("Capt. Geoffrey Thorpe" wrote)
'cause if it didn't, your feet would have nothing to do ;-) http://www.ercoupe.org/images/37.jpg That would be awful...! :-) Montblack |
"Montblack" wrote in
: ("Capt. Geoffrey Thorpe" wrote) 'cause if it didn't, your feet would have nothing to do ;-) http://www.ercoupe.org/images/37.jpg That would be awful...! :-) It is. I flew one of the old pedal-less ones for a couple of days giving a guy who had rebuilt one and hadn't flown for years a re-intro to flying. God awful! there is a brake pedal, though. A stalk type pedal I think it came out of a '38 DeSoto. The Pilot's handbook said that to deal with a too high situation on approach you should pull th estickk full aft and let the rate of descent increase that way until you were back in the slot.. Yech. Always liked the look of them though. Could have been worse, it could have been the Gwinn Air car hat filled that Niche! Bertie |
![]() In addition to what others have said, another interesting question to ponder is why the airplane yaws when you bank. The yaw is induced by the ailerons, so the only time you need to apply rudder is when you are changing your bank angle with the ailerons. On the side where the aileron is down, the wing has more lift, and more drag. On the other side, the lift is spoiled and there is less drag. The draggy wing yaws backwards, requiring opposite rudder. This is why when you initiate a bank, you need to apply rudder in the direction of the bank while the ailerons are in use, but not once you stabilize the bank and neutralize the ailerons. When you roll back wings level, you need to apply rudder the other direction to once again compensate for the ailerons. Dean |
On Oct 21, 3:56 am, Bertie the Bunyip wrote:
wrote in news:1192935582.999886.201640 @t8g2000prg.googlegroups.com: In addition to what others have said, another interesting question to ponder is why the airplane yaws when you bank. The yaw is induced by the ailerons, so the only time you need to apply rudder is when you are changing your bank angle with the ailerons. On the side where the aileron is down, the wing has more lift, and more drag. On the other side, the lift is spoiled and there is less drag. The draggy wing yaws backwards, requiring opposite rudder. that's adverse yaw. I beleive he meant why does the airplane yaw in the same direction (eventually) as the direction of roll? Bertie - Hide quoted text - - Show quoted text - Bertie, I assumed that adverse yaw was what he was asking about since it is the most pronounced effect. To answer the question the other way: The reason for rudder use in a sustained bank is due to the fact that the airspeed of the outside wing is slightly higher than the airspeed of the inside wing due to the difference in arc-distance that each wing is traveling in a turn. The outside wing has a little more drag due to the higher airspeed and a little bit of rudder is required to compensate. Dean |
Paul kgyy wrote:
On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. The rudder causes the airplane to yaw; one wing goes faster, generating more lift; the other wing goes slower, generating less lift. vince norris |
What gives, guys? Good question followed by three answers that
actually agree? What's up with that? Where's the usenet controversy? ![]() Bob The rudder causes the airplane to yaw; one wing goes faster, generating more lift; the other wing goes slower, generating less lift. vince norris -- I'm trying a new usenet client for Mac, Nemo OS X. You can download it at http://www.malcom-mac.com/nemo |
Bob Clough wrote in news:nemoSat102007091418
@newsgroups.comcast.net: What gives, guys? Good question followed by three answers that actually agree? What's up with that? Where's the usenet controversy? ![]() Hey, I gotta slep every now and again, ya know. Bertie |
Isn't interesting that entry level RC Aircraft only have rudder and elevator
controls.. and then turn just fine. Funny that a full sized airplane would react the same way. In a stall, you pick up the low wing with rudder, not aileron, that only adds adverse yaw, more drag on the low wing, and fights the rudder. BT "Paul kgyy" wrote in message oups.com... On a 3 hour cross country today I was amusing myself by flying with rudder pedals only (all right, OK, a little yoke usage to maintain altitude). But then I got to wondering why applying rudder pressure causes the plane to bank. All I could think of was that rudder usage produces asymmetric lift because one wing is somewhat blanked by the sideways motion induced by the rudder? Also, the rudder surface is above the plane's center of lift but I don't know how much of a factor that is. |
GPS instead of turn and bank | Danny Deger | Piloting | 52 | February 8th 07 02:03 PM |
X-Wings and Canard Rotor Wings. | Charles Gray | Rotorcraft | 1 | March 22nd 05 12:26 AM |
Bank Check Aviation | Ron R | Piloting | 68 | January 19th 05 01:30 AM |
BREAKING THE BANK | Cribsheet | Piloting | 0 | December 22nd 04 06:27 PM |
key bank | CSA722 | Piloting | 0 | July 14th 03 07:04 AM |
