CNN article on problems in Air Travel, as seen by FAA
Old October 31st 07, 05:34 PM posted to rec.aviation.piloting,rec.travel.air
Newps
Default CNN article on problems in Air Travel, as seen by FAA
John Kulp wrote:
Ah, no. GPS was not designed for that nor can it provide that. Most in
trail separation today is based on wake turbulence. Even if you got rid
of wake turbulence you still can't get less than 2.5-3 miles for jets
because that's how long it takes to land, slow down and exit the runway.
If it's dry. And that spacing doesn't allow departures to get out
between the arrivals. So you go to five miles and if everything works
out perfect that's barely enough room to get the jet departures out.
The plain simple fact of the matter is the limiting factor is lack of
runways. No amount of technology can force more airplanes onto the
runways we have now.
Funny none of the airlines I know of are saying this. They are all
advocating just this upgrade and the FAA is going to have it build.
So just what do you know that those running the business don't?
GPS was designed and built by the military. Imagine that, the airlines
not wanting to change anything but have others change to meet their
outmoded business plan. You can't change basic physics. GPS can
generate some minor efficiencies in getting aircraft to the start of the
arrival which is 150 nm from the airport. Then everybody gets lined up
and fed to the airport. GPS is of little value from that point on in
reducing spacing. How are you going to overcome the basic fact that
2.5-3 miles is the minimum useable spacing, assuming no departures?
Many studies have been done that the optimal runway occupancy time is
approx 45 seconds for a landing aircraft. More typical is 1 minute, in
good weather. That's approx 2.5-3 miles separation. You want more
operations? Lay more concrete.
Old October 31st 07, 06:18 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
So what? I use it all the time in my car to find where I am and where
I'm going. Just like the airlines want.
Imagine you not knowing what you're talking about. The airlines have
made huge changes in their business plans which you obviously know
nothing about.
Uh, when someone else pointed out that it is currently 5-6miles you
don't call that increased efficiency? Where did you study math?
a. what studies?
b. that would increase efficiency about 50% if it is currently 6 miles
wouldn't it?
Old October 31st 07, 07:07 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
John, you seem to be under the impression that GPS is going to somehow
manage to change the physics of time and space. Yes, when airlines use GPS
they can fly direct from point A to point B but if A and B are crowded they
are still going to have to wait on the ground to take off and fly around in
circles waiting to land.
Old October 31st 07, 07:52 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Wed, 31 Oct 2007 14:07:55 -0500, "Gig 601XL Builder"
Where did I say this? I said that if spacing can be reduced due to
safer wake turbulence management then GPS can be used to safely close
those spaces and improve the capacity of the system. That's all.
Just where do you think I am confused. And, if I am wrong (or
confused)
a. why is the FAA going ahead with the building of the system?
b. why are the airlines backing that change?
Old October 31st 07, 09:07 PM posted to rec.aviation.piloting,rec.travel.air
Larry Dighera
On Wed, 31 Oct 2007 19:52:22 GMT, (John Kulp)
wrote in :
The former Clinton administration opposed ATC privatization.
The current administration wants to privatize virtually every
government service. In the case of the FAA, privatization would
enable FAA to cut their workforce significantly, dodge liability
exposure, and open the federal coffers to by outsourcing to big
business.
Big business benefits from government privatization. Consider
Halliburton's contract to do the Army's laundry in Iraq[1] for
example.
Privatization also removes government accountability; private
corporations are not subject to FOIA requests, for example.
The airline industry, including the airliner manufacturers, would like
nothing better than to remove congressional FAA budget oversight, and
wrest the balanced governmental allocation of National Airspace System
resources from US citizens, so that they can advance their air carrier
agenda at the expense of other airspace users. Airliner manufacturer,
Boeing, is also in the privatized ATC business.[2]
[1]
http://video.google.com/videoplay?do...=iraq+for+sale
http://www.youtube.com/watch?v=6cJlJudDtVE
http://www.iraqforsale.org
[2] http://www.boeing.com/phantom/ast/atm.html
Old October 31st 07, 09:11 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Larry Dighera wrote in
wrote in :
business.
example.
If ATC is privatised, light aviation is, in a word, ****ed.
Bertie
Old October 31st 07, 09:40 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Wed, 31 Oct 2007 21:07:05 GMT, Larry Dighera
wrote in :
It also opposed social security privatization which the Swedes have
done quite well
business.
How does that work? Why wouldn't the government just be getting out
of the business?
example.
Sometimes they do, sometimes they don't. Depends on the contract.
Why should the government be accountable for something they are no
longer doing. Private corporations are subject to their auditors,
customers, Sarbanes-Oxley and a whole host of other things.
Why not if they can do it better and cheaper than the government,
which is a virtual sure thing. Who else but the government do you
know that is still using WWII technology like the FAA?
Old November 1st 07, 10:20 AM posted to rec.aviation.piloting,rec.travel.air
Larry Dighera
On Wed, 31 Oct 2007 21:40:14 GMT, (John Kulp)
wrote in :
(John Kulp)
wrote in :
business.
of the business?
example.
Are you able to cite a single US government privatization that hasn't
resulted in a windfall for private contractors?
longer doing.
Air Traffic Control records should remain accessible to the public, as
they are now, because they may establish legal culpability.
None of which will grant public access to their records as is
currently possible under the FAA.
Consider the November 16, 2000 case of the Mid Air Collision of a USAF
F-16 and a Cessna 172 over Florida. How would the widow of the C-172
pilot have obtained ATC records indicating the controller manning the
position responsible for alerting the pilots to the imminent collision
was unqualified if those records where the sole property of a private
contractor?
ATC is not about cheaper; it's about safer. Currently the US ATC
system is the best in the world. What criteria did you use to reach
your conclusion, that a new, un-tested privatized ATC system will ever
end up as good, let alone better than the current system? Or is that
just your unsubstantiated guess?
Also consider, what if the private contractor who wins the NextGen
competitive bid ATC contract is an Iranian firm (you know, like the
Dubai ports scandal)? Do you feel that it would be appropriate for a
foreign power to control the US skies?
Old October 31st 07, 09:16 PM posted to rec.aviation.piloting,rec.travel.air
Neil Gould
Recently, John Kulp posted:
somehow manage to change the physics of time and space. Yes, when
airlines use GPS they can fly direct from point A to point B but if
A and B are crowded they are still going to have to wait on the
ground to take off and fly around in circles waiting to land.
confused)
From what you said on 10/29/07:
"Gates can be a problem sometime but not runways. The GPS system would
handle about 25% more flights on the same runways."
And restated in your response to Jim:
"So you are saying, at peak rush times, there is 25% extra time for
separation to be maintained?"
Jim in NC
"GPS allows for closer spacing and straighter flight paths allowing
more flights to be handled in the same time span. About 25% more."
It appears that your expectations are too optimistic. The reasons for the
required separation in the destination airspace are wake turbulence and
runway safety. GPS will not have an impact on that, and that is where and
why the delays are occurring. As several others have explained, getting
there faster will not mean getting on (or off) the ground faster. It may
be that having 25% more flights in the air would only aggravate the
situation, as the required separation would still have to be maintained in
the airport's environment.
There are some benefits to upgrading the technology, particularly in
regard to near-misses en route. But, as long as the airlines' scheduling
and hub system are unchanged, there probably won't be any big improvement
in the number of delays. Go to one of the busier airports and observe the
arrivals and departures and you'll get an idea of why.
Neil
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
