Engine out practice
Old October 19th 07, 12:05 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Bertie the Bunyip[_19_]
Default Engine out practice
Matt Whiting wrote in
J.Kahn wrote:
It's not a problem when heating because the head expands faster than
the steel parts so the stress effects are reversed. This is why the
manufacturers have no problem with going from idle to full power as
soon as the engine will take it without stumbling. There is no such
thing as shock heating...
What about the aluminum piston in the steel cylinder?
That can happen too! But the clearances are cgrater ther than it would be
in a valve stem or head to cylinder seat.
Bertie
Old October 20th 07, 01:55 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Roger (K8RI)
On Fri, 19 Oct 2007 11:05:32 +0000 (UTC), Bertie the Bunyip
If we had that kind of piston to cylinder clearance in an automotive
engine we'd think it was worn out. :-)) At least in the "old days".
Roger (K8RI)
Bertie
Old October 20th 07, 02:39 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Roger (K8RI)" wrote in
than the steel parts so the stress effects are reversed. This is
why the manufacturers have no problem with going from idle to full
power as soon as the engine will take it without stumbling. There
is no such thing as shock heating...
be in a valve stem or head to cylinder seat.
Yes, some air cooled engines have tapered bores (when cold) to allow for
different rates of expansion in cylinder base-to-head so that it's
perfectly cylindrical when up to temp, but i don't know of any aircraft
engines that have that feature.
Bertie
Old October 20th 07, 04:10 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Morgans[_2_]
Really? I thought that they did have a tighter bore at the top. I guess I
read wrong, or remember wrong.
Jim in NC
Old October 20th 07, 11:09 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Morgans" wrote in
for different rates of expansion in cylinder base-to-head so that
it's perfectly cylindrical when up to temp, but i don't know of any
aircraft engines that have that feature.
guess I read wrong, or remember wrong.
Maybe. I didn't know that they did. It would make sense if they did, all
right. I don't do machining. I just run my fingers over the pretty parts
when they come out of the machine shop!
Bertie
Old October 20th 07, 11:41 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Morgans[_2_]
This ought to be an easy question for someone in the group. Surely, there
is someone that does do machining on engines that hangs out here, that would
know for sure.
Anyone?
Jim in NC
Old October 20th 07, 01:07 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
know for sure.
Anyone?
Jim in NC
Ok, First off don't call me Surely. GGGG.
The concept is question is called "choke bore" and the idea is the
bottom of the cylinder that's close to the case runs at a much lower
temp since combustion happens at the other end. The top end grows at a
greater rate because of this. In theory when the engine is up to temp
the cylinder ends up being pretty straight. I have the specs around
here somewhere but if I remember correctly the bore when cold is in
the .006-.008 smaller at the top. Boring one is usually done by using
a tool post grinder and performing the taper feature is a calculated
process. Honing one with a flex hone is straight forward and easy,
using a Sunnen CK-10 or a CV-616 takes ALOT more practice...
Ben
www.haaspowerair.com
Engine out practice Jay Honeck Piloting 155 November 9th 07 03:07 AM
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc Immaterial Aviation Photos 0 January 6th 07 09:15 PM
Topi - Mig29 engine failure during practice - "topi.wmv" (09/26) 6.0 MBytes yEnc Immaterial Aviation Photos 0 January 6th 07 09:15 PM
Practice Engine-Out Landings Jay Honeck Piloting 52 July 14th 05 10:13 PM
A PIREP: engine-out turn-back - some practice in the haze Nathan Young Piloting 15 June 17th 05 04:06 PM
