SR-71
Old October 30th 07, 03:32 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default SR-71
Gatt wrote:
"Morgans" wrote in message
What he is hinting at is probably the Aurora. You know, the one that
leaves donut shaped con trails?
That's no longer with us, is it?
Well according to THE GOVERNMENT it never was. And the plane that
didn't/doesn't exist was supposed to be pulse jet.
Old October 30th 07, 04:08 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default SR-71
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in
Not quite. Though the principle is essentially the same, the engine has not
moving valve at the front. A pulse jet wouldn't be able for supersonic, let
alone hypersonic flight.
the inlet would have an annular inlet arranged so the flow would direct
each pulse down the rear of the engine, but there would be a small efflux
out of the annular inlet. The biggest advantage to this system is that it's
easily throttleable simply by varying the frequency of the pulses.
this thing almost certainly exists. More than likely it's a development of
the Convair Kingfish which was , like the A-12, an upshot of project GUSTO,
but we're not going to be told anytime soon! I read about the Kingfish
years ago and can't find anything decent about it on the net, but it was a
parasite aircraft with some sort of ramjet or zip engine that had a ceramic
coating and was capable of cruising at over mach 4. At least one of it's
designers has alluded to it actually having gone ahead, but it's still a
very black item.
Bertie
Old October 30th 07, 04:24 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default SR-71
has not moving valve at the front. A pulse jet wouldn't be able for
supersonic, let alone hypersonic flight.
direct each pulse down the rear of the engine, but there would be a
small efflux out of the annular inlet. The biggest advantage to this
system is that it's easily throttleable simply by varying the
frequency of the pulses. this thing almost certainly exists. More
than likely it's a development of the Convair Kingfish which was ,
like the A-12, an upshot of project GUSTO, but we're not going to be
told anytime soon! I read about the Kingfish years ago and can't find
anything decent about it on the net, but it was a parasite aircraft
with some sort of ramjet or zip engine that had a ceramic coating and
still a very black item.
I mis-wrote. I should have written Pulse Detonation Engine
http://en.wikipedia.org/wiki/Pulse_detonation_engine
Old October 30th 07, 04:28 PM posted to rec.aviation.piloting
Default SR-71
Hmm, amybe I'll try welding one up out of some old drainpipe I have
outside!
I'll never forget the sound of the old dynajets some of the guys had at my
CL field when I was a kid.
Bertie
Old October 30th 07, 06:06 PM posted to rec.aviation.piloting
Phil
Default SR-71
very black item.
Bertie
I think it's pretty likely that Kingfish (or Aurora or whatever they
actually called it) is flying. If I had to guess, I would say they
retired the SR-71 because it was old technology and because it was
vulnerable to newer generation anti-aircraft missiles. As far as the
secrecy surrounding the new aircraft, it is hard to see what would be
gained by making it public.
Phil
Old October 30th 07, 07:00 PM posted to rec.aviation.piloting
Default SR-71
Phil wrote in
ups.com:
that leaves donut shaped con trails?
Bertie
Also hard to see what could be gained by keeping it secret at this
stage. If one exists, any opposition knows about it. It's been in the UK
and you know how crap they are at keeping secrets. (One of them had a
close encounter with a Brittania airlines 767 in Manchester about ten
yars ago, though it could have been an F-117, of course)
in this day and age when sattelites can read licence plates and everyone
knows it you'd wonder why they would bother keeping it secret after all
these years for any reason other than habit.
Bertie
Old October 30th 07, 07:17 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default SR-71
UK and you know how crap they are at keeping secrets. (One of them
had a close encounter with a Brittania airlines 767 in Manchester
about ten yars ago, though it could have been an F-117, of course)
everyone knows it you'd wonder why they would bother keeping it
secret after all these years for any reason other than habit.
Bertie
A. If they make it public they are going to have to tell how much it costs.
B. Once public, sooner or later the specs on it will get out. The one
advantage a spy plane has over spy-sats is that you don't know when it is
going to be over you taking pictures. If it becomes known that the plane can
fly from Nevada to Iran in x hours they just have to have someone in Nevada
to tell them about the launch and then x hours later whatever they need to
hide will be hidden.
C. They would have to disclose the alien tech that is in the aircraft.
My money's on A. No matter what they will use B as the reason once they do
make it public. But I really wish C were the reason.
Old October 31st 07, 01:50 AM posted to rec.aviation.piloting
Phil
Default SR-71
On Oct 30, 2:17 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
Once everyone sees that it's a saucer, the cat's out of the bag!
