That's how this whole discussion got started.
What, RAS going around in circles (in sink!) ? Unheard of! I haven't tried the high parasitic drag maneuver in a duo yet. When demonstrated by Marty Eiler in an ASK 21, it consisted of a near VNE dive to the ground well short of the intended landing area, and then bleeding off the speed quite low. The key is that you lose so much energy near VNE with spoilers out, you can afford now to bleed off speed, even in ground effect. Most of our duo discussions have not invovlved such high speeds -- I'm curious how it might work. I know that being high, 80 knots and aiming at the spot in a duo is a bad combination, but that's not what we're taling about! As fun as the high parasitic drag maneuver is, I wonder if anyone has ever actually used it in combat. Has anyone been so flustered and out of synch to get monstrously high in an off field landing, then had the presence of mind and skill left to dive to the ground at near VNE, aiming several hundreds of yards short of the intended small paddock with fence at the far end, and had it work? The mental attitude that gets to the problem seems incompatible with the attitude needed to pull this one off. If you don't aim short enough in the dive, you just crash into the far fence at really high speed. But I'd be curious to hear a "it worked for me" story. John Cochrane |
![]() "BB" wrote in message ups.com... That's how this whole discussion got started. What, RAS going around in circles (in sink!) ? Unheard of! I haven't tried the high parasitic drag maneuver in a duo yet. When demonstrated by Marty Eiler in an ASK 21, it consisted of a near VNE dive to the ground well short of the intended landing area, and then bleeding off the speed quite low. The key is that you lose so much energy near VNE with spoilers out, you can afford now to bleed off speed, even in ground effect. Most of our duo discussions have not invovlved such high speeds -- I'm curious how it might work. I know that being high, 80 knots and aiming at the spot in a duo is a bad combination, but that's not what we're taling about! As fun as the high parasitic drag maneuver is, I wonder if anyone has ever actually used it in combat. Has anyone been so flustered and out of synch to get monstrously high in an off field landing, then had the presence of mind and skill left to dive to the ground at near VNE, aiming several hundreds of yards short of the intended small paddock with fence at the far end, and had it work? The mental attitude that gets to the problem seems incompatible with the attitude needed to pull this one off. If you don't aim short enough in the dive, you just crash into the far fence at really high speed. But I'd be curious to hear a "it worked for me" story. John Cochrane I have tried it with my big wing glider and for me the 'high parasite drag' approach doesn't work unless you shift to a airspeed stabilized approach no lower than 100 feet AGL. My reasoning is that the ground effect starts at about a wingspan above the ground so the bigger the wing the higher it starts. Just above the runway, ground effect roughly doubles the L/D, (i.e. ~7:1 with full spoilers becomes 14:1) so in ground effect is a bad place to try to scrub off energy. The key to the Duo spoilers seems to be a stabilized approach. It's a really slippery glider and it's easy to let the airspeed creep up once your eyes are on the aim point. In low wind/low turbulence conditions, nailing the airspeed right on the yellow triangle while holding the glideslope to the aim point can result in a fairly short landing. You can fly much higher airspeed in the patern and on long final as long as the airspeed is reduced to the calculated reference airspeed on short final. Bill Daniels |
BB wrote:
As fun as the high parasitic drag maneuver is, I wonder if anyone has ever actually used it in combat. Has anyone been so flustered and out of synch to get monstrously high in an off field landing, then had the presence of mind and skill left to dive to the ground at near VNE, aiming several hundreds of yards short of the intended small paddock with fence at the far end, and had it work? The mental attitude that gets to the problem seems incompatible with the attitude needed to pull this one off. If you don't aim short enough in the dive, you just crash into the far fence at really high speed. But I'd be curious to hear a "it worked for me" story. In reality, I almost always have too little altitude rather than too much when I'm trying to sneek into a field. I did use this sort of technique with my Ventus a couple of times to get over trees and into short fields, but it had trailing edge dive brakes that would allow me to hold 60 to 65 knots in a dive, then round out, slow down, and plop it in. There is no way I could make that work in a Duo, or most other gliders... Marc |
BB wrote:
As fun as the high parasitic drag maneuver is, I wonder if anyone has ever actually used it in combat. Has anyone been so flustered and out of synch to get monstrously high in an off field landing, then had the presence of mind and skill left to dive to the ground at near VNE, aiming several hundreds of yards short of the intended small paddock with fence at the far end, and had it work? The mental attitude that gets to the problem seems incompatible with the attitude needed to pull this one off. In "combat"? In a Duo? There are a number of real combat stories about people keeping the speed high in damaged aircraft to get down out of the fight, through clouds, etc. to find a safer area for a forced landing or bailout--so as not to be hosed while under canopy, or to avoid setting up a big slow pattern that would make them a sitting duck--but I think that diverges from what you are asking. I don't think fighter pilots get a chance to practice engine out landings much, so yes, they adapt. The best adaptation is that for which the mental groundwork is laid _on_ the ground. Sailplane pilots have the incomparable advantage of doing their preparation on the ground _and_ in the air by planning and practicing both low- and high-energy approaches, as has been outlined here in previous postings by several contributors. Jack |
MA-8 with parachute extended S63-00693.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:52 PM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Extended GPX Schema | Paul Tomblin | Products | 0 | September 25th 04 02:44 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
