In article , AL wrote:
Yes, the newest F-15s is most impressive. But there isn't any planned future development. All funds are directed towards F-35. All US funds...maybe. There are upgrades programs underway for AESA radar on F-15Cs. Probably other upgrades, too. Plus Macair...oops, Boeing, will put in their own money if a sale looks in the offing. If you are considering F-15K/T against other aircraft, that is definitely not good. No, just a comparison of concerns, not missions. Interestingly models of aircraft operated by the Malaysia and Indonesia did not make it to the shortlist. There are a million ways to interpret this. One of them is to avoid any hesitation by the pilots when going head to head? That's certainly a consideration. Plus the recognition factor when US forces are in the area. USN a/c not likely to fire on an F-15. -- Harry Andreas Engineering raconteur |
On Tue, 14 Oct 2003 09:50:21 -0700, Harry Andreas wrote:
Interestingly models of aircraft operated by the Malaysia and Indonesia did not make it to the shortlist. There are a million ways to interpret this. One of them is to avoid any hesitation by the pilots when going head to head? That's certainly a consideration. Plus the recognition factor when US forces are in the area. USN a/c not likely to fire on an F-15. They'd be well advised not to fire on a Typhoon either, since it's better than anything the USN is likely to have for some time (and I think the F-35C falls in that category). -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
On Wed, 15 Oct 2003 01:48:52 -0600, Scott Ferrin wrote:
On Wed, 15 Oct 2003 00:09:46 +0100, ess (phil hunt) wrote: They'd be well advised not to fire on a Typhoon either, since it's better than anything the USN is likely to have for some time (and I think the F-35C falls in that category). Well it's good to dream but I'd say wait until the F-35C is flying before making that judgement. That big wing, 56k lbs thrust (so says RR) Who's RR? The figure I've seen for thrust is 35 klbf (15900 kgf), giving F-35 a AESA, What's this? 360 degree IRST, My understanding is Eurofighter has an IRST too. stealth, -9X, The AIM-9X will have a shorter range than the Meteor (I'm assuming that Singapore would buy it, it seems quite logical if they are going for an air superiority fighter). So the Typhoons would be able to get the first shot in (not only that, since they are faster than the F-35, they have the ability to decide at what range the engagement takes place). If the engagement does get to close range, the Typhoon has (according to figures I've seen) a better thrust to weight ratio and lower wing loading. F-35 has thrust vectoring, but late models of the Typhoon might too. Typhoon is dynamically unstable, which should increase its maneouvrability. (BTW, is it right that the F-35's weapons bay is too small to fit in some weapons like ASRAAM? My understanding is ASRAAM has a larger diameter than AIM-9X, giving it potential for greater range/acceleration). -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
On Wed, 15 Oct 2003 14:44:07 -0700, Harry Andreas wrote:
In article , wrote: AESA, What's this? Active Array radar. Higher performance and more versatile than mechanicaly scanned planar arrays. More reliable too. At the moment Typhoon uses the CAPTOR radar, but this may well change to the AMSAR active array radar in future. There's also the possibility of a conformal smart skin array of sensors, firther increasing radar capability. 360 degree IRST, My understanding is Eurofighter has an IRST too. the 360 part is very important. Possibly. In any case, I imagine it wouldn't be difficult to add a reverse-looking one to Typhoon, perhaps on a wingtip pod. stealth, -9X, The AIM-9X will have a shorter range than the Meteor (I'm assuming that Singapore would buy it, it seems quite logical if they are going for an air superiority fighter). So the Typhoons would be able to get the first shot in (not only that, since they are faster than the F-35, they have the ability to decide at what range the engagement takes place). If the engagement does get to close range, the Typhoon has (according to figures I've seen) a better thrust to weight ratio and lower wing loading. F-35 has thrust vectoring, but late models of the Typhoon might too. Typhoon is dynamically unstable, which should increase its maneouvrability. You seem fixated on close range combat. I don't think so; I did specifically say that long range missiles would be used first, but there's a possibility of close range combat -- I've no idea how high that possibility is. Postulating a South Asia Typhoon v F-35 engagement, what makes you think the more stealthy F-35 won't use NCTR then shoot the Typhoon in the face BVR with an AIM-120? I don't know what NCTR is, so I won't discuss that. If the F-35 is switching its radar on to detect the Typhoon, then the Typhoon will presumably be able to detect this (the signal will be billions of times stronger at the Typhoon than what's received back at the F-35), so I am doubtful of the possibility of the F-35 sneaking up on the Typhoon undetected. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
If you read the company releases, CAPTOR is actually performing a lot better
than expected, and at a level comparable with todays AESA radars. Supposedly (and I know very little about radars) it will keep itself in service for a lot longer than previously thought, and may just jump to the next big technical leap? "phil hunt" wrote in message . .. On Wed, 15 Oct 2003 14:44:07 -0700, Harry Andreas wrote: In article , wrote: AESA, What's this? Active Array radar. Higher performance and more versatile than mechanicaly scanned planar arrays. More reliable too. At the moment Typhoon uses the CAPTOR radar, but this may well change to the AMSAR active array radar in future. There's also the possibility of a conformal smart skin array of sensors, firther increasing radar capability. 360 degree IRST, My understanding is Eurofighter has an IRST too. the 360 part is very important. Possibly. In any case, I imagine it wouldn't be difficult to add a reverse-looking one to Typhoon, perhaps on a wingtip pod. stealth, -9X, The AIM-9X will have a shorter range than the Meteor (I'm assuming that Singapore would buy it, it seems quite logical if they are going for an air superiority fighter). So the Typhoons would be able to get the first shot in (not only that, since they are faster than the F-35, they have the ability to decide at what range the engagement takes place). If the engagement does get to close range, the Typhoon has (according to figures I've seen) a better thrust to weight ratio and lower wing loading. F-35 has thrust vectoring, but late models of the Typhoon might too. Typhoon is dynamically unstable, which should increase its maneouvrability. You seem fixated on close range combat. I don't think so; I did specifically say that long range missiles would be used first, but there's a possibility of close range combat -- I've no idea how high that possibility is. Postulating a South Asia Typhoon v F-35 engagement, what makes you think the more stealthy F-35 won't use NCTR then shoot the Typhoon in the face BVR with an AIM-120? I don't know what NCTR is, so I won't discuss that. If the F-35 is switching its radar on to detect the Typhoon, then the Typhoon will presumably be able to detect this (the signal will be billions of times stronger at the Typhoon than what's received back at the F-35), so I am doubtful of the possibility of the F-35 sneaking up on the Typhoon undetected. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
On Wed, 15 Oct 2003 01:48:52 -0600, Scott Ferrin wrote: Well it's good to dream but I'd say wait until the F-35C is flying before making that judgement. That big wing, 56k lbs thrust (so says RR) Who's RR? The figure I've seen for thrust is 35 klbf (15900 kgf), Rolls-Royce. They're working with GE on the F136 engine, which is the alternative to the Pratt Whitney F135 specified for the first JSF batches. The 56,000-lb figure came from Rolls-Ryce a couple of years ago; everyone else is sticking to "40,000-lb class" for both F135 and F136. The AIM-9X will have a shorter range than the Meteor (I'm assuming that Singapore would buy it, it seems quite logical if they are going for an air superiority fighter). S Here you're comapring apples and oranges. AIM-9X is a dogfight missile; the Eurofighter counterpart is ASRAAM. Meteor is a BVR missile; the US counterpart is AMRAAM (which is shorter ranged) or one of several proposed AMRAAM gowth options. o the Typhoons would be able to get the first shot in (not only that, since they are faster than the F-35, they have the ability to decide at what range the engagement takes place). If the engagement does get to close range, the Typhoon has (according to figures I've seen) a better thrust to weight ratio and lower wing loading. F-35 has thrust vectoring, but late models of the Typhoon might too. JSF does not have thrust vectoring, the tail nozzle moves only for vertical flight. Typhoon is dynamically unstable, which should increase its maneouvrability. But are like to the be dynamically unstable. (BTW, is it right that the F-35's weapons bay is too small to fit in some weapons like ASRAAM? My understanding is ASRAAM has a larger diameter than AIM-9X, giving it potential for greater range/acceleration). The bays are designed for AMRAAM and 2000-lb JDAMS. ASRAAM will certainly fit, but Meteor may not. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
On Thu, 16 Oct 2003 00:25:02 GMT, "Thomas Schoene"
wrote: "phil hunt" wrote in message rg On Wed, 15 Oct 2003 01:48:52 -0600, Scott Ferrin wrote: Well it's good to dream but I'd say wait until the F-35C is flying before making that judgement. That big wing, 56k lbs thrust (so says RR) Who's RR? The figure I've seen for thrust is 35 klbf (15900 kgf), Rolls-Royce. They're working with GE on the F136 engine, which is the alternative to the Pratt Whitney F135 specified for the first JSF batches. The 56,000-lb figure came from Rolls-Ryce a couple of years ago; everyone else is sticking to "40,000-lb class" for both F135 and F136. Pretty much everybody was/is skeptical of that figure from RR but it's notewothy that the PW version used on the non VTOL X-32 hit 52,000 in afterburner. Considering that several years more developement time are going into the production engine AND that GE will want to have SOME reason for the buyer to choose their's over the P&W engine I don't think 56k is beyond believability. But almost. |
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In | zeno | Instrument Flight Rules | 0 | October 30th 04 06:20 PM |
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In | zeno | Home Built | 0 | October 30th 04 06:19 PM |
Why don't all fighters have low Wing Loading? | Chad Irby | Military Aviation | 6 | September 22nd 03 10:52 PM |
US (Brit/Japanese/German/USSR) Use of Gun Cameras in Fighters?? | ArtKramr | Military Aviation | 3 | July 17th 03 06:02 AM |
Scrambling fighters | John Doe | Military Aviation | 7 | July 2nd 03 09:26 PM |
