I had my MT composite prop overhauled this year. The hub needed some
machining, but if the blades are damaged they are replaced. The leading edge is nickel, but the rest is wood laminate for weight. They do not do well in rain, since it chips the paint off of the wood. |
Hartzell 2 blade Prop for PA24-250 | kontiki | Aviation Marketplace | 1 | August 14th 11 10:21 PM |
Hartzell HC-C2YF-1BF 95" 2 blade CS prop | RT | General Aviation | 0 | October 6th 07 09:33 AM |
Hartzell HC-C2YF-1BF 95" 2 blade CS prop | RT | Aviation Marketplace | 0 | October 6th 07 09:33 AM |
Hartzell prop hub AD 2006-18-15...results and our options | Jack Allison | Owning | 10 | December 27th 06 06:51 PM |
WxWorx customer service | Dan Luke | Piloting | 9 | August 25th 05 03:53 AM |
