Re-shaping fiberglass parts with heat
Old October 30th 07, 09:27 AM posted to rec.aviation.soaring
Default Re-shaping fiberglass parts with heat
On Oct 29, 12:28 pm, JJ Sinclair wrote:
I knew the concept was valid from Schempp-Hirth instructions on how to
heat up an early Cirrus wing and put in the twist that Cirrus's after
s/n 175 had. I have a badly twisted gear door (corner stood proud a
good 5mm), so I thought I'd give it a try on a much smaller scale. I
held the gear door in front of an electric space heater for a good 8
minutes, until it was too hot to leave a finger on the surface. Then I
put it in place on the wheel-well (fuselage inverted) and held the
ends with two 25# shot bags. I slipped in a 5mm shim to achieve over-
twist for the expected spring-back. Let it cool for an hour and it
fits like new!
Anybody else have experience heat-twisting epoxy/fiberglass parts?
What's the yield temp?
JJ
Depends on the resin.
When we reshaped the trailing edge of my ASW22 Rudder, Larry M. built
a foam box and used hair dryers to maintain it at 175F
The part was Kevlar lay up not plain glass.
Your experience might vary
Regards
Al
Fiberglass seperation Lou Home Built 7 September 25th 06 04:03 AM
Aluminized fiberglass Dan, U.S. Air Force, retired Home Built 2 May 3rd 05 08:35 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 02:20 AM
2004 California airshow season shaping up! Wings Of Fury Military Aviation 0 December 31st 03 05:34 AM
