#51
On Oct 20, 4:41 am, "Morgans" wrote:
Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. Maybe. I didn't know that they did. It would make sense if they did, all right. I don't do machining. I just run my fingers over the pretty parts when they come out of the machine shop! This ought to be an easy question for someone in the group. Surely, there is someone that does do machining on engines that hangs out here, that would know for sure. Anyone? -- Jim in NC Ok, First off don't call me Surely. GGGG. The concept is question is called "choke bore" and the idea is the bottom of the cylinder that's close to the case runs at a much lower temp since combustion happens at the other end. The top end grows at a greater rate because of this. In theory when the engine is up to temp the cylinder ends up being pretty straight. I have the specs around here somewhere but if I remember correctly the bore when cold is in the .006-.008 smaller at the top. Boring one is usually done by using a tool post grinder and performing the taper feature is a calculated process. Honing one with a flex hone is straight forward and easy, using a Sunnen CK-10 or a CV-616 takes ALOT more practice... Ben www.haaspowerair.com |
#52
" wrote in
ups.com: On Oct 20, 4:41 am, "Morgans" wrote: Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. Maybe. I didn't know that they did. It would make sense if they did, all right. I don't do machining. I just run my fingers over the pretty parts when they come out of the machine shop! This ought to be an easy question for someone in the group. Surely, there is someone that does do machining on engines that hangs out here, that would know for sure. Anyone? -- Jim in NC Ok, First off don't call me Surely. GGGG. The concept is question is called "choke bore" and the idea is the bottom of the cylinder that's close to the case runs at a much lower temp since combustion happens at the other end. The top end grows at a greater rate because of this. In theory when the engine is up to temp the cylinder ends up being pretty straight. I have the specs around here somewhere but if I remember correctly the bore when cold is in the .006-.008 smaller at the top. Boring one is usually done by using a tool post grinder and performing the taper feature is a calculated process. Honing one with a flex hone is straight forward and easy, using a Sunnen CK-10 or a CV-616 takes ALOT more practice... And I thought it was just my old model airplane engines and bikes that had that feature. Who would have guessed a Lycoming could clamber to the height of sophistication reached by Ohlsson and Rice? Bertie |
#53
On Sat, 20 Oct 2007 12:31:57 +0000 (UTC), Bertie the Bunyip
wrote: snip And I thought it was just my old model airplane engines and bikes that had that feature. Who would have guessed a Lycoming could clamber to the height of sophistication reached by Ohlsson and Rice? Bertie Been awhile since Continental spec'ed a choke bore, unsure if Lycoming ever did (I've never come across one-does not mean it does not exist). What is curious is that on the Conti's you could "straighten out" the choke and be within service limits in most cases. Factory new Lycoming cylinders can tend to be a little smaller at the upper 1/4 of the bore, but that's because the head gets shrunk onto the cylinder after it is initially machined & nitrided. Sorta important to check min. ring gap up there when working with a new jug. Again, it can be a straight bore and be within new & service limits. TC |
#54
#55
![]() wrote in message ups.com... On Oct 16, 12:43 am, Bertie the Bunyip wrote: wrote in news:1192492570.300275.289550 @i38g2000prf.googlegroups.com: On Oct 15, 8:49 am, Bertie the Bunyip wrote: The examiner wouldn't allow him to slip because he reckons they are dangerous with the flaps out and that he should wiggle the ailerons back and forth to lose height. He didn't even want him to slip clean. Jesus wept. This examiner had had a fright in a 172 (this was an archer anyway) and did not alow anyone to slip with flaps out. While I am firmly in the camp that says some cessnas can get a litle fuzzy in pitch with full flaps, this is just stupidity incarnate. Shoot. We do slips with full flaps all the time in 172s, have done so for years, and never had a scare. I wonder if that "Avoid Slips With Flaps Extended" applied to some earlier models? I'll have to check the TCDS sometime. Dan Dunno. the manual in a 172 makes reference to a possibility of degraded elevator control, but I think it's only a bit of a nod, really. The Bird dog suffers from this ailment big time, though. it has, essentially, the 172's wing, but the flaps go to 60 degrees. I can tell you first hand that blanking of both the rudder and elevator are a very real characteristic of that airplane if you slip it ith full flaps. I did it once close to the ground and never even thought about it again.. Here's what the Type Certificate Data Sheet says: .................................................. .................................. D. On flap handle, Models 172 through 172E (1) "Flaps - Pull to extend Takeoff Retract 0° 1st notch 10° Landing 0° - 40° (2) "Avoid slips with flaps down." E. Near flap indicator Models 172F (electric flaps) through 17271034, excluding 17270050) "Avoid slips with flaps extended." .................................................. ........................................ The applicable models, 172 through 172F, were built between 1956 and 1964 ('65 model?). There's no mention of the slip with flaps thing for later models. I wonder if the addition of the back window changed the airflow enough to keep the elevator flying? Dan I believe that the advice against slips with (full) flaps ended when the maximum flap extension changed from 40 to 30 degrees. On the very early swept tail 172 (1959 model, IIRC) that I had some time in, a slip with full flaps resulted in a buffet--but I don't recall that being done with aft CG at any time that I was aboard. Peter |
#56
![]() "Scott" wrote in message .. . Of course, that system would lead to dumps on short final at about 50 feet up on a nice day under other than emergency conditions (except for the one just created)... Scott There really is a big difference between dumping the flaps, and bringing them quickly back to the point of greatest lift relative to added drag--usually around 20 degrees. I've had instructors who insisted on milking the flaps off, despite the contrary advice in the POH. Peter |
#57
"Peter Dohm" wrote in
: "Scott" wrote in message .. . Of course, that system would lead to dumps on short final at about 50 feet up on a nice day under other than emergency conditions (except for the one just created)... Scott There really is a big difference between dumping the flaps, and bringing them quickly back to the point of greatest lift relative to added drag--usually around 20 degrees. I've had instructors who insisted on milking the flaps off, despite the contrary advice in the POH. Well, ultimately you will get the best rate of climb clean after you have reached best limb speed, of course, but it's not al that significant at the begining unless you have a big obstacle problem off in the distance, so you're right, best flap position is usually around 20 or 15 or whatever is handy! Bertie |
#58
Ο "Bertie the Bunyip" έγραψε στο μήνυμα
... Well, ultimately you will get the best rate of climb clean after you have reached best limb speed, of course, but it's not al that significant at the begining unless you have a big obstacle problem off in the distance, so you're right, best flap position is usually around 20 or 15 or whatever is handy! Bertie An old rule-of-thumb I remember has it that aligning the flap with a down aileron gives you the best (most lift) flap position (assuming, i presume, that the ailerons deflect to maximum effectiveness=lift). FWIW, G. |
#59
"gpaleo" wrote in
news:1192979491.466999@athprx03: Ο "Bertie the Bunyip" έγραψε στο μήνυμα ... Well, ultimately you will get the best rate of climb clean after you have reached best limb speed, of course, but it's not al that significant at the begining unless you have a big obstacle problem off in the distance, so you're right, best flap position is usually around 20 or 15 or whatever is handy! Bertie An old rule-of-thumb I remember has it that aligning the flap with a down aileron gives you the best (most lift) flap position (assuming, i presume, that the ailerons deflect to maximum effectiveness=lift) Never heard it but it sounds like a good bush piloty sort of thing to do. Bertie |
#60
On Oct 21, 7:56 pm, Bertie the Bunyip wrote:
"gpaleo" wrote innews:1192979491.466999@athprx03: Ο "Bertie the Bunyip" έγραψε στο μήνυμα .. . Well, ultimately you will get the best rate of climb clean after you have reached best limb speed, of course, but it's not al that significant at the begining unless you have a big obstacle problem off in the distance, so you're right, best flap position is usually around 20 or 15 or whatever is handy! Bertie An old rule-of-thumb I remember has it that aligning the flap with a down aileron gives you the best (most lift) flap position (assuming, i presume, that the ailerons deflect to maximum effectiveness=lift) Never heard it but it sounds like a good bush piloty sort of thing to do. Bertie - Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - Hence the reason why some of us fly planes that have flaperons instead of flaps/ailerons.. |
Engine out practice | Jay Honeck | Piloting | 155 | November 9th 07 03:07 AM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (09/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
