On Oct 20, 4:41 am, "Morgans" wrote:
Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. Maybe. I didn't know that they did. It would make sense if they did, all right. I don't do machining. I just run my fingers over the pretty parts when they come out of the machine shop! This ought to be an easy question for someone in the group. Surely, there is someone that does do machining on engines that hangs out here, that would know for sure. Anyone? -- Jim in NC Ok, First off don't call me Surely. GGGG. The concept is question is called "choke bore" and the idea is the bottom of the cylinder that's close to the case runs at a much lower temp since combustion happens at the other end. The top end grows at a greater rate because of this. In theory when the engine is up to temp the cylinder ends up being pretty straight. I have the specs around here somewhere but if I remember correctly the bore when cold is in the .006-.008 smaller at the top. Boring one is usually done by using a tool post grinder and performing the taper feature is a calculated process. Honing one with a flex hone is straight forward and easy, using a Sunnen CK-10 or a CV-616 takes ALOT more practice... Ben www.haaspowerair.com |
" wrote in
ups.com: On Oct 20, 4:41 am, "Morgans" wrote: Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. Maybe. I didn't know that they did. It would make sense if they did, all right. I don't do machining. I just run my fingers over the pretty parts when they come out of the machine shop! This ought to be an easy question for someone in the group. Surely, there is someone that does do machining on engines that hangs out here, that would know for sure. Anyone? -- Jim in NC Ok, First off don't call me Surely. GGGG. The concept is question is called "choke bore" and the idea is the bottom of the cylinder that's close to the case runs at a much lower temp since combustion happens at the other end. The top end grows at a greater rate because of this. In theory when the engine is up to temp the cylinder ends up being pretty straight. I have the specs around here somewhere but if I remember correctly the bore when cold is in the .006-.008 smaller at the top. Boring one is usually done by using a tool post grinder and performing the taper feature is a calculated process. Honing one with a flex hone is straight forward and easy, using a Sunnen CK-10 or a CV-616 takes ALOT more practice... And I thought it was just my old model airplane engines and bikes that had that feature. Who would have guessed a Lycoming could clamber to the height of sophistication reached by Ohlsson and Rice? Bertie |
On Sat, 20 Oct 2007 12:31:57 +0000 (UTC), Bertie the Bunyip
wrote: snip And I thought it was just my old model airplane engines and bikes that had that feature. Who would have guessed a Lycoming could clamber to the height of sophistication reached by Ohlsson and Rice? Bertie Been awhile since Continental spec'ed a choke bore, unsure if Lycoming ever did (I've never come across one-does not mean it does not exist). What is curious is that on the Conti's you could "straighten out" the choke and be within service limits in most cases. Factory new Lycoming cylinders can tend to be a little smaller at the upper 1/4 of the bore, but that's because the head gets shrunk onto the cylinder after it is initially machined & nitrided. Sorta important to check min. ring gap up there when working with a new jug. Again, it can be a straight bore and be within new & service limits. TC |
Engine out practice | Jay Honeck | Piloting | 155 | November 9th 07 03:07 AM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (09/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
