Field capacity to repair, overhall, reconstuct, and build airplanes in W.W.I.I.
Old October 14th 03, 09:47 PM
John Freck
Default Field capacity to repair, overhall, reconstuct, and build airplanes in W.W.I.I.
A question has come up on anoouhter thread: Did airbases during
W.W.I.I have mini-factories near-by able to assemble airplanes from a
combination of recylced parts, mini-milled machine parts (ferrous
parts and aluminium parts, but not organic parts), and new spare
parts?
I have seen several domumentaries were there are mentions of small
industrial furnaces being deployed to the Pacific and new part
milling, the robust repair and recylcing of Hurricanes, and in one
documentary on the B-26 of whole plane final assemeble do right on
base from parts from a vareity of sources.
In addition, I have heard that on US aircraft carriers any metal
aircraft part can be made on board using furnances and milling tools
right on board: Is this so today? Was this so in W.W.I.I. ?
How many airmen did the Allied airforces have ground working in
England? How sophisticated and massive was aircraft maintence? Could
they assemble a warplane? Could they make a new engine using badly
damaged engines as the raw material?
Also, the internet didn't have a great deal on on-base or near-base
cottage warplane stuff, but it gets mentions in documeteries.
John Freck
Old October 14th 03, 11:43 PM
Keith Willshaw
"John Freck" wrote in message
om...
parts?
No
You have asked several questions, to answer them individually
1) Were small industrial furnaces deployed to the Pacific ?
That depends on what you define as a small industrial furnace.
Blacksmiths forges certainly were, aluminium smelters
certainly were not.
2) Were new parts sometimes milled in the field ?
Sure but only at great need, normally you pick the
spares up from the stores maintained on base and
which are purchased from the aircraft manufacturer
3) Were Hurricanes repaired and even recycled ?
Certainly, an entire organisation was created for just
this purpose with minor battle damage being handled
by the squadrons themselves, more substantial repairs
being handled by specialist units which were part of the
Civilian Repair Organisation and were located away from
the airfields.
4 ) In addition, I have heard that on US aircraft carriers any metal
No, think about for a moment , can you make an engine control
micro processor with a furnace and milling machine ?
5) Was this so in W.W.I.I. ?
No, you cant make a Merlin Engine or an H2S radar set that
way either.
6) How many airmen did the Allied airforces have ground working in
England?
Hundreds of thousands
7) How sophisticated and massive was aircraft maintence?
It was comparable to the motor industry
8) Could they assemble a warplane?
No, in the same way your local Ford dealer cant assemble a
new Mondeo
9) Could they make a new engine using badly
They could scavenge parts from a dead one to keep
a live engine going but this would be done only in
extreme circumstances, engine failure on take off
usually kills the pilot and crew
Lets kill this once and for all.
I live in East Anglia, there are literally dozens of old USAAF and
RAF base within 25 miles of my house. NOT ONE had or had
such a facility. Just doing routine maintenenance and battle damage
repair had the ground crews working 12-16 hours a day as it was.
Get Real
Keith
Old October 15th 03, 02:40 AM
John Freck
"Keith Willshaw" wrote in message ...
Prehaps where you are, Britain, the aviation industry isn't as large
as it is here in the USA.
I live in Fort Lauderdale, Florida. Today, there is no doubt that
aircraft engine part manufacture exists.
These companies are not huge, and I bet there are small companies able
to make jet engine parts all over the USA. Jet engine part makers are
in my local phone book; I have seen the buildings that house these
next to Miami International Airport and they are not huge. Not really
huge like Boeing's final assemble plant in Seatle,
Just the sort of operation, I claim, existed on USAAF bases in the
1940s does exist near large interantional airports in the USA today.
http://yp.yahoo.com/py/ypResults.py?...80.115800&cs=5
om...
parts?
No
You are wrong, and you basically admit it futherdown. I provided a
Yellow Book listing for today's situation for South Florida. How
about admitting that the avaition industry does this today? Huh?
certainly were not.
As far as I know an alumium smelter isn't needed to process alumium
metal in already process metal form, such as a used cola can, or
aircrafts' structural memebers. It can be hard for a small slumium
recycler to make new structrual members.
Today, there are tens of thousands of commercialpassenger jets flying
the world, and it looks to me as if just the sort of operation I
described is common place. With a little yellow book researching, I
might confirm that the amount of medium sized bussiness making jet
engine, and other airplane parts, is common whereever there is an
airport with heavy mantience. Hell, maybe light too.
the airfields.
Wouldn't it be more fuel, time, and money effiecient to have this
labor near large airbases?
Why not pack the stuff up and go to the field?
I said metal parts, and not organic parts. Organic parts would
include tires, hoses, betls, glass (ok not organic), foam, and ire
insulation, and chemicals. By no means do the big factories make
everything for an airplane from utter scratch raw materials, you know.
These feeder business in the situaitons would simply route stuff to
the airbases instead of the large factory. The aviation industry
doesn't make aviation grade alumium; it is ordered from the alumium
processing industry.
way either.
They do it today for commerical passenger jet engines.
England?
That is no par with the numbers of factory works employed by large
plants and the first rign of supply to factory factories.
Right.
new Mondeo
People today assemble more complicated planes from kits they have
purchased.
You might look up in the London phone book and see just how
sophiticated all automoblie
repair and resortation is. Just take a constellation of small to
medium auto repair bussiness, put them
close together, buy them small "pilot" scale stuff like a furnace, and
some tool and die company thrown it for good measure, and price
supports too. When you are done, you will have a auto manufacturer
with no more than a few hundred employees. There were at one time
scores upon scores of automonble makers and they all didn't make
millions of cars a year, for some it was few hundreds of cars sold per
year.
Get Real
Look at the current state of affairs with aviation repair. There must
over 100 companies making new parts at near airports in the USA alone.
John Freck
Keith
Old October 15th 03, 08:12 AM
Keith Willshaw
om...
True enough
So ?
There's a plant just down the road from me that makes
aircraft drop tanks. Thats a LONG way from building
Eurofighter in your back yard.
om...
parts?
No
It doesnt, the example you gave is of a plant that makes PARTS
for an aircraft just as small factories make parts for computers
and cars
certainly were not.
Such operations dont require a furnace.
Note the distributed manufacture of parts is not in question.
the airfields.
No
Because one field might only have 2 repairs a week to perform,
its much more efficient to ship them to a regional repair centre.
Silicon chips arent organic
Organic parts would
They do however have complex asssembly jigs and expensive
machine tools to shape that aluminum
way either.
No they dont. Jet engines are built by a handful of specialist
companies who may buy parts from smaller outfits
England?
This makes no sense
Right.
new Mondeo
purchased.
The kits are of course made in a factory
supports too.
You just described an operation thats extremely inefficient
year.
Such operations exist, their cars cost hundreds of thousands
of dollars
Get Real
John Freck
You seem unable to see the difference between a part and the whole
How sad
Keith
Old October 16th 03, 11:33 PM
Nick Pedley
om...
parts?
Here's a couple of things I've picked from books and museums....
The 'Block and Cube' test at RAF Halton involved each apprentice being given
a rough lump of one metal and a thin square of another, object being to
shape each piece using workshop tools that would available at any decent
base they might go on to serve at. The shapes had to be a perfect square
cube with a block it would sit in, all done to specifications and by hand.
I was told this would enable the manufacture of most, if not all, needed
parts that were otherwise unavailable.
During the Battle of Britain it was not unknown for damaged aircraft to be
cannibalised to provide spare parts for lesser damaged aircraft. This would
involve any part that would allow another machine to fly within safety
limits. 'Skies of Fire' by Alfred Price has a chapter about 266 Squadron who
flew Spitfires. The Engineering Officer broke his 'pet rule' about not
cannibalising aircraft to the extent he took a starboard wing from one
aircraft (the only undamaged part overall) to get another in the air.
I assume any damaged remains would have been taken away for further
repair/disposal at a different location when time allowed, as suggested by
other people here. Marshalls of Cambridge were involved in this and IIRC
there was a small airstrip somewhere in Anglia purely for a repair factory,
allowing previously damaged aircraft to fly out.
Nick
Old October 16th 03, 11:55 PM
Keith Willshaw
"Nick Pedley" wrote in message
om...
parts?
given
I did this as part of my mechanical fitters apprenticeship
for ICI in 1968. Its bloody har work and takes a LOT
of man hours
would
who
factory,
Nick
Marshalls are based at Cambridge Airport, the runway
can handle aircraft of all sizes, the refurbish 747's and
Tri-Stars there.
Keith
Old October 17th 03, 10:48 AM
Nick Pedley
om...
parts?
The 'Block and Cube' test at RAF Halton ....
of man hours.
I'm impressed. I had trouble believing the old boy on his display stand at
an RAF Halton event last year. Just looking at the rough lumps of metal made
me wonder!
by
factory,
Nick
Tri-Stars there.
Keith
Sorry, should have made myself clear. From reading books like 'Airfields of
the Eighth Army Air Force/9th AAF/Bomber Command/Fighter Command' etc, I
recall reading about a repair location which was little more than a barn
converted into a hangar with a bit of flat field, near a road. Not sure
where it was but am certain it wasn't the Marshalls operation at
Cambridge...
Nick
Old October 17th 03, 02:47 PM
M. J. Powell
In message , Keith Willshaw
writes
om...
parts?
given
of man hours
Me, too. For English Electric in '49. File and scraper work. And plenty
of 'Blue'.
Mike
M.J.Powell
Old October 17th 03, 03:22 PM
of man hours
of 'Blue'.
Mike
Yes, good old 'mechanic's blue', takes me back...
-Gord.
Old October 17th 03, 03:42 PM
Keith Willshaw
"M. J. Powell" wrote in message
writes
of man hours
of 'Blue'.
Thats the drill , file it square and scrape the top flat checking
with a surface plate.
Keith
