My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil
Old October 20th 07, 12:21 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Scott[_1_]
Default My Modest Proposal to End Global Warming, Revitalize GeneralAviation, and End Our Dependence on Foreign Oil
What voltage do those cars use? I assume it's more than 12V. If so,
you'll have to series connect several solar panels to match what you
need. And then, if it's an oddball voltage, you'll have to build your
own charge controller to keep from overcharging. And then, does the
battery type used require a constant voltage or constant current to
charge them. If constant current, you will have to build your own
current source. None of this is un-doable, just some dinking around.
If the voltage required is quite high, you will have a fair investment
in solar panels...
Edward A. Falk wrote:
In article . com,
Jay Honeck wrote:
Sounds good to me.
Me, too.
I could live quite happily without freeways. In fact, given my 6 mile
(round trip) commute each day, I'm considering an all-electric car as
my next vehicle.
All-electric cars have the problem of limited range. I'm thinking of
a plug-in Prius for my next car. It's an electric car for short trips,
and a hybrid for long ones. With solar panels on the roof to charge it,
it becomes pretty green.
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Old October 21st 07, 12:52 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Jim Macklin
Default My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil
The current crop of electric hybrids use about 4,000 AA
Li-ion batteries in series-parallel to get 800-1000 VDC for
the motors.
"Scott" wrote in message
12V. If so,
match what you
to build your
then, does the
current to
your own
dinking around.
fair investment
| in solar panels...
| In article
. com,
| Jay Honeck wrote:
| Sounds good to me.
| Me, too.
given my 6 mile
all-electric car as
| my next vehicle.
I'm thinking of
for short trips,
roof to charge it,
| Scott
Old October 21st 07, 03:26 AM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Jim Stewart
the motors.
The specs I've seen on the Honda Accord hybrid
show 120 NiMH cells giving 144 volts at 6.0 Ah
The Prius also uses NiMH cells, a total of 168
and a peak voltage of 201 volts and 6.5 Ah.
Old October 21st 07, 03:10 PM posted to rec.aviation.piloting,rec.aviation.student,rec.aviation.owning,rec.aviation.homebuilt
Peter Dohm
"Jim Stewart" wrote in message
Jim Macklin wrote:
The current crop of electric hybrids use about 4,000 AA Li-ion batteries
in series-parallel to get 800-1000 VDC for the motors.
That makes more sense; although I admit that the much higher voltage, with
solid state controls, could be fun to watch--from a safe distance.
My Modest Proposal to End Global Warming, Revitalize General Aviation, and End Our Dependence on Foreign Oil Gene Seibel Piloting 58 November 2nd 07 04:50 AM
I have an opinion on global warming! Jim Logajan Piloting 89 April 12th 07 12:56 PM
Aviation Conspiracy: CBS Spotlights Aviation's Effect On Global Warming!!! Free Speaker General Aviation 1 August 3rd 06 07:24 PM
Proposal For A New Rec.Aviation Newsgroup. (WAS: McCain in '08) Larry Dighera Instrument Flight Rules 54 July 24th 06 08:32 AM
House proposal to restrict general aviation C J Campbell Piloting 20 March 3rd 04 02:37 AM
