CNN article on problems in Air Travel, as seen by FAA
Old October 30th 07, 02:27 AM posted to rec.aviation.piloting,rec.travel.air
Morgans[_2_]
Default CNN article on problems in Air Travel, as seen by FAA
"John Kulp" wrote
GPS allows for closer spacing and straighter flight paths allowing
more flights to be handled in the same time span. About 25% more.
If they are heavies, the separation for wake turbulence is what the limiting
factor for separation, isn't it?
Jim in NC
Old October 30th 07, 03:02 AM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Mon, 29 Oct 2007 22:27:34 -0400, "Morgans"
Well, wake turbulence is certainly a factor, particularly for the A380
which may slow down things even further. Which raises the question as
to whether it should be penalized more than others if they start to
use penalties.
Old October 30th 07, 01:28 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
use penalties.
If it takes up more of a scarce asset then of course it should pay more.
Old October 30th 07, 03:58 PM posted to rec.aviation.piloting,rec.travel.air
Newps
You need up to six miles behind a heavy. Your spamcan needs four miles
behind a large, such as a B737. To say GPS increases available capacity
25% is ludicrous.
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
