Polar with spoilers extended?
Old October 25th 07, 08:00 PM posted to rec.aviation.soaring
Bruce
Default Polar with spoilers extended?
This is the kind of rigid thinking that kills people.
While I entirely concur that being too slow on final approach is dangerous, one
has to understand the variables. If you teach that the needle has to be ON the
yellow triangle, what happens to the pilot when he suddenly notices the glider
he is in doesn't have one. While under pressure in a difficult situation.
For every weight and configuration there is a stall speed.
For every wind condition there is a different factor to add to stall to get to a
safe approach speed.
Personally I would far rather fly with someone who knows exactly why he/she is
trying to maintain a particular speed, than someone who is a master at nailing
some arbitrary speed. Which happens to be perfect for one set of conditions.
As a Std Cirrus driver (pre serial 75) I can vouch for the wisdom of being at
the right speed. Too fast by even a small margin and you will float forever, and
PIO if you try to fly it on. Too slow and the handling gets very interesting if
there is turbulence. That right speed varies widely depending on the wind and
other circumstances.
Maybe we make it too complicated - our rule is you have to be able to decide an
appropriate approach speed, explain why you chose it, and then keep within 5km/h
of it.
John Smith wrote:
Brian wrote:
Looking at a polar is exactly why it works. It is called Speed to fly.
It really only works well when you have some headwind. It does work
somewhat in calm conditions but is really not very effective. It
probably doesn't work at all in a tailwind condition.
First I thought that you were pulling our legs, but it seems you're
actually serious.
Every year a couple of pilots die because they are too slow on approach.
Where I fly, a student will fail his checkride big time if he's only one
knot below the yellow triangle on final. *Especially* with a headwind.
If you don't understand this, I *strongly* recommend you talk to a
knowledgeble instructor.
Old October 25th 07, 11:07 PM posted to rec.aviation.soaring
John Smith
You can't be rigid enough when it comes to final approach speed.
needle has to be ON the yellow triangle, what happens to the pilot when
he suddenly notices the glider he is in doesn't have one.
Yeah, yeah, yeah. I would expect from a glider pilot that he doesn't
"suddenly" discover on short final that there isn't such a triangle, but
that he familiarizes himself with the glider before the flight. If he
doesn't, then many other things have gone wrong during his training.
Of course. But the other poster proposed to slow down to the point where
you get a steeper approach. For me, this is a *very* rigid no-no. I
don't think that rigidness in this point kills people. I even tend to
think the contrary.
MA-8 with parachute extended S63-00693.jpg [email protected] Aviation Photos 0 April 10th 07 02:52 PM
spoilers vs. ailerons [email protected] Piloting 36 August 8th 05 11:24 AM
Frozen spoilers stephanevdv Soaring 0 November 4th 04 05:24 PM
Extended GPX Schema Paul Tomblin Products 0 September 25th 04 02:44 AM
L-13 Spoilers Scott Soaring 2 August 27th 03 06:08 AM
