Blended-wing Airliner
Old October 18th 07, 12:48 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Blended-wing Airliner
Mxsmanic wrote in
Neil Gould writes:
That ratio isn't all that different from today's aircraft, is it?
Even with ten across, the ratio is 1 in 5. In smaller aircraft it is
higher.
Where do the emergency exits go? Which airports will be constructing
completely new gates for these aircraft? How long does it take to
replace an engine? Where do you board the aircraft? Where does the
cargo go?
Whgat's it matter? you don't fly and you never will?
I'm sure that noise reduction alone cannot justify this aircraft. If
the gain in fuel is really 35%, that could work strongly in its favor
(it would have to be verified with real-world prototypes), but
probably not enough to overcome many other issues, only a fraction of
which have been mentioned above.
Good grief, it's a clueless vortex.
Bertie
Boeing Flies Blended Wing Body Research Aircraft Larry Dighera Piloting 28 August 3rd 07 07:51 PM
X-48B Blended Wing Body Research Aircraft Takes First Flight [1 attachment] §qu@re Wheels[_4_] Aviation Photos 5 July 30th 07 06:17 AM
Design merit of blended wing aircraft Rob Mohr General Aviation 0 June 13th 04 02:45 PM
Blended wing bodies and sailplanes...? Robert Bates Soaring 8 December 23rd 03 09:34 PM
Hitting airliner with rifle round? [was: PK of Igla vs. airliner] B2431 Military Aviation 7 August 20th 03 11:29 PM
