the ideal fire/water bomber?
Old October 29th 07, 01:44 AM posted to rec.aviation.piloting
Morgans[_2_]
Default the ideal fire/water bomber?
"Bertie the Bunyip" wrote
I've watched one put out a real fire in france. Amazing. But the key here
is nearby water source. without one how good is it compared to anything of
similar size and weight?
It can also refill on the ground with a hose and tanker. It can lift a full
load off of a runway, 1200 gallons for a 215, 1400 gallons for a 415. I
would have to do some searching to find out how much runway it would take,
but it isn't much.
Jim in NC
Old October 29th 07, 03:55 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"Morgans" wrote in
here is nearby water source. without one how good is it compared to
anything of similar size and weight?
a full load off of a runway, 1200 gallons for a 215, 1400 gallons for
a 415. I would have to do some searching to find out how much runway
it would take, but it isn't much.
Oh I know, but that just puts it on even footing with a similar sized
aircraft with a tank installed, in which case, if you were buying an
airplane to protect an area with no bodies of water nearby, you'd be as
well off or better off buying something even larger that's filled the same
way.
Bertie
Old October 29th 07, 05:04 AM posted to rec.aviation.piloting
patrick mitchel
"Morgans" wrote in
Do they still make the -215 as the av book shows it having the PW R2800
recip engines- do they still make those or are they using a reman? Gotta be
a lot more econmical at least from the fuel burn at low altitudes. Pat
Old October 29th 07, 04:18 AM posted to rec.aviation.piloting
"patrick mitchel" wrote in
"Morgans" wrote in
lift a full load off of a runway, 1200 gallons for a 215, 1400
gallons for a 415. I would have to do some searching to find out
how much runway it would take, but it isn't much.
R2800
Gotta be a lot more econmical at least from the fuel burn at low
altitudes. Pat
No, they haven't made them since the sixties, at the latest. They'd be low
hours rebuilds.
Bertie
What is the ideal ILS antenna? billkennedy3 Home Built 8 October 5th 05 07:22 PM
Ideal Glider Hangar Dimensions SGS135 Soaring 3 November 27th 04 11:04 PM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Ideal watch? Brinks Owning 45 December 24th 03 03:00 PM
ideal training glider M B Soaring 2 September 19th 03 10:15 PM
