the
Navy put them in the first place. Then again, quite a few AC were retired
to the Boneyard only to find themselves back on duty. Like the C-124
Globemaster.
(snip)
away from
Again, ask the Elite Guard that was outside Bagdad. Oh, that's right. They
are all dead from things falling on their heads and going boom.
runs
F-16.
Then you need to see better. Both can do more than 2, I assure you. The
difference is, the F-16 has a higher survivalbility rate due to it being
able to slow down to 200 kts and then speed up to Mach if need be to exit.
The 10 doesn't have to slow down. It's already slow.
(snip)
even
I don't know where you got your info (you made it up, of course) but the
Buffs were nailing the Republican Guard Armor with Carpet Bombing long
before you characters set foot in even Saudiland.
ground
support.
I suggest you voice you concerns to the Head of the Air Force. He could use
a nice bit of humor. And since when does anyone in the Military get enough
Battle Practice anyway? I suggest you learn to read roadmaps.
was daft
enough to buy it...
slow
its
The
At 110 kts, you can knock it down with a handgun. At 200 KTs it's a bit
harder to hit it and no pilot in their right mind slows down much below
that. Those that are not in their right mind and slow it down to stall
speed are dead.
adept
one
Yup. Except when the 16 closes, it's usually running at a speed where the
sound is reaching the ground just behind the AC passing. The Doppler affect
makes it appear to be dead quiet. If you heard it, you weren't the target.
2028?
Is that a REg or your hat size?
(snip)
is about 30
seconds.
Newsflash, we don't have enough F-15s and just how many F-22s do you think
are in the active duty inventory? We could have used the F-14 during
Vietnam but didn't.
be
established?
Why would they need to. The 16 doesn't need the cover nearly as much. The
A-7s often flew with no Topcap. And the Mig Pilots learned to leave the
Sluf alone due to a high deathrate of their own.
airfields... if
F-22s,
have
been shot up.
Rave on. Name one place on the earth that the F-15 with Conformal Packs,
the F-16 with external tanks and the Tankers can't get to. There isn't one
place on earth.
Without the F-15s, 16s and such, the A-10 will be parked on a very
comfortable Airfield well behind the lines. Completely out of range where
the Junk 1950s Fighters from a 3rd rate AF can't get to them and blow them
all to hell and gone.
Korea
is a prime example.
See above.
See above.
as hell
Newsflash, there also was no opposing Air Force either. It had already been
plowed away to nothing or thought better of taking off. Attack that A-10
and you get a frontline Fighter on your way in. You won't make it.
Old October 13th 03, 04:38 AM
redc1c4
Daryl Hunt wrote:
(snipage occurs, fore and aft)
Vietnam but didn't.
really? that appears to be news to most folks:
Three early F-14As were delivered in the autumn of 1972 to VX-4 at NAS
Point Mugu, California for operational evaluation. The replacement
squadron VF-124 at NAS Miramar received its first Tomcats in June of
1972.
The job of VF-124 was to train Tomcat crews for duty with operational
carrier-based squadrons. The first two operational Tomcat squadrons
were VF-1 Wolfpack and VF-2 Bounty Hunters, both based at NAS Miramar.
These units deployed aboard the USS Enterprise (CVN-65) in mid-1974.
http://www.csd.uwo.ca/~pettypi/elevo...r_us/f014.html
redc1c4,
do you enjoy getting caught lying, or are you just stupid?
A Troop - 1st Squadron
404th Lemming Armored Cavalry
"Velox et Capillatus!"
Old October 13th 03, 04:24 AM
Replacement_Tommel
'SINV ALIDBABY wrote in message
says...
runs
F-16.
You need to read better.
"In the same time..." means in the same amount of time, an A-10 can do two
attack runs whereas the F-16 will only do one.
even
Tell the USAF that:
http://www.airpower.maxwell.af.mil/a...4/fedor2a.html
"Although they represented less than 10 percent of the coalition's air assets,
A-10s were responsible for about 70 percent of the armored vehicles destroyed by
coalition air forces.32 During the latter part of the ground war, Lt Gen Charles
A. Horner, the joint force air component commander (JFACC), stated bluntly, "I
take back all of the bad things that I said about the A-10. I love them! They
saved our ass."33 Furthermore, a captured Iraqi officer reported that the
"single most recognizable and feared aircraft at low level was the A-10.
Although the actual bomb run was terrifying, the aircraft's loitering around the
target area caused as much, if not more, anxiety since the Iraqi soldiers were
unsure of the chosen target."34 Another source reported that A-10s killed over
50 percent of all enemy tanks, more than 50 percent of all field artillery
pieces, and 31 percent of all armored personnel carriers. Interestingly enough,
they also accounted for more air-to-air combat kills than the multirole F-16
Fighting Falcon.35 Clearly, the A-10s were decisive combat multipliers on the
battlefield and were instrumental in minimizing US ground losses in the ground
campaign that liberated Kuwait. And, once again, the Air Force used B-52s in the
BAI role to bomb Republican Guard positions as well as troop or equipment
concentrations.36"
32. "`The Air Campaign' Videotape Script," in Air Command and Staff College
Seminar/Lesson Book, vol. 9 (Maxwell AFB, Ala.: Air University, 1993), 37-51.
33. Smallwood, 96.
34. Ibid., 203.
35. "Letters," Air Force Magazine, September 1991, 9-10.
36. Hallion, 221.
It's also in "White Paper - Air Force Performance in Desert Storm, Department of
the Air Force, April 1991."
Next thing you know, you'll be telling me that the Russians have a three stage
SAM...
-Tom
"What I Live for"
Old October 13th 03, 06:59 AM
Daryl Hunt
says...
message
says...
attack
runs
F-16.
And the A-10 Pilot is more than twice as vulnerable to everything. You sure
put a low price on a Pilots Life.
A-10s -
even
back
Tell the USAF that:
mercy snip
You will not that it said "Ground Vehicles". If the A-10 had done the bulk
of the Armor killing as you have claimed, it would have made that claim.
Ground Vehicles consist of trucks more than anything else. And ANY type of
A or F could do this. Bring back the OV-10 or the armed version of the O-2
and they could do it as well. The A-10 was primarily used AFTER the
Fighters and Bombers killed the Armor and made everyone put their heads
down.
End of discussion, Troll Boy.
Old October 13th 03, 02:57 PM
Replacement_Tommel
says...
(sbip)
A-10s - even the USAF has damitted that (USAF General Horner remarked that
he took back everything bad he said about the A-10 because it "saved his
ass.")
Tell the USAF that:
mercy snip
Huh?
A-10s were responsible for about 70 percent of the (Look Daryl ------) ARMORED
(----look Daryl) vehicles destroyed by coalition air forces.32 During the
latter part of the ground war, Lt Gen Charles A. Horner, the joint force air
component commander (JFACC), stated bluntly, "I take back all of the bad things
that I said about the A-10. I love them! They saved our ass."33 "
(----look Daryl) vehicles destroyed by coalition air forces."
The article says "ARMORED" vehicles.
Armored vehicles consist of MBTs, SPA, and APCs.
Your reading skills are pitiful.
-Tom
"What I Live for"
Old October 13th 03, 10:24 PM
Daryl Hunt
says...
message
says...
(sbip)
that
"saved his
ass.")
Tell the USAF that:
mercy snip
Huh?
assets,
ARMORED
air
things
assets,
ARMORED
Nope. But most of the armor was destroyed even before the A-10 arrived.
The Bombers and Fighters took them out. Now, is he had said that 80% of the
Armor was destroyed that was left, I would put more credence in his
statements. Don't you recognise PR and Politicing when you see it? This
was NOT an official Air Force Statement.
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
