#21
BradGuth wrote:
On Oct 16, 6:51 am, Mike wrote: [snip] If the object is to spend the most possible in order to kill off as many humans as possible, why not just stick with using VX dirty cluster bombs? - Brad Guth - Cluster bombs are not very effective agaist flying aircraft. Andrew Swallow |
Vince wrote:
Also under consideration is a redesign of the V-22’s nose to accommodate a chin gun, Birkholz said. “It’s all do-able,” he said. “It’s just expensive.” http://www.nationaldefensemagazine.o.../V-22_Aims.htm it wasn't doable you can hang it on the belly at the center of lift, that is where they put the cargo hook http://www.defenseindustrydaily.com/...ng_M777_lg.jpg Delete the hook. Any mission that the V-22 can use the hook for the H-53 series can do better. For any mission that doesn't include a sling load the V-22 flies faster, higher and further. -HJC |
Henry J Cobb wrote:
Vince wrote: Also under consideration is a redesign of the V-22’s nose to accommodate a chin gun, Birkholz said. “It’s all do-able,” he said. “It’s just expensive.” http://www.nationaldefensemagazine.o.../V-22_Aims.htm it wasn't doable you can hang it on the belly at the center of lift, that is where they put the cargo hook http://www.defenseindustrydaily.com/...ng_M777_lg.jpg Delete the hook. Any mission that the V-22 can use the hook for the H-53 series can do better. For any mission that doesn't include a sling load the V-22 flies faster, higher and further. -HJC no it doesn't Carry 5 tons as far as you can and drop it off Carry 10 tons as far as you can and drop it off Carry the biggest payload you want 200 miles Who wins? Vince |
On Oct 17, 8:13 am, Dan wrote:
BradGuthwrote: snip There are multiple species of humans on Earth, with some way dumber than others. Not all humans are Zion Yids, and not all smart Yids are Third Reich. Go figure. - Brad Guth So, how long have you been this afraid of Jews? Hitler was actually a fairly good Jewish puppet, much like our resident LLPOF warlord(GW Bush), and I'm still afaraid of what either of those two incest cloned *******s have accomplished. Obviously you and others of your semitic Third Reich kind could care less about the past, present or future, that is as long as it's semitic dominated. - Brad Guth - |
On Oct 17, 8:50 pm, Andrew Swallow wrote:
BradGuthwrote: On Oct 16, 6:51 am, Mike wrote: [snip] If the object is to spend the most possible in order to kill off as many humans as possible, why not just stick with using VX dirty cluster bombs? - Brad Guth - Cluster bombs are not very effective agaist flying aircraft. Muslims don't have any such flying aircraft. So, what's your point? Arnt you semitic (aka pretend atheist) folks going for the absolute maximum of Muslim population extermination? - Brad Guth - |
BradGuth wrote:
On Oct 17, 8:50 pm, Andrew Swallow wrote: BradGuthwrote: On Oct 16, 6:51 am, Mike wrote: [snip] If the object is to spend the most possible in order to kill off as many humans as possible, why not just stick with using VX dirty cluster bombs? - Brad Guth - Cluster bombs are not very effective agaist flying aircraft. Muslims don't have any such flying aircraft. So, what's your point? They don't? How about Pakistan, Saudi Arabia, Egypt, Syria, Iran etc? Dan, U.S. Air Force, retired |
On Oct 16, 4:31 pm, BradGuth wrote:
On Oct 16, 6:51 am, Mike wrote: Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. There's little agreement on when such a gun might arrive, but at least one major defense company is spending its own money to compete for the job. A nose gun was considered early in the tilt-rotor's two-decade gestation but was branded too costly, Air Force requirements officials said. The fiscal 2008 supplemental request includes $82 million for research, development and testing of an "all-quadrant," or 360-degree, defensive weapon to augment the ramp-mounted 7.62mm machine gun the Marines use for now. Navy program spokesman James Darcy said there is no timetable for finding such a gun, and the search will be bound by finances and the plodding acquisition process. "SOCom is looking at a faster turnaround," Darcy said. "But Air Force Special Operations Command is flying a different mission than the Marine Corps." The squadron of 10 Marine-owned Ospreys now in Iraq will be used largely to transport troops, equipment and supplies. The Air Force, which handles the tilt-rotor program for U.S. Special Operations Command, is buying the plane for long-range special ops missions. While the Air Force's CV-22s are not slated to hit the desert until 2009, the service's Chief of Staff Gen. T. Michael Moseley is considering deploying his aircraft earlier. In September, SOCom announced the search for an "interim all-quadrant defensive weapon system" for its CV-22 tilt-rotors, with the intention of flight-testing such a weapon within 120 days of the contract award. "We both have a requirement for some sort of defensive weapon system," said Air Force Lt Col. Chet Treloar, deputy director for mobility and special operations requirements. But for the most part, those requirements are intentionally vague, he said, leaving the door open for industry to be as innovative as possible. It is not even specified whether the system should be fully integrated into the aircraft in the future or if a drop-in solution is the best plan. "There are advantages and disadvantages to total, permanent integration," said Air Force Maj. Rob Pittman of the Air Force acquisition office. "The quick-and-dirty solution that gets the job done might be the answer." Pittman, Treloar and Darcy said the requirements are joint Marine-Air Force requirements and the expectation is that everyone will get the same weapon. But they added that nothing has been decided except the requirements. "There's no competition yet and there's been no selection yet," Darcy said. "It's possible that the solution may be different" for different versions of the V-22, Pittman said. "But we push for as much commonality as possible." "I don't think we're there yet" as to what the final solution will be, Treloar said. "But the Air Force and the Navy and the Marine Corps are committed to keeping the troops safe. They want to deploy this aircraft tin a way that is as safe and effective as possible." BAE jumping the gun Meanwhile, BAE Systems has been spending its own money to develop the Remote Guardian System, a turreted, remote-operated, retractable weapon that could be fielded in the third quarter of 2008 and fitted aboard the V-22 and other aircraft, said Clark B. Freise, vice president and general manager of defense avionics for BAE. "We've been investing for two years and created our own program to develop the capability," Freise said. While Freise would not say how much BAE has spent or how much it would charge per weapon, he did say the price would be low enough to appeal to the Pentagon and high enough to recoup its investment. "We spent a lot of money on it," he said. "We found a hole in their protection, we're covering it for now, and we'll get it back. We'd rather not say how much we've invested. We have shared with the Marine Corps what we think it will cost to go into production, and it is significantly lower than other solutions." So far, the Remote Guardian has been tested only while mounted on a Humvee, but Freise said it has fired various U.S. weapons and is currently cleared to handle 300 knots and four times the force of gravity. Guns can include a 7.62mm Gatling gun, a .50-caliber machine gun and more, he said. He said it has an easily upgradeable sensor suite. A concern with any 360-degree system, especially a remote-firing one, is taking a shot at your own propeller or landing gear. According to BAE, that is not a risk with Remote Guardian. "The gun will never, ever point at a part of the aircraft. We integrated the safety keys into the design from the very beginning," Freise said. My God! (are we good at killing innocent hummans, or what?) - Brad Guth People trying to kill you are not innocent. If you actually look at things, you'll see the idea of avoiding killing civilians is a great concern to the US, even to where more US troops get put at risk tuhan might otherwise. Civilians are targeted by the enemy, who would also kill you if they could. Modern turreted guns on aircraft, with modern sighting and stabilizers, can be directed with good precision. Hardy a cluster bomb, or the terrorist's market place bomb or bombs like were used to attack Benazir Bhutto's convoy in Pakistan recently. That is indiscriminate killing, and where you should focus your attention sometime. |
#28
On Oct 16, 7:35 pm, Vince wrote:
David Lesher wrote: Mike writes: Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. Strange no one is discussing how much such weighs; in an airframe already short of payload... and balance its a side to side prop-rotor configuration hang a thousand pounds on the chin and see what happens There could weight to play with in the tail, or a way to counterbalance by moving some equipment inside. They modified the B-17 OK, but they had a lot more relative weight to play with. Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including ammo.) Wonder what they will hang on there? A .50 or twin .50 could work. 7.62 minigun? Vince- |
#29
On Oct 21, 2:27 am, BradGuth wrote:
On Oct 17, 8:50 pm, Andrew Swallow wrote: BradGuthwrote: On Oct 16, 6:51 am, Mike wrote: [snip] If the object is to spend the most possible in order to kill off as many humans as possible, why not just stick with using VX dirty cluster bombs? - Brad Guth - Cluster bombs are not very effective agaist flying aircraft. Muslims don't have any such flying aircraft. So, what's your point? Google Mi-24 Hind, or in Iran, Cobra Gunship. (Drivel snipped.) |
#30
David E. Powell wrote:
On Oct 16, 7:35 pm, Vince wrote: David Lesher wrote: Mike writes: Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. Strange no one is discussing how much such weighs; in an airframe already short of payload... and balance its a side to side prop-rotor configuration hang a thousand pounds on the chin and see what happens There could weight to play with in the tail, or a way to counterbalance by moving some equipment inside. They modified the B-17 OK, but they had a lot more relative weight to play with. Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including ammo.) IIRC that was the weight of the 30 mm turret + ammo + structural reinforcement and all control equipment Vince |
Desktop Wallpaper - "Osprey Out for a spin". | T. & D. Gregor, Sr. | Simulators | 0 | August 31st 07 02:48 PM |
"Seeking Foreign Buyers For Osprey" | Mike[_7_] | Naval Aviation | 72 | July 4th 07 05:26 AM |
Desktop Wallpaper - "A covey of Osprey". | T. & D. Gregor, Sr. | Simulators | 0 | June 1st 07 08:41 PM |
"Marine Corps Grounds V-22 Osprey Aircraft" | Mike[_1_] | Naval Aviation | 0 | February 18th 07 03:40 PM |
V-22 Osprey "ground effect" question | Robert | Naval Aviation | 6 | January 2nd 07 03:44 PM |
