On Oct 15, 9:03 pm, "news.west.cox.net"
wrote: I have a 1966 Cessna 172G and some replacement plastics from Vantage Plastics. There are a number of missiong screws on the existing interior, and the perfectionist in me is wanting to replace them along with the plastics. Can anyone out there recommend the screw sizes that are typically used for a Cessna interior? Vantage sells quantities of stainless screws and washers, but I would like to either get a kit or minimize the number of different screws that I have to order. TIA, Jake Typically #4 x 3/8" or so, but you might also find #6 and #8 screws. They are driven into the aluminum itself rather than anchor nuts, and as the holes wallow out they are usually replaced with bigger screws. Cheap setup. And to do the annual/200 hour inspections you have to remove the interior stuff, which just tears those holes to bits over the average airplane lifetime if you do the maintenance properly. I wish Velcro had been available when they designed the airplane. Dan |
you have to remove the interior stuff, which just tears those holes to bits over the average airplane lifetime if you do the maintenance properly. You have to remove the interior panels of a 172 to do an annual inspection? Dang. Makes me happy to own a Piper, where all we have to do is remove (in the passenger compartment) the seats, the flap handle cover, the back seat floor panel, and the rear bulkhead. -- Jay Honeck Iowa City, IA www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jay Honeck wrote: You have to remove the interior panels of a 172 to do an annual inspection? No, usually just the front two panels because that's where the fuel lines run and there's some control cables in there. The front seats have to come out but not the rear. |
Newps wrote:
Jay Honeck wrote: You have to remove the interior panels of a 172 to do an annual inspection? No, usually just the front two panels because that's where the fuel lines run and there's some control cables in there. The front seats have to come out but not the rear. Actually, on the 172, the aileron cables run up the rear door posts, as do flap cables on the manual flap models. If you don't remove the rear seat, accessing these areas can be very difficult. Happy Flying! Scott Skylane |
On Oct 16, 3:32 pm, Scott Skylane wrote:
Newps wrote: Jay Honeck wrote: You have to remove the interior panels of a 172 to do an annual inspection? No, usually just the front two panels because that's where the fuel lines run and there's some control cables in there. The front seats have to come out but not the rear. Actually, on the 172, the aileron cables run up the rear door posts, as do flap cables on the manual flap models. If you don't remove the rear seat, accessing these areas can be very difficult. Happy Flying! Scott Skylane There are elevator and rudder cables and pulleys under the entire length of the 172's floor. If you don't yank the rear seat, you can't get the carpet up and take the inspection panels off. Every time we get another second-hand 172 we find the pulleys under there seized, cables worn, an incredible amount of junk including mouse nests and droppings (corrosive), dirt, oil, small stones (tracked in by people), rags and lost hardware (risk of cable/pulley fouling), and so on. Sometimes even tools. The bottom end of the aft doorposts (immediately ahead of the aileron cable pulley in that corner) has a tendency to crack in the angle cutout. It's difficult enough to see the area with everything pulled out, impossible without it. Any 172 with more than two or three thousand hours is likely to be cracked in that spot, both sides, and certainly cracked if it has seven or eight thousand. Cracks sooner if operating off rougher surfaces. Cessna sells a reinforcement kit, but it's a stinker to install. They say it's 20 man-hours per side, and we've found that not far off. After we do a couple more we'll get that down. If you don't drop the headliner at least partway you can't inspect the rubber fuel line connections. They harden and crack with age and start leaking. Guess what you'll find someday when you go to fly your airplane? Or maybe they'll start leaking in flight. Had that happen once in an old 180. And the aluminum lines are often not properly located and are chafing against the holes in the doorpost on their way from the wing root, down past the aileron cable and into the floor. The bulkhead at the back of the forward baggage compartment (or the back of the only compartment if it's a 172L or earlier) has cracking problems, usually in the lower corners near floor level. Got to take all the plastic out of there to get a good look. If you don't take the rudder bar covers out, you can't get a look at the bar bearings (they need lubing) or the fuel line where it goes through the firewall (the RH steering rod comes awful close and can chafe it. Could create nasty surprises in flight). Some airplanes have had trouble with loose bar bearings or broken brake master cylinder bracketry. If you don't remove the side panels forward of the door you can't see inside those doorposts. They like to crack around the door hinge attach points and you can't see it on the outside. It's the doorpost itself that cracks, inside the skin, in the bend radius by the rivet line. Bottom hinge is worst, 1975 and later is worse, too. Don't know why. If you don't take the plastic console off you can't get a good look at the trim mechanism, the aileron, trim and rudder pulleys (more seizures, possibly fraying cables) and the fuel valve u-joints, which have stupid little rivets that gradually wear out and could leave you with no fuel control. The skin and internal structure at the little fuel access step forward of the door sometimes cracks. Got to have the rug up and panels out to see that. There's no substitute for taking the time to do it right. We do it, it takes a couple hours longer, but we seldom have any snags in between inspections. And we're always surprised, even though we shouldn't be, at how easily all the controls move after we've cleaned everything, freed up all the pulleys and bellcranks, and set all the cable tensions to spec. Dan |
![]() wrote in message oups.com... There are elevator and rudder cables and pulleys under the entire length of the 172's floor. If you don't yank the rear seat, you can't get the carpet up and take the inspection panels off. Every time we get another second-hand 172 we find the pulleys under there seized, cables worn, an incredible amount of junk including mouse nests and droppings (corrosive), dirt, oil, small stones (tracked in by people), rags and lost hardware (risk of cable/pulley fouling), and so on. Sometimes even tools. ..... There's no substitute for taking the time to do it right. We do it, it takes a couple hours longer, but we seldom have any snags in between inspections. And we're always surprised, even though we shouldn't be, at how easily all the controls move after we've cleaned everything, freed up all the pulleys and bellcranks, and set all the cable tensions to spec. Dan Nice write up! Thanks! Dan D. |
Stuck panel screws | [email protected] | Owning | 10 | July 7th 06 12:51 AM |
FAA Screws Up Again | BushOKDemocratsSTUPID | Instrument Flight Rules | 2 | March 22nd 06 10:39 PM |
Microair Transponder brass screws? | abripl | Home Built | 7 | July 13th 05 06:40 PM |
Media screws up again... | Sam | Piloting | 181 | June 17th 04 06:08 PM |
Avsim screws itself | Azhosers | Simulators | 2 | April 5th 04 10:32 PM |
