Adiabatic lapse rate
Old October 22nd 07, 07:17 PM posted to rec.aviation.ifr
S Green
Default Adiabatic lapse rate
"Everett M. Greene" wrote in message
Does the lapse rate equation hold in all cases? I was recently
wondering what kind of temperature would be reached at 35 Kft
over Arctic Canada in January. It seemed that the lapse rate
equation would lead you to expect temperatures that would be
causing nitrogen and carbon dioxide to be condensing which
doesn't seem likely.
As you pass through the tropopause at approx 36,000 and -56 C the
temperature rises in the stratosphere as solar radiation is bounced back up
through the stratosphere by ozone (O3).
As you get right on the fringes of the atmosphere the temperature rise is
enormous.
The main issue in the troposphere is that well known greenhouse gas water
vapour. The adiabatic lapse rate is entirely dependent on the amount of
water in the air and you can calculate that using the wet and dry bulb
thermometers.
Old October 23rd 07, 03:43 AM posted to rec.aviation.ifr
Dane Spearing
A few years back, my (then) 4th grade son did his science fair project on how
temperature changes with altitude. Over the course of a year, and
probably a dozen or more family flights, he measured the OAT as a function
of altitude during our climb-outs and descents. He got data from sea level
up to 14,000. Amazingly enough, it averaged out to almost exactly
2 deg C/1000'. He noted that the greatest deviations from that occurred
very close to the ground (within 2000' AGL) and when we were in clouds (IMC).
Now, our Cherokee 6 can't climb up to FL 350, so I have no personal
experience with how high the standard lapse rate holds. However, my son
will tell you that for a clear day, above 2000' AGL, it seems to hold
very very well.
Oh....and he got first place for his science project. I couldn't be a
prouder pilot-papa.
-- Dane
Old October 29th 07, 03:40 PM posted to rec.aviation.ifr
Al G[_1_]
Why dies everyone think that the standard lapse rate is a
meteorological term?
It's not.
You think it is a cooking term?
Maybe medical, as in "I let my medical lapse".
Al G
Old October 29th 07, 04:20 PM posted to rec.aviation.ifr
Jim Macklin
It is used to model the standard atmosphere, certainly is a
scientific term used in physics, which applies to
meteorological study. It has an application to actual
flight by using terms such as ISA+20
"Al G" wrote in message
| wrote in message
a
| It's not.
| Al G
Old October 30th 07, 12:43 PM posted to rec.aviation.ifr
Environmental lapse rate is a meteorological term.
Adiabatic lapse rates are meteorologocal terms.
Standard lapse rates are an invention of engineers to enable them to
compare aircraft performance.
On Mon, 29 Oct 2007 08:40:05 -0700, "Al G"
It's not.
Al G
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Wx Time Lapse Videos Jay Beckman Piloting 0 September 20th 05 07:32 AM
How saturated adiabatic lapse rate varies with temperature Andrew Sarangan Piloting 5 February 15th 05 02:38 PM
Atmospheric stability and lapse rate Andrew Sarangan Piloting 39 February 11th 05 05:34 AM
Lapse Rate Question Waduino Soaring 0 October 1st 03 07:32 PM
