Meeting to discuss FLARM in the USA
Old October 29th 07, 01:50 PM posted to rec.aviation.soaring
Andy[_1_]
Default Meeting to discuss FLARM in the USA
On Oct 27, 10:16 pm, " wrote:
, and don't get me started on the cheap "transponder
sniffer" devices... ;-)
Urs --- FLARM
Thanks for joining the discussion and for the factual input on FLARM.
Cheap transponder sniffing devices such as the Zaon MRX that I use in
my glider and my airplane can do something that FLARM cannot do. They
can warn of the proximity of an aircraft with transponder but no FLAM.
In over 25 years of flying gliders I have had many many more near
misses with powered aircraft than with other gliders. It was my last
experience of a King Air going through my gaggle with 2 other glider
that convinced me to buy the Zaon.
I'll be the first to admit that Xaon MRX would be useless if all
gliders had transponders. The designer was approached to see if an
intelligent muting alogorith could be added but he responded there was
insufficient processing power in that unit. So integrate the sniffer
with FLARM and provide intelligent muting of transponder alerts then
you would have a US market.
Andy
Old October 29th 07, 08:14 PM posted to rec.aviation.soaring
Eric Greenwell
If gliders everywhere were assigned a separate code, like the 0440 in
Minden, it might be a much easier task. Nearby gliders would not
generate alerts, for example, while airplanes using the 1200 code would be.
Yes! And if the logger were IGC approved, it would be an even bigger market.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old October 29th 07, 10:55 PM posted to rec.aviation.soaring
Robert Danewid
Eric Greenwell skrev:
Buy a Colibri FLARM and you have it!
Robert Danewid
AS 28-18E RD
market.
Old October 30th 07, 09:11 PM posted to rec.aviation.soaring
Andy[_1_]
On Oct 29, 3:55 pm, Robert Danewid
I don't think so! Are you saying the Colibri has integrated PCAS and
reports transponder targets?
Andy
Old October 30th 07, 09:09 PM posted to rec.aviation.soaring
Andy[_1_]
The Zaon MRX does not do anything with the squawk code except to
report the host aircraft code. Target tracking and reporting is based
only on signal strength which is interpreted as target distance.
Based on the the designers response to intelligent muting I have no
doubt that intelligent muting based on squawk code would be a non-
starter.
Andy
Old October 31st 07, 05:06 AM posted to rec.aviation.soaring
Eric Greenwell
starter.
It was a general observation that applies to transponder detectors. I
think it would require less processing power and provide better muting
if the unit could determine which threat was a glider and which was an
airplane.
I would like to hear from MRX-equipped (or similar units) pilots that
fly with other gliders equipped with transponders. I've done a limited
amount of it, and with only a few gliders at a time. By setting the
altitude warning band tighter and ocasionally using the mute button on
the MRX (though I'd like the mute to automatically reset after 5 or 10
minutes), I wasn't bothered by excessive alerts.
Old October 31st 07, 07:00 AM posted to rec.aviation.soaring
bumper
I've been flying with a Proxalert R-5 for over 5 years. It displays the
squawk code of the threat aircraft so I can tell, at least near Minden, if
it's a glider (0440) or someone not talking to ATC (1200), or if the other
aircraft *is* talking to ATC (discreet code) and thus likely has been told
about me.
The R5's ability to display squawk appears to be not enough of an advantage
to overcome its more expensive price tag and larger form factor as compared
to the diminutive and more popular ZAON
I wonder if enough people asked them to add squawk code display, ZAON would
add that to there next model. I'd buy one.
bumper
news:Z2UVi.4372$pT.572@trndny07...
be.
starter.
think it would require less processing power and provide better muting if
airplane.
I would like to hear from MRX-equipped (or similar units) pilots that fly
with other gliders equipped with transponders. I've done a limited amount
of it, and with only a few gliders at a time. By setting the altitude
warning band tighter and ocasionally using the mute button on the MRX
(though I'd like the mute to automatically reset after 5 or 10 minutes), I
Old October 31st 07, 01:00 PM posted to rec.aviation.soaring
Andy[_1_]
I have the MRX and have flown at meets where there was at least one
transponder equipped glider. It was not a problem. For the case
where I was nearly mown down by a King Air, the MRX would have given
no protection if one of the other gliders with me had been transponder
equipped and I had muted the MRX. Intelligent muting requires that
the unit will unmute if a new threat is detected. It could perhaps be
made more intelligent if unmute was not activated by a new glider
target but that's debatable.
I think there is great potential for integrating FLARM or ADS-B (with
CDTI) with PCAS devices. I hope that will be discussed at the
meeting.
Andy
General Janis Karpinski/Karen Kwiatkowski discuss war for Israel in Iraq and beyond... [email protected] Naval Aviation 0 April 23rd 06 11:44 AM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
Flarm Mal Soaring 4 October 19th 05 08:44 AM
FLARM John Galloway Soaring 9 November 27th 04 07:16 AM
Roadable aircraft group please join and discuss with us in our forum Strafi Home Built 0 October 22nd 03 01:37 AM
