To Pawnee or not to Pawnee...that is the question...
Old October 22nd 07, 09:27 AM posted to rec.aviation.soaring
Dan G
Default To Pawnee or not to Pawnee...that is the question...
On Oct 18, 3:49 am, " wrote:
I concur with Cloudy. Eventually, almost all high volume tow
operations in the USA have ended up with Pawnees. Rugged, inexpensive
to buy and operate
Reason I mentioned "other efficient 180hp tugs" is because at least at
sea-level sites, the likes of SuperCubs and Robin DR400s (guess you
don't have them in the US) tow to height just as fast as a Pawnee, but
use only something like two-thirds of the fuel by virtue of a much
more efficient aerodynamic design. The Robin saves even more on aero-
tow retrieve (it's fast), and is a very popular tug in the UK (moreso
than the Pawnee). In fact we even tried towing with a Rotax Falke -
only 100hp or so, but very efficient. Within its tow limit (600kg)
what it loses in climb to a Pawnee 250 it more than makes up on
descent as it's water-cooled.
The only place a Pawnee shines (at sea-level) is for acceleration on
the ground roll. If you have the room, that's not an issue.
Dan
Old October 22nd 07, 01:07 PM posted to rec.aviation.soaring
Dan G
"As a tug, the SF25C Rotax Falke seems to perform very well, climbing
with heavy two-seaters at 400ft/min. This is marginally slower than,
say, a Robin DR400, but this Falke uses only half as much fuel and the
noise pollution is much less. In Germany, official analysis of
comparative tug noise estimates a single tow in a Robin DR400 type tug
equates to 4.8 tows in a SF25C Rotax Falke. Glider-tug speed
compatibility, similar wing loadings and aspect ratios, and reduced
wake turbulence, mean the motorglider aerotowing option offers
significant safety features.
The manufacturer's fuel consumption figures are 16-18 litres (c 3.5
gallons) an hour, hardly thirsty for tugs. Taking into account all the
costs of operating the Falke, including an engine rebuild every 2,000
hours, insurance, fuel and maintenance costs, a Falke is estimated by
its makers to tow at about 60 per cent of the cost of today's
conventional tugs."
http://www.fffoundation.co.uk/SGart.html
Old October 22nd 07, 02:56 PM posted to rec.aviation.soaring
309
Well, imagine that. If the students (and/or instructors...and/or
private ship owners) really **** of the tow pilot, he can shut the
"money making motor" off and soar for himself! I like that idea.
Having been stuck as the only "tow slave" on many booming days when I
wanted to soar (but was too chicken to shut off the motor in the
Pawnee or CallAir). Yeah, I know pilots that have taken Pawnee
"gliders" to 20,000+ feet in wave -- I guess I never got THAT
desperate.
-Pete
Old October 22nd 07, 03:05 PM posted to rec.aviation.soaring
Frank Whiteley
conventional tugs."
That article was published in 2000. How many are currently in use as
tugs?
Old October 22nd 07, 07:35 PM posted to rec.aviation.soaring
Dan G
Ours was used for a couple of comps in 2005 with great effect (matched
the Pawnees as due the very quick descent and only used 1/3 the fuel),
but since then it hasn't been insured for towing. Another club is a
using a G109 with the turbo Rotax, but has performance issues once the
5-minute boost period is over (i.e., if you want to go higher than
about 3,000'). Finally I know of a Rotax-engined microlight being used
for towing in South Africa.
So, being honest, it's not being used widely (at least not to my
knowledge). There's no good reason though - maybe it's a combination
of it not being around for long, that there's still a lot of Pawnees
and Robins knocking around which are still in use, and that new things
rarely get taken up widely in gliding even if they're proven (e.g.
plasma rope).
Dan
Old October 22nd 07, 08:00 PM posted to rec.aviation.soaring
Dan G
A couple of links about towing with Rotax power. First the microlight
in SA:
http://www.glidingmagazine.com/FeatureArticle.asp?id=91
And also on using Rotax Falkes:
http://www.glidingmagazine.com/Featu...cle.asp?id=117
I bet a fair few Falkes are being used as tugs in Germany - any of our
members from over there know?
Dan
Old October 22nd 07, 08:07 PM posted to rec.aviation.soaring
Dan G
Bleurgh, it would help if I RTFA I linked to. At least 20 are used for
towing over there, and that was in 2001. A good point made in the
article is also that, of course, a motorglider tug still gets used for
circuit training, field landing exercises etc., and all that ups
utilisation and lowers costs. And it is damned quiet - ours is *much*
quieter than our Pawnee.
Dan
Old October 23rd 07, 01:31 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
I think you'll also find that a number of German operations are using
modern glass ultralights as tugs. IIRC the Wasserkuppe uses a Virus or
similar - a nose gear gear high-wing anyway - for towing single seaters
and a GR400 for their ASK-21s.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 23rd 07, 06:57 AM posted to rec.aviation.soaring
Bruce
About as many as Scheibe elected to build...
Scheibe has recently gone through ownership change, and hopefully will get more
focussed on building gliders.
conventional tugs."
tugs?
Towing with a 150 hp Pawnee? [email protected] Soaring 5 November 22nd 06 01:32 PM
PA-25 PAWNEE Rafgsa Centre Soaring 2 March 3rd 05 03:13 AM
WTB Pawnee Prop Roy Bourgeois Soaring 1 November 2nd 04 06:57 PM
Pawnee Damien Dyer Soaring 2 November 2nd 04 05:35 PM
Pawnee hell Stewart Kissel Soaring 17 October 27th 04 04:15 AM
