Civil airports closed for ultralights
Old October 26th 07, 11:55 AM posted to rec.aviation.piloting
wp
Default Civil airports closed for ultralights
How many civil airports in Europe are closed for ultralight aircrafts?
If so, what's the common cause?
Example NOTAM (EPKK):
A3465/07
AD NOT AVBL FOR CIVIL ULTRALIGHT AIRCRAFT DUE TO LACK OF PARKING
POSITIONS AND GROUND STAFF SHORTAGE.
SCHEDULE: 0800-1600
SPace-SHIP
Old October 26th 07, 12:07 PM posted to rec.aviation.piloting
Stefan
When it come to ultralight aircraft, there is no such thing as "Europe".
Each country is different. And the situation in each country is different.
Old October 26th 07, 02:24 PM posted to rec.aviation.piloting
Denny
The categories of aircraft allowed on a given airport are listed in the
AIP, and "UL" will be listed. Those who allow microlights are also
marked with a specific symbol on VFR charts.
When are you folks in "europe" going rise up and throw those socialist
monstrosity governments that believe that they OWN you from birth to
death, off the continent?
denny - ugly, capitalist, revolutionary spawn - and proud of it...
Old October 26th 07, 02:51 PM posted to rec.aviation.piloting
Stefan
Not really, just a bit uninformed.
Don't feed the troll. Not worth the effort.
Old October 26th 07, 03:40 PM posted to rec.aviation.piloting
wp
To be more precise: which international airports you are aware of are
closed for ultralights? I wonder if this is common practice or just an
exception?
In terms of ultralight in mean LSA/VLA of MTOW 495/600kg.
SPace-SHIP
Old October 26th 07, 04:12 PM posted to rec.aviation.piloting
Stefan
exception?
Again: When it comes to ultralights, there is no such thing as "Europe".
Even this definition is not unified in Europe.
Old October 26th 07, 04:34 PM posted to rec.aviation.piloting
Snowbird
One variation on the theme is those large airports that require a
transponder to enter the control zone. That tends to keep out most ULs, as
it's difficult to fit a transponder within the (in this case) 450 kg MTOM
limit.
Another variant is the significantly higher landing fees charged at the
large airports.
Neither one is of course directly shutting out ultralights, but the end
result is practically the same.
And as already mentioned, each country is different.
Old October 26th 07, 04:55 PM posted to rec.aviation.piloting
wp
limit.
Transponder weights only 1.5kg or even less so it's not a problem.
large airports.
The money is not a problem as well.
SPace-SHIP
Old October 26th 07, 06:55 PM posted to rec.aviation.piloting
Snowbird
Then buy a certified airplane, for example the inexpensive Aero AT-3, which
presumably can be operated at your airport ;-)
Ultralights in Space? DABEAR Home Built 9 February 12th 07 08:26 PM
Australian Ultralights Kevin Berlyn Home Built 0 March 15th 05 12:09 PM
Best engine for ultralights Josip General Aviation 5 August 27th 04 06:02 PM
one medical away from Ultralights Gilan Owning 7 May 22nd 04 12:54 AM
one medical away from Ultralights Gilan Piloting 7 May 22nd 04 12:54 AM
